08-26-2022, 08:02 PM | #1 |
Uncommon option K43 and Q20
I came across this C30 9 foot stepside for sale on the side of the road. An uncommon truck anyway, but the had a couple of SPID codes I hadn't seen before.
K43 - Poly-wrap air cleaner (I assume it's not the dyer hose induction system it's currently running) Q20 - 6.00 x 2.00 Spare Wheel Any examples of these options out there that are still in place?
Dave R. 1972 K20 1972 C20 Highlander 1967 C10 |
08-26-2022, 08:07 PM | #2 |
Re: Uncommon option K43 and Q20
I have never seen that before
08-26-2022, 09:56 PM | #3 |
Who Changed This?
Maybe it had 16" split wheels from the factory? 5" wide sure seems skinny for a 1T wheel, though.
08-26-2022, 10:19 PM | #4 |
Those stepside fender protectors are pretty cool, I would keep them if it was my truck. A white truck with black interior, I assume it was a fleet of some kind.
I have a truck with the K43 code, unfortunately the air cleaner and the rest of the engine are gone, though. What I could find indicated that it was some kind of replacement for the oil bath air cleaner, ie it was meant for dusty roads and conditions. http://67-72chevytrucks.com/vboard/s...d.php?t=653901
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
08-27-2022, 09:44 PM | #5 |
I thought the fender protector setup was pretty cool too for a working truck.
08-28-2022, 01:40 AM | #6 | |
The ''Poly Wrap Air Cleaner'' would be some kind of foam band that encircles the paper element for extreme dust environments. K&N sold a similar band for their air cleaners, too. 16 x 5 is not an unusual rim size for that period. My '68 C/10 Stepside specified 17.5 x 5.25 6-lug rims. WTF is a ''Bulldog Transmission?'' SM465 maybe?
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 08-28-2022 at 03:05 AM. |
08-28-2022, 04:24 PM | #7 |
Yep, the foam band over the paper element and a spare wheel w/o tire.
08-28-2022, 09:49 PM | #8 |
Yes, bulldog is referring to first gear in an SM465 or similar tranny with a very low first gear. A pretty common term in these parts.
08-28-2022, 09:54 PM | #9 |
In the West, it's a Granny Gear.
08-29-2022, 01:59 AM | #10 |
Location: Herculaneum MO (20 minutes south of St. Louis
It is in the Midwest as well. We always called it a granny low 4 speed. To me that told you it was a truck transmission as opposed to a car 4 speed.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
08-29-2022, 07:04 AM | #11 |
Granny or creeper gear here, but I'd get it if someone said bulldog gear. I guess I also hear the grunt gear, or tractor gear, too. It was many years later and they started labeling the shift knobs as L-1-2-3 so people new to the truck world would know to not start out in granny all the time (is my guess). So now you get people calling 1st low and second 1st and there is confusion for some whether it's a 3spd or a 4spd. There are owner manuals. Why not just instruct to use 2nd to start out unless extra pull is needed and leave the shift patter labeling alone?
08-29-2022, 08:13 AM | #12 |
Who Changed This?
I learned that as "compound" low, as a kid. That seems to be more used with two gear boxes in one vehicle, though.
08-29-2022, 10:35 PM | #13 |
That motor is a late 70’s long water pump small block so who knows what else is changed in that engine compartment.
08-30-2022, 04:31 PM | #14 |
Who's got steelies?
Seems from the vin that this truck started life as a straight 6 and SM465, since there is no RPO's for trans or engine. So it was probably a 250-6 and 4-spd.
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
08-30-2022, 06:09 PM | #15 | |
SM465 would be listed as M20.
