03-28-2020, 03:38 PM | #1 |
1982 GMC Sierra- cab corner wires
Hi Guys,
I am restoring a 1982 GMC Sierra. I removed the interior from the truck about three years ago to allow for rust repair. I am now putting it back together and am having a hard time with the wires that run along the drivers rocker and plug into wires going up into the cab from the drivers side cab corner. I believe one wire is for the interior light...what is the other wire for? |
03-28-2020, 04:55 PM | #2 |
Moderator
Re: 1982 GMC Sierra- cab corner wires
Two wires would be the power and switched ground for the dome light.
Off the top of my head Orange hot and White switched ground from the door and headlamp switch but I'm not positive on those colors.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
03-28-2020, 06:12 PM | #3 |
My 81 C20 has one wire that goes to the seat belt.
Eric 2001 Ford F350 EC dually 7.3 1981 Chevy C20 to K20 350 1978 Oldsmobile Cutlass Supreme 455 Pontiac 1969 Pontiac GTO 400 |
03-29-2020, 10:07 AM | #4 | |
As said by
Should have connector on it cab corner Driver side if you have the rear top dome light another orange wires and white wire harness from light to the top 1/4 of the cab corner. If you have seat belt light/buzzer as said black or white wire there (check your yr). I Have all was have mine unplugged.73-85 cars and truck I owned.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
03-29-2020, 01:54 PM | #5 |
Thanks Guys....will look into it further. I know I have an orange wire....think there is also a single black wire.
