02-04-2024, 03:41 PM | #26 |
Location: 3,018 feet above the SoCal/Mojave Desert region.
Re: Radio options
02-04-2024, 08:27 PM | #27 | |
Re: Radio options
that's the Custom Autosound radio. Brothers sure has a habit of calling stuff their own. I suspect the reason they carry this, and at a discount is the non-bluetooth. If you go directly to Custom Autosound, which I did, they no longer offer non-bluetooth
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass * * * New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus! |
02-04-2024, 10:05 PM | #28 |
Re: Radio options
I had seen that as well. OP hadn't specified if he wanted bluetooth or not, I just seen these had come on sale last week. For a factory looking AM/FMradio it looks better than some of the other renditions and the price isn't horrible for what they seem to go for. A month ago I probably would've picked one up, but I bought an original AM to fill the slot and will be using a bluetooth amp placed elsewhere for sound.
1972 Chevy C-10 Cheyenne Super - Buckets, A/C, "The 17 Year Revival Project" |
02-05-2024, 09:08 AM | #29 |
Re: Radio options
i think id want the bluetooth one but there is one that is non blue tooth but it has a bluetooth reciver that will plug in the back of the radio. so i wonder if that it just as good as one with bluetooth built in?
Greater love hath no man than to lay down his life for a friend. Members i Have met Earl Slick68 1969 Stepside Build thread http://67-72chevytrucks.com/vboard/s...=1#post4253546 Chevy Trucks the longest lasting most dependable trucks on the road |
02-05-2024, 12:15 PM | #30 |
Re: Radio options
Yes. As I described above.
02-05-2024, 02:50 PM | #31 |
Re: Radio options
https://www.classiccarstereos.com/SE...etooth+adapter
here are the two adapters that they offrer for this radio https://www.classiccarstereos.com/19...o-usa-630.html
02-06-2024, 03:19 PM | #32 | |
Re: Radio options
I would have preferred a converted original radio, but the cost was prohibitive at the time, so this was an acceptable alternative considering my needs. The USA-740 can also work with modern speakers where the original radio cannot. |
02-08-2024, 03:17 AM | #33 |
Re: Radio options
I have one of these hidden units to install for 99% of my listening. https://www.memphiscaraudio.com/product/smc2a/ It is kind of like the bluetooth amps mentioned but I can use my own amps and components with it. It can be installed without the hardwire controller if you only want to use your phone. My original working AM/FM will be installed in the dash with the new speaker I purchased.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 02-08-2024 at 03:32 AM. |
02-12-2024, 11:18 PM | #34 |
Re: Radio options
I went with the retro sound slidebar. The previous owners cut the dash. It took me several hours to fix that.
1971 C10 manual cab. 76 4x4 chassis. Cut short frame. Carbureted Blueprint 350, automatic 700r4. ~ James |
02-13-2024, 12:27 AM | #35 |
Re: Radio options
Your dash repair looks great! I am enthused to work on my mangled dash so I can get my radio installed.
02-13-2024, 11:50 AM | #36 |
Re: Radio options
@ K-10 Kansas: Great work! Fixing those kind of issues is really rewarding, you are doing great work, please submit a finished dash pic when you are done!
02-13-2024, 01:31 PM | #37 |
Re: Radio options
i ordered a radio
https://www.classiccarstereos.com/19...o-usa-630.html with free bluetooth adapter and a 15% off coupon
02-13-2024, 02:00 PM | #38 |
Re: Radio options
my 72 was a radio delete so no antenna either. This mas my $300 solution that took maybe 5 min to install using existing screw locations. Yes its loud.
02-13-2024, 02:06 PM | #39 |
Re: Radio options
Thanks Yup, here is before and after. I got a panel from LMC, bought a flux welder, watched a bunch of YouTube videos, practiced with the flux welder, took the flux welder back to the store, bought a mig welder and took my time. I've never done anything like this before. It was great fun!
02-13-2024, 02:29 PM | #40 |
67-72 parts collector,…
Re: Radio options
For anyone doing a repair with a complete spare dash,…
Cut under the dash pad and all the way to the dash cluster and all the way to the glove box. Requires less filler. More disassembly required.
02-13-2024, 03:14 PM | #41 |
Re: Radio options
Hell, why not cut it and make it like you want.
CD player with bluetooth for phone. Cup holder. AC Climate Control. L/R Fuel Switch. The CD is kind of dated now, but I had to weld a previously cut dash to put that in and I can do it again.
'67 GMC 2500, 292, 4spd, AC |
02-13-2024, 08:03 PM | #42 |
Re: Radio options
That is excellent advice!
02-14-2024, 09:59 PM | #43 |
Re: Radio options
I think next time I am going to go with something like this. Might even mount it in the tachometer hole.
https://www.amazon.com/Kicker-46KMC2...2-63e904010ad0 |
02-16-2024, 12:23 AM | #44 |
Re: Radio options
I just converted a stock AM radio to Bluetooth using one of these from Amazon for $18.
ZK-1002L 100Wx2 50W 80W 5.0 power amplifier board I gutted everything from the radio except the two knob assemblies. Then removed the rear section of the volume knobs rheostat, which left a shaft I was able to file to fit the bluetooth volume shaft. Mounted the Amp to the factory case (lining up the shafts to work without binding was the worst part). Tested it with a spare battery and some ancient speakers and sounded good. Took about 4 hours of tinkering.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
02-17-2024, 12:24 AM | #45 |
Re: Radio options
--flipped--
02-17-2024, 11:23 AM | #46 | |
Re: Radio options
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
02-17-2024, 02:21 PM | #47 |
Re: Radio options
Basically started by taking the outer top and bottom metal casing off the radio. They are held on with a bunch of small hex head sheet metal screws. Once those are off, start cutting out the old radio components. You will need a soldering iron to melt out some of the connections between the electronics and case. You basically want to get to the point where all that's left is the two knob assemblies and the push button assembly.
02-17-2024, 02:29 PM | #48 |
Re: Radio options
Next, take out the on/off/volume rheostat knpb assembly. You will.see r small tabs that hold the front and rear parts together. Carefully pry the tabs out, one needs to be heated to release the solder, and pull the two halves apart.
This is the bluetooth Amp I bought off Amazon for $18. You can see the slot in the Amp shaft. Now lightly file the round part of the half circle shaft coming out of the factory on/off/volume rheostat to fit the slot in the Amp volume shaft.
02-17-2024, 02:45 PM | #49 |
Re: Radio options
The Amp comes with a power cord. I then wired a 4 wire connector, similar to a trailer plug, to the speaker outputs.
Then fasten the amp to the radio casing. This was the worst part, trying to get the shafts to line up without binding. I ended up making about a 3/16" wood shim to go between the outer case and the Amp. Then made a 3/4" sheetmetal strap to fasten it to the case. Then just put the upper and lower casings back on and wire it in. I did cut out part of the back of the casing for the wires to exit. Overall, I think it took me about 4 hours of tinkering and a total investment of about $25. Obviously, the am radio no longer works, but the original buttons and scrolling tuning knob do still function. And the original on/off/volume knob works as the original, but now controlls the bluetooth.
02-17-2024, 03:24 PM | #50 |
Re: Radio options
Thanks. I ordered one . I think I will try this too.
