Old 09-12-2012, 10:44 PM   #1
knomadd
knomadd's Avatar
Knomadd '71 SWB C-10 "Brutus" 6.0L 6l90e swap
Hello to everyone reading this. I've been looking around for a while and have decided to start a build thread. This will be a LONG process, so I hope you'll be patient with me. I've had this truck for a few months now so I'll start off with some "as purchased" pics. This is a very basic '71 SWB C-10 with a 350/350 combo, not the original engine.
*update* Now doing a 2016 6.0L LS based swap with 6 speed auto. Starts here
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 09-12-2012, 10:46 PM   #2
knomadd
knomadd's Avatar
Re: Knomadd '71 SWB C-10
My first mod was new plates.
-Duane
Old 09-12-2012, 10:55 PM   #3
knomadd
knomadd's Avatar
Next was to change the locks and ignition so if there are any copies of the previous keys out there, they won't work. I also ordered an American Auto Wire classic update kit, new gauges with 8K tach and vacuum, and a New Port Engineering wiper motor and intermittent switch (wipers currently don't work).
-Duane
Old 09-12-2012, 11:00 PM   #4
knomadd
knomadd's Avatar
Brown just delivered the latest on the list of things I'll be putting in this winter... I've got a lot to do.
-Duane
Old 09-12-2012, 11:58 PM   #5
Zoomin
Man of Mini-Talents
Zoomin's Avatar
You're off to a great start.
Zoomin is offline   Reply With Quote
Old 09-13-2012, 01:58 AM   #6
cubber
Jeez, I thought that first pic was the after pic.
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 09-14-2012, 11:28 PM   #7
knomadd
knomadd's Avatar
Thanks, I think so.
Thanks for the compliment. The pictures don't show the flaws. Man, there are some flaws. Bad body work on the passenger bedside (maybe more that I haven't found yet) and the paint wasn't done very well. There are bubbles in the paint from (i believe) moisture in the air line during painting. I could keep going, but it is 41 years old so most of the issues are expected. I may be picky because I used to work at a shop when i was in college, but I can see it and it doesn't make me happy. Overall, it's not in bad shape for a driver, but it can be improved quite a bit.
-Duane
Old 09-15-2012, 01:16 PM   #8
scotts72heavyhalf
scotts72heavyhalf's Avatar
Thanks a beautiful truck! Be careful making it so nice thats its no longer a driver takes a bit away from the truck, trust me I have both and I really like my long bed driver the best.
Scotts72C10
scotts72heavyhalf is offline   Reply With Quote
Old 09-15-2012, 01:23 PM   #9
lolife99
67-72 parts collector,…
lolife99's Avatar
nice!
Keith
Convert to disc brakes.
Old 09-16-2012, 12:51 PM   #10
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Nice looking SWB.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-16-2012, 12:56 PM   #11
big_al_71
big_al_71's Avatar
Great looking truck!!!
Keep the picts coming....
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 09-16-2012, 08:23 PM   #12
knomadd
knomadd's Avatar
Thanks for the compliments gents. I was hoping to start the tank swap and rewiring this weekend, but the wife's car broke down on Thursday and had to fix it this weekend. Starter went out on her Honda... had to take apart half the engine compartment to get to it. I had to give her my daily to get around and I drove the truck. Glad I hadn't taken it apart yet.
-Duane
Old 09-16-2012, 08:59 PM   #13
Tinkermc
lookin good welcome to the forum
Tinkermc is offline   Reply With Quote
Old 12-28-2012, 11:19 PM   #14
knomadd
knomadd's Avatar
It's been a while since I've updated. Life gets in the way sometimes. You know how it is....
Santa was good this year, brought me a new steering wheel. I've ordered more parts too, but they're not here yet. I'll post pictures when they show up.
-Duane
Old 12-28-2012, 11:34 PM   #15
knomadd
knomadd's Avatar
I started rewiring. I've got the fuse block mounted in the firewall, and some of the dash harness connected. Waiting on a new steering column from CPP to finish the interior wiring. The wife had foot surgery after thanksgiving, so everything's been on hold while I help her out around the house. Hopefully in a couple weeks I'll be able to get back out in the garage.
