Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 07-21-2021, 11:47 AM   #1
brian1115
Help with Retrosound
Trying to put a Retrosound system in my truck. The wiring diagram shows 4 speaker outputs. 2 for the front and 2 for the rear.
I have 5 speakers going into the truck though, 2 small at the dash, 1 center dash which is a DVC (dual voice coil), and 2 rear corners.
I was thinking about using 1 channel to power the two small fronts. Run the rears separate and use the last one to wire the DVC in series.
Is this correct?
1986 Chevy Fleetside Wrangler (Canadian Only)
brian1115 is offline   Reply With Quote
Old 07-21-2021, 07:40 PM   #2
dmjlambert
dmjlambert's Avatar
Re: Help with Retrosound
Do you know what the retrosound manual says about the number of ohms the speakers should be? And do you know the ohms of each of your speakers?
Old 07-22-2021, 07:51 AM   #3
brian1115
Each speaker is 4ohms. I contacted retro sound and they said that I needed an external amp to use more than 4 speakers so I got one.
Old 07-22-2021, 07:59 AM   #4
dmjlambert
dmjlambert's Avatar
It sounds like your all set then. I think the dual voice coil speaker can be used as if it is 2 speakers, so you really have 6 speakers as far as the radio and amp know.
Old 07-22-2021, 08:41 AM   #5
brian1115
yeah, the amp was is an easy way to solve the problem lol
Old 02-15-2022, 07:41 AM   #6
Speedracer39
Speedracer39's Avatar
I have been looking at the retrosound radio and was wondering if your happy with yours and how well the sound is?
Speedracer39 is offline   Reply With Quote
Old 02-18-2022, 07:03 AM   #7
brian1115
It is great! Sounds good and I have no problems with the system. I'm not someone who is super into sound or anything just need something to listen to when on long drives. No problems so far
