Old 02-01-2023, 10:36 AM   #101
dsraven
Re: My new Beater 1959 GMC
just admiring the underhood area of the last post and noticed the pass side upper control arm pivot shaft looks to be mocked up at an angle to the frame. when alignment is done that could change a bunch. that change may mess with the axle centreline so the wheel may move forward some if that control arm pivot shaft is set up to be more parallel to the frame. hope it doesn't mess up your wheel fitment in the fender opening.
Old 02-02-2023, 12:10 AM   #102
hardwaa
hardwaa's Avatar
hardwaa is offline   Reply With Quote
Old 02-02-2023, 12:23 AM   #103
hardwaa
hardwaa's Avatar
Love it.
You got that front wheel in the perfect position.
I see that done wrong SO MANY times.
Engine and wheel/tire choice is spot on.
Thanks for the compliments. Just having FUN!
Old 02-02-2023, 12:31 AM   #104
hardwaa
hardwaa's Avatar
Originally Posted by 57tailgater View Post
Oh my love the white headers!! What did you paint them with?
Cheap and easy. Won’t last forever, figure it’s easy to pull headers and repaint them.
Old 02-02-2023, 12:32 AM   #105
hardwaa
hardwaa's Avatar
Old 02-02-2023, 12:36 AM   #106
hardwaa
hardwaa's Avatar
curious to see how the steering shaft fits through the header tunnel.
engine and headers look awesome. where will the exhaust dump out when you're all done?
Sorry to let you down, it fits just fine. You are turning into a BOZO…
Old 02-02-2023, 10:31 AM   #107
dsraven
ok, thanks for the tip. you're awesome.
Old 02-02-2023, 10:34 AM   #108
Rickysnickers
I'm hoping this was meant as a joke. Even if it was, there's no call for this. Back on topic. Consider this a warning.
Old 02-02-2023, 01:28 PM   #109
57tailgater
And you can cook with it too! Ha ha!! Thanks. Keep it going!
57tailgater is offline   Reply With Quote
Old 02-06-2023, 05:36 AM   #110
hardwaa
hardwaa's Avatar
Stripped the 59 rear frame hangers and overload spring stops. Next I took squarebody frame rails I had removed all the crossmembers. I removed the lower lip of the squarebody frame sections so I could clamp them on my 1959 frame. The square body frame sections are just templates and allow me to locate the rear axle location. Once I’m happy with wheel in fender placement I can center punch frame through the leaf spring bracket holes. I removed 2 rivets from each bracket. The square body frame rails will be removed and I will bolt the squarebody leaf spring perches to the 59 frame.
Truck is on its own four wheels. Rear end will definitely be coming down lots. Way to much rake.
Old 02-06-2023, 01:07 PM   #111
lolife99
67-72 parts collector,…
lolife99's Avatar
Great progress!
Using the squarebody frame rails very cool.
Never seen that before to locate leaf spring perches.
Keith
Convert to disc brakes.
Old 02-06-2023, 02:00 PM   #112
57tailgater
Nifty idea on using the square body rails for templates. Does the square body setup still give you enough fender clearance? You planning on getting a GMC hood to go with that Chevy front end? I always thought they were cool with that opening on the front.
Old 02-09-2023, 11:54 PM   #113
hardwaa
hardwaa's Avatar
Yes, frame is 34” outside dim. Springs and hangers add about 6” each side. Inside dimension of bedsides is 50”
I have a 56 chevy hood for truck.
Old 02-09-2023, 11:55 PM   #114
hardwaa
hardwaa's Avatar
Finally got bed on. Rear axle will need to move back towards rear of truck. Can’t wait to get notches in and rear of truck lower.
Old 02-10-2023, 12:38 AM   #115
hardwaa
hardwaa's Avatar
Pics.
Old 02-10-2023, 02:20 AM   #116
lolife99
lolife99's Avatar
Are those 52” or 56” leaf springs?
If they are 56” you could possibly turn them around and offset the rear axle to the rear.
Keith
Old 02-10-2023, 12:50 PM   #117
57tailgater
What size tires are you running on the back?
Old 02-10-2023, 01:05 PM   #118
hardwaa
hardwaa's Avatar
That’s a good idea.
Old 02-10-2023, 01:05 PM   #119
hardwaa
hardwaa's Avatar
31 10.50 15.
Old 02-10-2023, 02:12 PM   #120
6DoF
6DoF's Avatar
this is turning into a great mix of beater and not beater.
6DoF is offline   Reply With Quote
Old 02-10-2023, 04:37 PM   #121
57tailgater
31 10.50 15.
Thanks! I really like the stance the way it is as I am a rake guy. But hey, do what YOU want to do! Enjoy!!
Old 02-12-2023, 02:11 PM   #122
hardwaa
hardwaa's Avatar
Ended up 2” back from initial guess. Really easy to slide rear square frame rails after I jacked up rear of 59 frame and released all the clamps on the squarebody frame rails. Frame notches will get cut this week hopefully I can get them installed next weekend along with squarebody perches mounted directly to 59 frame.
Old 02-17-2023, 09:03 AM   #123
6DoF
6DoF's Avatar
that stance is MEAN
Old 02-19-2023, 06:02 AM   #124
hardwaa
hardwaa's Avatar
Progress. Laying it all out.
Old 02-19-2023, 06:07 AM   #125
hardwaa
hardwaa's Avatar
Let’s try this again. Now that I found location (front to back) for rear axle time to move it up.
