02-05-2021, 12:33 PM | #1 |
Fuse Box
Does anyone have a list of what blades in the fuse box are hot all the time and which ones are hot with key on? Also which are fused? Could fiqure this out if I had power going to the fuses at this time. As always any help is appriciated.
02-05-2021, 02:54 PM | #2 |
Re: Fuse Box
The first tool you'll need when doing electrical work is a wiring diagram. It will answer most of your questions. If you don't have one, go here and download the proper one for your vehicle..
http://67-72chevytrucks.com/vboard/s...d.php?t=185856 |
02-05-2021, 02:59 PM | #3 | |
Re: Fuse Box
02-05-2021, 08:53 PM | #4 | |
Old member
Re: Fuse Box
If we knew what year truck you had would be very helpful seeing how there are many, many types of GM, GMC trucks out there.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
02-05-2021, 10:00 PM | #5 |
Re: Fuse Box
02-05-2021, 11:05 PM | #6 | |
Re: Fuse Box
02-06-2021, 11:30 AM | #7 |
Old member
Re: Fuse Box
This is what you should have.
02-10-2021, 02:31 PM | #8 |
Re: Fuse Box
