Old 05-15-2022, 09:47 AM   #1
kmabe
1970 2wd terrible ride quality
I have converted a 70 4wd to a 2wd using a truck frame with trailing arms and 5 in drop coil springs I used the same shocks that I have always used on trucks with the same drop but they bottomed out so I ordered 5.5 in drop shocks now it seems as though it has no schoks just goes bouncing along. What shocks is everyone using
kmabe is offline   Reply With Quote
Old 05-15-2022, 12:33 PM   #2
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: 1970 2wd terrible ride quality
Moved to general K5 message board for more eyeballs.
Old 05-15-2022, 05:18 PM   #3
amashal
amashal's Avatar
I’m using kyb part #344055. Mine is bagged but ride height is probably equal to about a 5” drop. They don’t bottom out and ride quality is good to great.
amashal is offline   Reply With Quote
Old 05-15-2022, 11:09 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Did you add the shock relocators and adjustable panhard bar?
Trim the bump stops or remove them?
Keith
Convert to disc brakes.
Old 05-17-2022, 06:07 AM   #5
kmabe
I did relocate the shock brackets and c notched the frame installed adjustable panhard and extended it to the trailing arm mounting bracket this is what I do to all the trucks I have done and have had great results just not on the blazer