-Duane
Old 01-07-2013, 02:11 PM   #16
knomadd
knomadd's Avatar
So I finally had some time to get back on the C10 wiring. I've got the instrument cluster wired and temporarily installed. I still have a long way to go. I just need the time...
Parts on order:
*CPP tilt column (to get shifter off the floor)
*Transmission linkage
*Steering wheel adapter for new Billet Specialties steering wheel
*Carpet (PO cut holes in carpet for shifter bracket, instead of just for bolts)
*Heater Controls (to fill hole in dash and keep wires from grounding out and causing problems until I get Vintage Air - PO removed the heater and all components, including controls)
*Power port and Billet plug form Watson's Street Works (cigarette lighter doesn't work and there aren't any factory knobs in the truck anymore - This allows me to use any knob with proper threads)
*CPP deluxe drop kit (1"/3" springs - already have spindles and 2" blocks - 3.5/5 total drop)
*Temp Sending Unit (for stock gauges - replaced warning light style gauges)
*Hydroboost brake booster
*Fuel line & fittings (to install new tank)
*Hidden hitch kit from ECE
Parts I have that need to be installed:
*Finish rewire
*100 amp alternator
*Fuel Tank (under bed with top filler)
*Bed floor patch (fill holes in bed floor from fuel cell/fuel lines)
*Front Bumper (stock style w/ clear lenses)
*cowl vent trash screens
*Stainless window screens (above window on doors)
*Clean/lubricate/reinstall wiper linkage
*Steering wheel
*Dash knobs (after wiring and reassembly)
*Hood bumpers (side) and adjustable bumpers (front)
-Duane
Old 01-07-2013, 02:18 PM   #17
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Making good headway with this thing. Such a good looking truck!
-Nate
Old 01-08-2013, 10:54 AM   #18
knomadd
knomadd's Avatar
Thank you!
-Duane
Old 01-08-2013, 11:31 AM   #19
67cheby
67cheby
67cheby's Avatar
Beautiful truck ! Looking forward to the updates !
67cheby is offline   Reply With Quote
Old 01-13-2013, 09:17 AM   #20
Hart_Rod
Hart_Rod's Avatar
Sweet truck! I like your upgrades....
Hart_Rod is online now   Reply With Quote
Old 01-13-2013, 11:17 AM   #21
chevy88
chevy88's Avatar
Nice truck to start with.
Kerry
My build thread.
http://67-72chevytrucks.com/vboard/s....php?p=3657823
1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears
1988 Chev Extendacab
2010 Honda VT1300CS Sabre
2005 Buick Rendezvous wife's ride
chevy88 is offline   Reply With Quote
Old 01-13-2013, 09:58 PM   #22
trkfrk
trkfrk's Avatar
Looking good. Keep the pictures coming.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 01-15-2013, 08:47 PM   #23
knomadd
knomadd's Avatar
The big brown truck came today. Unfortunately I couldn't stick around to see what it brought me. I'll post pics of what's inside the boxes later this week, maybe this weekend if I don't clear up my schedule more before.
Sorry about the low quality cell phone pic. I was in a hurry.
-Duane
Old 01-15-2013, 11:27 PM   #24
67cheby
67cheby
67cheby's Avatar
Sweet !
Old 01-16-2013, 10:17 AM   #25
knomadd
knomadd's Avatar
Thanks for the compliments gentlemen. I did get an email last yesterday that said my track bar is still on its way. I guess CPP didn't have it in stock when I ordered my kit.
Oh, and I'm trying to add door jamb switches so my dome and courtesy lights will come on when the door opens. They're being delivered today. Parts stores had switches that were too long... the door wouldn't shut with the one I had. Hopefully the picture isn't a misrepresentation and I'll be getting the shorter switches today. *fingers crossed*
-Duane
