Old 08-18-2023, 09:15 PM   #1
speedwrench44
cruise on L83 swap
67 Suburban with 2018 L83, 4l60E trans, trans X controller, dual air. Runs good, 20 mpg cruising 70-75 with AC on.
Problem: Dakota Digital Cruse control works but surges and hunts. DD not any help, last suggestion was have the accelerator reprogrammed. I would have tried that if I could find anyone in South Texas that had a clue what that is. Anyone had this problem and found a cure?
speedwrench44 is offline   Reply With Quote
Old 09-05-2023, 10:28 PM   #2
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Re: cruise on L83 swap
Ive never heard about programming the accelerator pedal... the pedal is nothing more than a potentiometer... Another member here had rosta or rastra .. probably spelled it wrong, but he had that setup on his swap. Im sure a search will turn up his post... I dont know why after market just seems to suck when it comes to simple solutions like this.
on hptuners site someone ran the OEM bcm + brake pedal sensor and cruise switch and said it worked aswell.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 09-06-2023, 09:12 AM   #3
Joyridin
I have it on my L83. I think what they are saying is changing the way the gas pedal reacts. GM has tendency to make their pedals very touchy with the pedal coming on pretty fast. On the stock ECM, you can change how the pedal reacts so it only opens X amount at 10% pedal etc. The guy that tuned my truck adjusted the pedal, but I am not sure what he did. It seems to work a lot better now especially on smooth flat roads.
Joyridin is offline   Reply With Quote
Old 09-09-2023, 07:14 AM   #4
speedwrench44
Thanks, that seems to be what I need, only problem is down here is is finding a tuner that doesn't look at you like a chicken watching a card trick when you try to explain what you want
Old 09-09-2023, 08:19 AM   #5
Joyridin
I have a guy that can probably do it, but you must have HP Tuners to load the tune into your truck. I am guessing if you had that, you could probably make the adjustment yourself.
Either way, if you want the guys name, drop me a PM.
Old 09-09-2023, 05:56 PM   #6
87chevy.com
interesting..
what pedal did you use with your swap?
Old 09-25-2023, 08:37 AM   #7
speedwrench44
Thanks all, been under the weather last couple weeks, will get back on it soon
