Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-07-2021, 02:40 PM   #1
oneperfectrun
oneperfectrun's Avatar
How wide on rear wheel?
What’s the widest rear wheel I can run? Truck has 8” GM rally’s now with 4” backspace. 10” possible with 5” back spacing? I’m looking to mount and run 275 M/T drag radials. Truck is all factory including wheel tubs.
Jeff
oneperfectrun is offline   Reply With Quote
Old 02-07-2021, 09:20 PM   #2
HAULIN' IT
Re: How wide on rear wheel?
Those should fit fine on the wheels you have now. They are just a bit over 11" total width. You should end up with nearly a couple inches on each side. Lorne
HAULIN' IT is offline   Reply With Quote
Old 02-07-2021, 10:12 PM   #3
oneperfectrun
Thanks for the info. I’m wanting to buy two extra wheels to mount the drag radials on and swap out at the track. Planning on driving on regular tires to the strip.
Jeff
Old 02-09-2021, 06:21 PM   #4
SCOTI
SCOTI's Avatar
10" w/5"bs should work fine. That can easily be verified w/your current combo by putting something 1" thick on the inside of the current wheel/tire & 1" on the outboard side. Rotate the wheels w/it on jack stands & look for any issues.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-24-2021, 02:56 PM   #5
I_Wanna_Go_Fast
I have 15x12 Weld alumastars on my 72 with Mickey Thompson 29x15.5x15's.
With the stock wheel tubs they just barely rubbed, Didn't trust it to run it down the track so I sprung for the +4" wheel tubs ($179/pair scratch and dent from jegs), oddly enough they were not scratched or dented. Other than being the wrong color - they were perfect.
After the tubs went on there is more than enough room to tuck the 18.5" wide sportsman's and still have room to party!
I_Wanna_Go_Fast is offline   Reply With Quote
