Old 10-20-2020, 09:06 AM   #126
theastronaut
theastronaut's Avatar
Re: 1966 F100 Short Bed Styleside Metal/Body/Paint Work
Originally Posted by Russell Ashley View Post
I think you are magic. How do you have time to do stuff like this and work on your Fiesta too?
My own projects get pushed back a lot, the red Festiva is still sitting and theres a list a mile long that needs to be done with the white one. Haven't done much with my '66 C10 in about a year either except for moving it around the shop and assembling the sheetmetal. My '64 VW is in storage, the '63 is slowly being converted to stock suspension, and my granddad's '64 C10 is also just sitting in storage. Hopefully by the time this F100 is finished I'll have the shop set up to transition into doing more panel fabrication and less big projects, and I'll have more time for my own projects.
Originally Posted by mongocanfly View Post
Thanks John...so to raise the panel , did you hold the dolley on the bottom side pushing up, and hammer on the top?..I've had some similar stuff I've worked my butt off trying to fix, so I had to ask...
I lightly hold the dolly on top and use the hammer to push the metal up, pretty much just letting the weight of the dolly hold it down- no added pressure. The dolly is mainly there to squeeze the metal between the hammer and dolly for stretching the metal, and the hammer is also pushing the metal upward as it stretches. The dolly will somewhat keep the metal from moving up as much as it could so some hammer blows without the dolly will rearrange the metal into the correct shape if there's enough stretching. It would still stretch the metal if the hammer/dolly were on opposite sides but I feel like hammering in the direction you want it to go is more effective.
theastronaut is offline   Reply With Quote
Old 10-20-2020, 12:02 PM   #127
mongocanfly
mongocanfly's Avatar
Gotcha...thanks John..!
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 10-21-2020, 04:00 PM   #128
theastronaut
The owner wanted the radio, glove box, and ashtray shaved. I ground through the outer layer of the dash to release the spot welds over the left half of the inner dash brace that was straight. The right side of the inner brace was shaped to fit the glove box opening so it was cut out.
The right corner of the dash was bent too far outward past straight/in line with the center of the dash- the aluminum bar is laid flat against the center section of the dash to show the misalignment. I cut far enough over to get rid of the part that was rounded out too far so the new section would be in the correct alignment.
The top edge of the glove box opening was formed really close to the bend across the face of the dash, so that won't leave much room for welding and grinding.
Profile gauge and tape with matching marks to transfer onto the filler panel blank.
After turning the lower flange with a brake, I used the profile gauge to mark the filler panel for the area that needed the most roll and the areas that were mostly flat.
I picked the english wheel die that most closely matched the profile of the dash. I didn't take pics while I was making the panel, but I stretched an inner tube over the upper wheel so that the english wheel only bent the metal in one direction instead of two since this isn't a compound curve.
Matched the shape of the old panel.
Initial test fit. I'll wait to weld it in after the owner comes over so we can finalize the placement of the A/C vents, it'll be easier to weld in the A/C vent mounting cups with the filler panel loose instead of welded in place.
I turned a couple of mdf blocks in the lathe to make mounting cups for the A/C vents. This will keep the vent mounting flange straight and flat while shaping the edges.
First quick trial piece, not really happy with this shape but it's something to start with.
C-channel dash brace fabricated and test fit. Not perfectly shaped to match the original but it's just a dash brace that'll never be seen.
Right side turned 90* with mitered and welded corners, and drilled for a plug weld.
Last detail to sort out before the A/C mounting cups can be welded in- there was a recessed round stamping with a raised lower edge in the corner of the dash that will interfere with the edges of the A/C vents. I used a mallet, hammer, and dolly to flatten it and reshape the corner to the correct profile. To finish it I went over it with a 2" 100 grit disc on a 1" grinder; that lets the pad flex to the rounded shape without digging in on the edges. Then finished with a DA sander. You can see by the "light line" reflections that the corner is evenly shaped.
Initial hammer/dolly work to really flatten and level the stamping.
After reworking the shape using a small PVC fitting as a donut dolly and mallet.
Smoothed up with 100 grit, then 60 grit on a DA.
Old 10-21-2020, 11:40 PM   #129
MP&C
MP&C's Avatar
Like it was never there.. Awesome John!
Robert
MP&C is offline   Reply With Quote
Old 10-22-2020, 07:22 AM   #130
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
That is a very nice dash. As usual, your work blows my mind....
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 10-22-2020, 07:46 AM   #131
mongocanfly
I was gonna say "like it never happened "...but Robert beat me to it..!!
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 10-31-2020, 10:42 PM   #132
theastronaut
Thanks guys! I think all the bed floor detail sanding has made me push for getting the metalwork on the dash straighter for less filler /shaping sanding later on
The dash was originally padded and had a separate trim piece at each end. The owner wants a painted dash with no pad or original trim pieces which leaves ugly dash corners when both are removed, so my next task was to smooth out the transition from the dash to the A-pillar and windshield pinchweld.
Old edge of the dash cut out.
