Old 07-06-2014, 04:22 PM   #1
SS Tim
SS Tim's Avatar
Do you have a 1972 Plaid Pickup?
Many people know about the Highlander Plaid seat trim option on both Chevrolet and GMC conventional light trucks.
However in an attempt to reach out to those who don't know I am asking people who are not sure, to please check the trim code/s of their trucks. Often the seat covers have been replaced leaving few clues beyond white door panels (again often changed) and seat belts with black dash pad, column and carpet.
So if you could, please let us know if you have (or just found!) a "Hidden Highlander"
The codes to look for are below.
Also just in case SPID reading is new to you the code may have leading and trailing numbers even letters. Reading between the lines may be needed.
Examples 613, _ 613_ _, 613_ _
As far as the SPID description goes, generally you will see "CUSTOM TRIM COMBINA" or the COLOR followed by "...HIGHLANDER P"
This thread is body style specifc so if you have several different body styles please check the other forums for the specific trim codes as applicable. Not trying to cross post this, just touch with all who may have a Highlander.
On a personal note if anyone has a 519/549/581/480 Dark Yellow with the 618 Orange Plaid please post pictures.
Pickups
Custom Deluxe Z62 mandatory option
Avocado 613
Blue 611
Gray 604
Orange 618
Blazers http://67-72chevytrucks.com/vboard/s...d.php?t=635033
Suburbans http://67-72chevytrucks.com/vboard/s...d.php?t=635035
SS Tim is offline   Reply With Quote
Old 07-06-2014, 06:18 PM   #2
Nitis
Nitis's Avatar
Re: Do you have a 1972 Plaid Pickup?
Ok so my truck was not originally a highlander however I'm a sucker for unusual things. Since the highlander plaid is period correct I am thinking of using it. My truck is 525 light yellow which plaid would it have come with originally I must assume the black grey but that picture looks like it has orange
Also dad's truck is a gmc with ochre? Mustard yellow. Which would be his correct
Nitis is offline   Reply With Quote
Old 07-06-2014, 07:29 PM   #3
SS Tim
SS Tim's Avatar
First off my research is to help validate vehicles not build fakes.
But if you have a 72 Custom Deluxe (as I did) I can see wanting to upgrade a little to the Highlander plaid. As a bonus the Highlanders had black carpet too vs the CDs color coded vinyl mat.
So off we go.
You are correct the 525 Light Yelow truck pictured has the 618 Orange Plaid. GM offered Gray Orange and Avocado Plaid with the Light Yellow. Plus I am sure it could just as well been overide ordered with the Blue too.
On an Ocre truck Gray is the only color I can think of actually seeing offered. But the Avocado would work very well too.
To recap from my Highlander threads.
Highlander Plaid trim codes All included black dash pad, steering column (with or without tilt) and carpet. In addition the door panels, visors, console (Blazer only) and seat belts were always parchment (white). Seat vinyl was also parchment and the insert color is determined by the specific trim code. So the ONLY variable color keyed component was the insert color of the seatcovers.
Old 07-06-2014, 07:34 PM   #4
Nitis
Nitis's Avatar
My 525 yellow truck also had parchment interior. Of course some one along the way painted the visors and door panels black.
Old 07-06-2014, 10:02 PM   #5
72 Highlander
Two photo's of my 72 Dark Olive Highlander, one the SPID and the other the interior. Pretty much all original, except for repaint in original color by previous owner. 1YG820 Special Promotion Package, 161310 Avocado Highlander.
72 Highlander is offline   Reply With Quote
Old 07-06-2014, 10:13 PM   #6
kcsa75
kcsa75's Avatar
The plaid seat is long gone but my truck is a Highlander. I believe it was the YG8 Package with tilt, factory AC, AT, PS, etc. Medium blue and white with the blue plaid seat.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 07-06-2014, 11:11 PM   #7
leh72super1500
GMC with Blue Plaid
leh72super1500's Avatar
1972 GMC Super Custom built in Oshawa. Has the 611 Custom Trim Combination, with black dash pad, black instrument bezel, black steering column, black glove box door, and carpet. A PO has removed the plaid. Now just to decide to go vertical or horizontal with the new plaid cloth. It also has the wood grain lower mouldings. Do you know if that would have been part of the 611 option?
Current:
1972 GMC Super Custom 1500 402 < 73K Orig MI
2015 GMC Canyon SLT(Daily Driver)
Previous:
2008 Chevrolet Colorado LT 2.9L I4
1988 Chevrolet Suburban Silverado 10 350 < 60K Orig MI
1984 GMC S-15 2.8L V6
1976 GMC Sierra Classic 2500 Camper Special 350
1980 GMC High Sierra 3500 Dually 350 4spd
1974 Chevrolet Cheyenne Super 10 Shorty 454 (Was my Dads, I wish I still had it)
1969 GMC 910 250 I6 4spd
leh72super1500 is offline   Reply With Quote
Old 07-07-2014, 01:55 AM   #8
frank69
Tim 72 longbed that I'm parting out. It has yg8 spec promo pkg-c @ a 604 gray plaid seat, but it doesn't say anything about it being a highlander. Are any of the parts more desiable than the standard trim parts . Seat is in pretty bad shape but it's original. Thanks Frank
frank69 is offline   Reply With Quote
Old 07-07-2014, 02:05 AM   #9
SS Tim
SS Tim's Avatar
Thanks for the replies guys, already it is showing former Highlanders and hopefully more can be discovered. Here is a truck that almost didn't catch my eye being a typical blue and white customized truck, then I saw the SPID. It was 549/618 dark yellow and orange, one of my quest combos!
