Old 05-20-2023, 11:28 AM   #1
SacramentoJoe
Always Fixing Things
SacramentoJoe's Avatar
Clutch Chatter and Oil Leaks
I'm going after a repair for clutch chatter and I think I should apply for the gunkiest engine award. Even after de-greasing and pressure washing, it seems as if I barely made a dent.
I got the flywheel off and I was going to pull the oil pan and start replacing gaskets.
Can I slide the oil pan out without jacking the engine or will it still hit the front crossmember? I already have the rear mounts removed, I was concerned about pulling the front mounts since, I will need to support the engine on a jack.
Just an Average Joe
‘68 GMC 307 3spd – My dad's original truck
310,000 miles
SacramentoJoe is offline   Reply With Quote
Old 05-20-2023, 02:15 PM   #2
MySons68C20
MySons68C20's Avatar
Re: Clutch Chatter and Oil Leaks
I replaced a rear main seal 40+ years ago on my old 68 with a 307 without having to iirc.
MySons68C20 is offline   Reply With Quote
Old 05-20-2023, 03:47 PM   #3
samert111
samert111's Avatar
You may have to rotate the crankshaft some to position the crankshaft counter balance weights on the front cylinders out of the way to give the front of the oil pan lip enough room to clear them.
samert111 is offline   Reply With Quote
Old 05-20-2023, 07:16 PM   #4
72SB
IIRC when crank is turned to #6 TDC the cheeks are in their highest position. IDK though if there is enough clearance to get pan off without raising engine a few inches though
72SB is offline   Reply With Quote
Old 05-20-2023, 08:43 PM   #5
SacramentoJoe
It fell right out. There seemed to be plenty of clearance.
Still got a lot to clean-up. I almost need a chisel to get through some of this stuff.
Hopefully I can get some paint to stick.
Just an Average Joe
310,000 miles
Old 05-20-2023, 08:59 PM   #6
geezer#99
geezer#99's Avatar
Get a wire wheel for your drill.
And use a safety shield if you do.
https://www.ebay.ca/itm/134501605121
Old 05-20-2023, 08:59 PM   #7
72c20customcamper
72c20customcamper's Avatar
I used Ezoff oven cleaner the old stuff not the new nice smelling stuff . If you leave it on long enough the paint comes off too .
Degrease it enough the paint will stick .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 05-20-2023, 10:00 PM   #8
SacramentoJoe
I got the crankshaft rear oil seal out. I have never done it before. I was always scared to unbolt the bearing cap. I had trouble getting the seal to push out. My son gave me some needle nose pliers and said to try to wiggle it, and that did the job.
Just an Average Joe
310,000 miles
Old 05-20-2023, 10:03 PM   #9
SacramentoJoe
I think I spent more time cleaning parts than I spent wrenching.
Now, I just need to get the transmission pilot bushing out so I can put things back together. I remember last time, I packed it with grease and hit it with a rod, but I can't find any tool. It seemed like it was something common. Any ideas?
Just an Average Joe
310,000 miles
Old 05-20-2023, 11:00 PM   #10
geezer#99
geezer#99's Avatar
Wood dowel works.
Old 05-20-2023, 11:40 PM   #11
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Might try this method of using a bolt and a nut with a screwdriver. https://www.bing.com/videos/search?q...tail&FORM=VIRE A Dremel or a die grinder can be used to cut the bushing. Sometimes a slide hammer with a hook will pull them.
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 05-20-2023, 11:49 PM   #12
RustyPile
RustyPile's Avatar
I always use my Lisle clutch alignment tool.. Fill the bearing with grease and tap it out.. I put a washer under the pilot "plug" and use the tool to drive the new bearing in place.
https://www.lislecorp.com/specialty-...alignment-tool
RustyPile is offline   Reply With Quote
Old 05-21-2023, 06:11 AM   #13
HalfBrit
If you happen to have a slide hammer, this works well.
https://www.summitracing.com/parts/o...RoCQkIQAvD_BwE
HalfBrit is offline   Reply With Quote
Old 05-21-2023, 08:51 AM   #14
samert111
samert111's Avatar
That bearing looks like its worn into the copper base material.
Might as well change the bearings while your into it this far.
Old 05-21-2023, 09:03 AM   #15
72SB
Autozone Loan-a-Tool has a Blind Hole puller. #27128 Very easy to use to remove pilot bushing. Use a short piece of wood closed dowel to pond in new one.
Old 05-21-2023, 11:26 AM   #16
SacramentoJoe
Yeah, that's why I posted that picture. I really scared of trying to replace the bearing. The bottom end has around 150k miles since it was rebuilt. I want another 50k
The deeper I dig......
The harder it is to see the bottom.
Just an Average Joe
310,000 miles
Old 05-21-2023, 12:59 PM   #17
samert111
samert111's Avatar
It's easy, just like the upper part of the seal. Use something like a thin plastic scraper to tap on the side without the retaining tang and rotate them out. If they are standard bearings they should have it stamped on the back side of the bearing insert and buy the same thing. Lube up the wear surface on the new bearings with some engine assy lube and rotate the new upper in place until the ends are flush with the mounting surface and the bearing cap will seat them in place when you torque the cap bolts down. Just make sure you start the end without the retaining tang first. The hardest one will be that rear one you already have off since it's the thrust bearing.
Old 05-21-2023, 03:32 PM   #18
Steeveedee
Who Changed This?
Steeveedee's Avatar
I've done this by loosening the main cap bolts first to give a better path for the shell to roll out. Be prepared to get lots of oil on you and your clothes...
~Steven
Simi Valley, CA
Old 05-21-2023, 06:44 PM   #19
SacramentoJoe
I decided to put everything back together without replacing the bearing. But didn't get very far as I just broke the cap bolt when while torqueing it down.
Sigh...
Just an Average Joe
310,000 miles
Old 05-21-2023, 07:36 PM   #20
Steeveedee
Who Changed This?
Steeveedee's Avatar
Bummer! Take the other cap bolt out and see if enough bolt is sticking out to where you can turn it with needle-nose pliers, or something. What were you torquing it to?
~Steven
Simi Valley, CA
Old 05-21-2023, 09:04 PM   #21
SacramentoJoe
My book says 115. I was at around 100 ft-lb, but it felt like more than than that. I am going to calibrate my wrench.
Just an Average Joe
310,000 miles
Old 05-21-2023, 09:06 PM   #22
SacramentoJoe
It was buried in the block but I was able to get the other half of the blot to bite back into it and ease it out.
Just an Average Joe
310,000 miles
Old 05-21-2023, 09:47 PM   #23
Steeveedee
Who Changed This?
Steeveedee's Avatar
^Niiice! One thing to note about torquing fasteners. The face of the bolt/nut should be dry for development of proper torque. Threads at the factory were solvent-wetted, and there was no lube between the bolt/nut and their faying surfaces. I know people who lube those faces, but the tension on the bolts is WAY more than spec when that is done.
~Steven
Simi Valley, CA
Old 05-21-2023, 10:05 PM   #24
SacramentoJoe
Anyone know where I can find a replacement bolt?
Just an Average Joe
310,000 miles
Old 05-21-2023, 11:14 PM   #25
Steeveedee
Who Changed This?
Steeveedee's Avatar
I'm drawing a blank on the grade of those bolts. How many marks are on the head? You may be able to find one at your local hardware store.
~Steven
Simi Valley, CA