The seams in the door jamb were pretty ugly as well so they were welded up and reshaped. I don't like fully shaving seams, I prefer the look of well defined panel edges and evenly shaped seams. Noticed the mismatch between the kick panel's edge and the separate door jamb panel- this was corrected.
I ended up doing two rounds of welding/shaping to get a consistent seam, then did a bit more final touch up work after the dash corner was welded in.
To make a template for the new dash edge I used tape and a sharpie to get a rough idea of the new edge's trim/fold line.
The front edge was folded over 180* and the rear edge was bend down 90* for a flange to weld to the A-pillar. The front section that wasn't bent was later trimmed off.
Using linear stretch dies in the planishing hammer to lengthen and raise the inside edge to match the contour of the dash hump.
After a lot more shaping and fine tuning of the outside edge. I had reworked the edge a lot and it was beginning to fatigue, so I cheated and welded the edge of the flange to strengthen it, which also gave me enough material to grind a consistent radius on the edge.
The last issue to straighten out before welding in the new corner- There was a spot weld in the A-pillar that created a low spot and an uneven gap for the new dash edge. I drilled a small hole in the outside of the pillar and used a punch to bump the inner panel level.
Old 10-31-2020, 10:55 PM   #133
theastronaut
After welding the panel in, initial planishing of weld seam, and grinding the welds flat. Notice that I also lengthened and reshaped the upper edge of the door jam panel so that seam is in line with the upper corner of the dash edge.
And then the process was done on the other side of the dash. This side was much easier since there was no transition into the cluster hump.
The removed panel with a bit of tape added was sufficient for a template.
Shaped on the english wheel to match the dash profile.
Cut line scribed.
Initial fit up.
Final fit.
After welding, leveling the welds, and planishing the weld distortion. Finished in 60 grit on a DA sander to prep for epoxy.
Old 10-31-2020, 11:30 PM   #134
mongocanfly
More really nice work John..!!
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 11-01-2020, 05:03 AM   #135
Ol Blue K20
Absolutely amazing!, Looks great.
Dale
Old 11-01-2020, 04:04 PM   #136
Russell Ashley
Russell Ashley's Avatar
Amazing work. This has to be costing the owner a fair amount. Just wondering if there is sentimental attachment to this truck.
Russell Ashley is offline   Reply With Quote
Old 11-02-2020, 10:38 AM   #137
youngrodder
youngrodder's Avatar
Awesome stuff right there....I love to see how to tackle the various challenges.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 11-09-2020, 11:19 AM   #138
theastronaut
Marc
Appreciate all the comments! Russell, I believe the truck was purchased not long before we started on it, it hadn't been in the family or anything like that.
Old 11-09-2020, 11:31 AM   #139
theastronaut
More metalwork on the cab. The firewall had a lot of extra holes to fill in. It'll have a hydraulic clutch and an aftermarket wiring harness so none of those holes were needed anymore. I made a bigger panel to fill in a bunch the smaller holes instead of filling them individually.
A notch had been made in the firewall seam for clearance around the new engine. I tacked the two layers together to keep them from flexing or separating so the seam sealer won't be upset later on.
Determining a radius.
Radius and allowance for the flange scribed into a sheet of metal.
Flanged formed using a steel block and mallet initially.
Turning a curved flange causes the panel to distort, so I used a section of round bar in the vise and a hammer to stretch the flange out to take out the distortion.
Trimmed and welded in place.
Old 11-09-2020, 12:00 PM   #140
theastronaut
The filler neck hole needed to be shaved. The shape around it was flattened and a bit more square compared to the right side of the cab. I made a quick flexible shape pattern to compare both sides, and it also maps out exactly how much to stretch the new filler panel.
First step was to roughly knock out a dent in the opposite side so the pattern would be accurate.
Two layers of tape. The blue tape is low adhesion so it peels off easily with no risk of stretching the pattern as it comes off. The second layer is reinforced with fiberglass strands so once it's pressed down firmly it'll hold the same length- this is important as it allows the template to retain the same surface area over every square inch after it's removed. That surface area is what shows how much stretch is needed to replicate the panel.
With the pattern removed you sprinkle it with baby powder to kill the adhesive. You can see how much surface area the pattern has, and how the details of the body lines carry over.
I also made marks on the template to locate the filler neck on the pattern. The patterns can be flipped inside out while retaining their surface area.
Vertical and horizontal lines marked through the center of the filler panel area. The pattern on shows the amount of stretch needed, not the exact shape, so a profile gauge shows how the added surface area from stretching needs to be shaped and arranged.
Low spot in the middle- more stretching needed.
Overall shape is now correct.
After rough trimming. Notice how the bottom corner doesn't match up, that's from the flat stamping around the filler neck opening. Using this method of making a filler panel and having the flexible shape pattern ensures that any variance between the two sides is made noticeable so it can be corrected.
Welded in and welds ground down, still needs final planishing.