On the lower bodyside moldings. Still trying to sort out the details there. Most trucks have woodgrained trim but some have black even from the same plant. Unfortunately this is going to take a lot more time and highlander build sheets to develop. At this point I say go with what you believe the truck had originally.
Old 07-07-2014, 02:12 AM   #10
Nitis
Nitis's Avatar
So obviously that truck has been painted?
Old 07-07-2014, 02:20 AM   #11
SS Tim
SS Tim's Avatar
Good point, the YG6, YG7 and YG8 codes are for the Promo Package Highlanders that included the Highlander Plaid Trim upgrade with bundled options at a total cost savings.
As to special parts beyond the seat cover there are none. It is a combination of colors that make it a "special" upgrade of the Custom Deluxe trim and of course carpet.
Old 07-07-2014, 02:40 AM   #12
SS Tim
SS Tim's Avatar
Yes, sorry it was Dark Yellow and White in the conventional two-tone (roof only).
Probably half of the Highlanders I find are formers with the plaid long gone! As many SPIDs do not use the word Highlander nor is there any badging its easy for one to slip away.
Old 07-07-2014, 07:33 PM   #13
Mike's money pit
Hey Tim,
We have discussed my 1972 Highlander a few times before. I appreciate your research and in depth knowledge of these cool trucks. Mine is medium red with a white roof. It has the gray plaid seat specified on the SPID. I haven't mentioned it before, but several of the pieces of trim on my truck had woodgrain that had been covered with cheap black tape. A few pieces were painted black so I don't know which were original. My truck did have a woodgrain tailgate band on it when I got it. I don't know of that was original either.
I am sorry to see your dog is still missing. I know how special dogs can be. Best of luck to you, my friend.
Mike
Mike's money pit is offline   Reply With Quote
Old 07-15-2014, 09:16 PM   #14
SS Tim
SS Tim's Avatar
Guys, I know there has to be a lot more Highlanders and Highlander Promo Package trucks out there.
Again if you have a 72 Custom Deluxe (Z62) pickup trim coded:
Avocado 613
Blue 611
Gray 604
Orange 618
Then you have/had a Highlander!
If you also have the SPID code:
YG6
YG7
YG8
Then you have a Promo Package Highlander!
BTW: If you only have a SPID/glovebox door left I'd be interested to see the color combinations and options. So post them up too.
Old 07-15-2014, 10:02 PM   #15
patokik
Hello, I am quite new to forums in general. I have recently acquired a 1972 c-10 custom deluxe highlander. It's got the factory 402, Ac, heavy duty leaf springs etc. If anyone can provide me with any more information on these trucks it would be greatly appreciated.
patokik is offline   Reply With Quote
Old 07-15-2014, 10:05 PM   #16
patokik
Also trying to figure out how to upload pictures from my cell phone
Old 07-15-2014, 10:08 PM   #17
Dirt's72
Tim here's a spid for ya I had saved on my phone from a friends parts truck. Pretty sure the plaid seats are gone. I'll double check next time I'm over there.
Dirt's72 is offline   Reply With Quote
Old 07-15-2014, 10:26 PM   #18
patokik
Yes I do, proud father
Old 07-15-2014, 10:32 PM   #19
patokik
Does anyone have any idea of what the production numbers for these trucks are?
Old 07-15-2014, 10:44 PM   #20
bluek5
bluek5's Avatar
Tim,
Here is another one for you.
Paul
bluek5 is offline   Reply With Quote
Old 07-15-2014, 11:18 PM   #21
75gmc454
75gmc454's Avatar
Here is a truck that I have that has plaid trim but it does not mention any highlander package.
75gmc454 is offline   Reply With Quote
Old 07-16-2014, 12:06 AM   #22
SS Tim
SS Tim's Avatar
So what is the trim code and does it have a YG6, 7 or 8 code as well denoting a Promo Package truck?
If you want Highlander information in general just site search ""ss tim" highlander" there is a lot out there.
Only very general production numbers (basically by model) are released and rife with typos. As far as breaking down trim levels or option content its not there.
Old 07-16-2014, 12:13 AM   #23
SS Tim
SS Tim's Avatar
Thanks, Every little bit helps. Looks have been a nice St Louis built truck in 504 Dark Olive with the 613 Avocado Plaid and loaded up as a Promo Package "B" (YG7) truck.
Old 07-16-2014, 12:21 AM   #24
SS Tim
SS Tim's Avatar
Originally Posted by bluek5 View Post
Tim,
Paul
Very Nice! Sharp looking truck I'm sure.
Old 07-16-2014, 12:33 AM   #25
SS Tim
SS Tim's Avatar
It is a Highlander! Like I mentioned above in a couple of places, the trim code is the key. The 613 code is for the Avocado Plaid Highlander special trim combination. Many SPIDs carry Plaid in the trim description but omit Highlander.
If you compare your SPID to Dirt's72's posted #17 you can see that even though they are both St Louis built trucks they are almost 65,000 units apart and St Louis had lots of running SPID variations.
"ss tim", highlander, plaid
