04-24-2010, 06:57 PM | #1 |
mini truck racer
New project
1987 S-10 will be Forged 385 , TH350 , 9" Ford caltracs truck on 275 / 60 / 15 drag radial .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
04-24-2010, 09:23 PM | #2 |
Re: New project
I thought we had talked you into a full size truck.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
04-24-2010, 11:05 PM | #3 |
60-66 Nut
Re: New project
Cool....Are you going to have a build thread?
04-24-2010, 11:31 PM | #4 |
mini truck racer
Re: New project
Yea , i just couldn't do it . I am not funded for making alot of power so i have to be light .
I will put together a build thread . This will be my forged 383 set up with 150 in the fogger and 150 in the plate to start with .
04-25-2010, 09:55 AM | #5 |
Re: New project
I dont care if it's full sized or not. Nice project
Shawn
Shawn 85 SWB 7.39 @ 93 Best so far with 0 tuning Lesson in life: Never fry bacon naked! Last edited by shawnt; 04-25-2010 at 09:59 AM. |
04-29-2010, 05:07 PM | #6 |
mini truck racer
Re: New project
Found out last night that the block needed 2 sleexes at .030 and 1 at .040 . I spent $670 on SRP pro series pistons , so 2 sleeves it is . I m also dropping off the cam for clearencing tomorrow . Crower sportsman rods and eagle lightweight 4340 crank all balanced . My neighbor came over yesterday and ask if i would help him haul off an old transmission . Turns out it is a 73' TH 350 out of his truck . He had the dealership rebuild it and the service tech talked him into a 700r4 swap and did it as a side job . Turns out the trans has only been sitting 3 years and has low miles . I'll shoot some pics of the current state of the motor and try and update .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 Last edited by hotrod 80; 04-29-2010 at 05:13 PM. |
04-29-2010, 05:36 PM | #7 |
Under Construction
Re: New project
looking forward to the updates....
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
04-30-2010, 12:34 AM | #8 |
Re: New project
wouldn't it be much cheaper to find another block?
05-01-2010, 10:08 AM | #9 |
mini truck racer
Re: New project
Well i ask about that . The yard i got the block from doesn't have anymore 4 bolts and they only exchange . I would have to drop back to a 2 bolt main . I made 484 with this top end on a 355 . I don't expect alot more HP , but more torque and the assembly should handle 800 HP . So close to 500 on motor and 250 more nitrous , i need a 4 bolt . My machinist ( a good friend and a high school buddy ) has assured me i will never know it is there and i have run his sleeves before with no problems . Oh , and there is no S-10 build section so i put it here . Hope you don't mind as my primary purpose is to drag race it .
Visual update for saturday .Sorry for the crappy pick of the block it was in the bore machine . Pics of the lightweight forged crank and JE pro series pistons .
05-01-2010, 10:36 AM | #10 |
Re: New project
Having a good buddy as a machinist, could have got a 2bolt and had him splay it. Would be better then any stock 4bolt. What ever happened to that 396 you built?
69 c-10 BBC 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build. |
05-01-2010, 01:21 PM | #11 | |
mini truck racer
Re: New project
I sold the 396 with the Luv . The guys that bought the truck are strictly grudge racers so im hesitant to discuss it as it is their race program now . I will tell you that is runs good and is out of the Houston area . The truck has been repainted as the new owners have a body shop . They just bought a proven combo with all my notes and repainted it and showed up in a different area as unknowns .
05-01-2010, 06:29 PM | #12 |
Re: New project
Nice, that little thing had to be a bit scary.
05-02-2010, 10:40 PM | #13 |
mini truck racer
Re: New project
It would move around due to the short wheelbase , but i think it made me better as a driver . The truck really reacted to "jerk shift" and the break over point or point of no return ( when sideways) was quicker than a longer truck . Tire pressure was pretty critical as sidewall flex was important . The truck didn't have power steering so you either had to man handle it , chop it ONCE , or lift . Most of the time i would just make the shift and the loss of torque would bring it back in line even if i shifted early . It was a fun truck .
Got the new rim combo on the gray truck today and did a suspention lookover .
05-08-2010, 12:05 AM | #14 |
mini truck racer
Re: New project
I ended up listing the old body for my golf cart on Craigslist and the guy who is to replace the ends on my 9" shows up to buy it . Well a little horse trading and he is going to replace the ends on one housing and narrow another housing for the golf cart body .
Ordered the converter and dropped of the trans local for a rebuild . Here's a link to the converter . Hoping i didn't go to tight , but still street worthy . http://transmission-specialties.com/...products_id=56 Also looking for opinions on this companies converters . Going parts hunting tommorow also .
05-11-2010, 09:38 PM | #15 |
mini truck racer
Re: New project
Sleeves are in and its ready for final hone . Also took a picture of the rods .
05-25-2010, 06:20 AM | #16 |
mini truck racer
Re: New project
My Machinist called me this afternoon and told me he just knocked the last piston in it . I usually assemble them ( motors) , but i think He's pretty proud of this one . This is one of the best pieces i have ever built . He said the deck was so far off his machine couldn't cut it . It was .018 in the front and .031 in the rear . It's zero now . Told me bring the rest of the stuff and we'll finish it up sometime this week . Matt called me this afternoon and told me Kenny Hubbard (another local all around good guy) is ready to build the trans , so i gotta haul that to him coming up . Been working on small stuff like pre plan for radiator . Researching the A/C parts needed to convert to 134A . Also got all the stuff together to build Rick's center section . Looking like i will have some time next week to relax and get busy . This type of work is relaxing and gives me a sense of acomplishment .
05-25-2010, 07:14 AM | #17 |
Re: New project
you are putting air on the race truck?
05-25-2010, 09:09 AM | #18 |
mini truck racer
Re: New project
Yea , it has air , so im keeping it . It will see some street duty with drag radials and it's light enough those couple of extra pounds won't hurt to much + im getting older . Hopefully i have enough vacuum for power brakes .
05-26-2010, 03:14 AM | #19 |
Re: New project
How much does it weigh?
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs. Best time so far 11.8@XXXMPH |
05-28-2010, 08:16 AM | #20 |
mini truck racer
Re: New project
I will scale it soon and let you know .
06-02-2010, 09:33 PM | #21 |
mini truck racer
Re: New project
Well i got the shortblock back and the timing cover and balancer on . The lifters are in and the oil pump and windage tray should be in tommorow .
06-03-2010, 01:21 AM | #22 |
Re: New project
looks like a fun project, subscribed!
06-03-2010, 09:34 PM | #23 |
Right on the line, baby!
Re: New project
Nice project- looking forward to hearing it. That's my favorite color, grey.
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly Click and scroll down for site vendors! Subscribe here! |
06-11-2010, 07:10 AM | #24 |
mini truck racer
Re: New project
Not much of an update , but a new picture . i welded up the oil pump pickup and installed the pan . Got a new copper washer for the oil plug . The heads are on and torqued . Timing chain cover wasn't my first choice , but i had it and it was new in the box . Hoping to have the intake and valve train buttoned up by the end of the weekend . Headers and mounts should be here soon . Plaining the install the weekend of the 25th .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 Last edited by hotrod 80; 06-11-2010 at 07:11 AM. |
06-11-2010, 11:04 AM | #25 |
Re: New project
Looking good, that thing should be fun to drive.
Tim |