The owner brought the gauge bezel so I could fit it and lay out the location of all of the switch holes. I used washers with butyl that are roughly the size of the A/C controls, and cut out a few pieces from a worn DA disc in the diameter of the ignition switch and headlight/wiper bezels. This lets me stick them to the dash and move them around where they look best.
Old 11-09-2020, 09:00 PM   #141
duallyjams
duallyjams's Avatar
english wheel, planishing hammer, lathe, may need a shop tour.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 11-10-2020, 12:08 PM   #142
67ChevyRedneck
67ChevyRedneck's Avatar
We need to add a "GIF" thingy to the forum. This thread totally needs an old school Waynes World "We're not worthy" GIF.
Great work as always!
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-10-2020, 10:17 PM   #143
theastronaut
Here's the quick version until I have time to make a shop tour vid
https://www.harborfreight.com/catalo...tools/id/2159/
There's nothing too special; we have a HF english wheel and planishing hammer, a small shrinker/stretcher set from Eastwood, 4' brake, Millermatic 135, Mittler Bros 24" bead roller, and the Atlas/Craftsman lathe. Currently looking for a heavier box/pan 4' brake, 4' stomp shear, and a Burke/Powermatic Millrite milling machine. Haven't got the new/old bandsaw or Pullmax up and running yet, the VFD I want to use is out of stock and that side of the shop has to be rewired for 220v. Hope to have those up and going by the end of the year.
Thanks Jesse!
I finished up the dash layout today. The second pic shows how welding close to the edges makes the distortion more prevalant, third pic is after planishing to stretch out the weld zone.
Old vs new layout. The ignition switch was moved from beside the cluster to under it, and the headlight and wiper switches were moved over to make room for it. One original hole on the left side was deleted. The right side was shaved and three 9/32 holes were added for the A/C controls. The spacing was modified from stock to more evenly fill out the panel and better match side to side.
Old 11-10-2020, 11:28 PM   #144
mongocanfly
More great work John...love the shop tour..!!!...
Is that dash inset aftermarket or orig?..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 11-11-2020, 12:28 AM   #145
theastronaut
Thanks! I've been doing some repairs/remodeling and painting and cleaning and organizing around the shop, I'll do a video tour once it's farther along.
The dash is aftermarket, made by Classic Dash.
https://classicdash.com/product/1961...6-gauge-panel/
Old 11-17-2020, 11:28 PM   #146
theastronaut
Next step on the dash was to figure out a way to blend in a flat spot to mount the A/C vent right in the middle of the very curved location where the ignition switch was. To keep the flat spot flat I bolted two pieced of MDF together and turned them down just larger than the OD of the A/C vent.
After a lot of hammering, shrinking, stretching, and shaping to fit the contours of the dash... a shape started to form around the flat spot. I got started and kept going and didn't take pics of this process like I should've. This is a shape that I wasn't 100% sure how to make since it curves in two directions with a raised center, but I basically started by remembering that the only things you can do to shape metal are to shrink, stretch, and bend... so I tried to use logic and think what would happen to the metal if I stretched this spot, or shrunk that spot and it pretty much worked out into the mostly correct shape.
After most of the rough shaping was done.
Sharpening the edge of the raised area using a corner of the steel block.
Trimmed and tacked into place... noticed the hammer marks, I'll explain these later, but after tacking there was still a bit of shaping to get this to fit the contours of the dash.
This angle shows that I wasn't able to get the shape of the filler piece to match the dash contour 100%, and I kind of gave up after not being able to add more shape to the mostly finished piece. My reasoning for going ahead and tacking it in place anyway was that I could use a dolly that matched the shape of the dash and finish shaping that area of the filler piece once it was held in place... and it worked. After planishing the two panels into a blended shape I finished welding the panel in and smoothed the welds.
Half and half, this shows how far apart the initial tacks were.
Bolt head stuck in the lathe and dimpled in the center so I could scribe a circle to trim out.
And finished.
Old 11-18-2020, 12:23 AM   #147
mongocanfly
ok...now your just showing off..!!!!...haha...unbelievable...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 11-18-2020, 09:21 AM   #148
Ol Blue K20
X2, it looks great!
Dale
Old 11-18-2020, 10:25 AM   #149
67ChevyRedneck
Jesse James
Project "On a Dime"
Old 12-23-2020, 12:19 PM   #150
theastronaut
X2, it looks great!
Thanks!!
The next step was to finish the dash- shaving the glovebox/ashtray/radio and making vent bumps.
Decided to use the centerline of the defrost vents to locate the two A/C vents in the middle of the dash panel. I messed up and didn't consider that there would be A/C vents added when I originally cut the blank dash panel so part of the vent bump was off the edge of the new panel.
Reference on how much the bumps needed to be raised.
Roughed out with a mallet and sand bag.
The table on the new bandsaw had the same radius as the dash panel so I used it and a chisel end hammer to sharpen up the edge of the bump.
Corner vent bump.. lots of shape to fit a bump around.
I cheated and cut a few reliefs in what would end up as the vent opening to help the surrounding metal flatten out easier.
The finished dash.
