12-18-2014, 02:18 AM | #1 |
Supercharger for my Apache
After 4 years as my daily driver I have decided that it is time for some more power. The truck has the original 235 in it with a custom built one off fuel injection system built by a good friend named Greg and myself. Greg is an EE and did all of the wiring and computer programing and tuning. He has hacked several of the most popular GM OBD1 computers and is a genius at manipulating and tuning them. I am a mechanic and fabricator from the school of hard knocks and I handle those items.
My neighbor Kris, Greg, and myself recently installed a ZZ4 crate engine with a First Fuel Injection system (not FAST) on Kris's 1972 step side. There is a build thread here at: http://67-72chevytrucks.com/vboard/s...d.php?t=603726 My Apache runs well for a 50+ year old engine and the fuel injection makes the drivability of the truck great compared to the carb., but does little to increase the horsepower. Around town it is great but at freeway speeds it struggles when there is a hill and/or a stiff head wind. Since I live in the land of 75 and 80 MPH (posted) speed limits I want a few more horses to work with. The fuel injection system consists of a vintage Edmunds dual carb manifold with 3 bolt flanges, 2 Retrotek Stromberg lookalike throttle bodies, a Frankenstein Chevy/Ford distributor and ignition system, and various GM and Ford sensors. I did a build thread on the fuel injection system on the Stovebolt Forum. If you are interested it is here: http://www.stovebolt.com/ubbthreads/...=678192&page=1 The engine also has Fenton cast iron manifolds with a custom built stainless steel 2 inch x 1 3/4 exhaust system out the back. The rest of the drivetrain consists of a 1967 Saginaw 3 speed on the column, a Gear Vendors overdrive, the original rear end with 3.90 gears and 31 inch tires. The plan is for a .040 over 261 and a McCullough supercharger. Other engine mods include a 235 cylinder head with some bowl work and clean up of the ports and a mild blower friendly cam. I'm not looking for maximum power. Just enough to get over the next hill. Some might question the decision to use an old McCullough supercharger since there are more efficient units available. It is to stay with the style of the build which is vintage 60's. While I am waiting for the machine shop to finish with my engine I decided to work on the supercharger. It is a VS 57 that needs a total rebuild and conversion to a SN (short nose) unit. Following are some pictures of the process. More to come.
"In an insane world a sane man must appear insane" ~Spock~ |
12-18-2014, 08:19 PM | #2 |
Re: Supercharger for my Apache
Here are some pictures of the truck and the fuel injection.
12-18-2014, 09:08 PM | #3 |
Very interesting & I like where you're going with this ... I'll continue to watch.
R46 |
12-18-2014, 10:08 PM | #4 |
Great friends you guys are. A good team. Read the 72 build thread and enjoyed it.
Tagging along here to learn. Supercharger came out nice and the truck is super cool. |
12-18-2014, 10:23 PM | #5 |
A320 Pilot/USAF Retired
Cool looking truck!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
12-19-2014, 10:30 AM | #6 |
Thanks guys! I'm hoping my supercharger rebuild parts come in today so I can work on it this weekend. Machine work on the engine should be done soon, but with the holidays I won't be able to do much until after the first of the year. Here are some more pictures.
Hank Autographs 20 Indy 500 wins represented (owners and drivers) 2. Bill Neale – Automotive Artist 3. Franz Weis – Crew Chief for Jim Hall – VDS Engines 4. Troy Rogers – Crew Chief for Jim Hall 5. Wesley Sweet – Crew Chief for Jim Hall 6. Dan Davis – Publisher “Victory Lane Magazine” 7. A. J. Foyt 8. Al Unser 9. Dan Gurney 10. Jack Chissenhall – Owner “Vintage Air” 11. Johnny Rutherford 12. Parnelli Jones 13. Peter Brock – Designed Stingray and Daytona Coupe 14. Paul Stewart – Son of Jackie Stewart 15. Doug Nye – English Motoring Journalist 16. Sir Stirling Moss 17. Vic Elford 18. Gil de Ferran 19. Ed Welburn – GM Vice President of Global Design 20. Al Unser Jr 21. Herschel Walker #34 22. Richard Petty 23. Geoff Bodine – Nascar Driver 24. Kyle Petty 25. Rutledge Wood – Television Personality
12-29-2014, 01:55 PM | #7 |
While waiting for my supercharger parts I decided to modify an old turbocharged Corvair air cleaner that I have to use on this project. The plan is to use the high pressure area in front of the windshield for a little extra supercharging and a cool air source. The mods consisted mostly of turning the oval inlet snorkel 90 degrees and giving it a slight angle so the unit can be mounted vertically.
"In an insane world a sane man must appear insane" ~Spock~ Last edited by diceman50; 12-29-2014 at 02:07 PM. |
12-29-2014, 02:04 PM | #8 |
I'm am going to enlarge the outlet to 3 1/2 inches to match the supercharger inlet but, I don't have any tubing that size right now. A few more pictures.
12-29-2014, 08:20 PM | #9 |
Nice work! Interesting...so will the air cleaner snorkel flow air through a passage in the firewall from the vents at base of windshield?
12-29-2014, 08:30 PM | #10 |
This is really cool. Excited to see how it turns out.
12-29-2014, 10:12 PM | #11 |
Thanks, and yes that is the plan. As steep as the windshield is I expect there is quite a bit of pressure in that area. At the very least I should get some nice cool air.
12-30-2014, 11:22 PM | #12 |
More air cleaner mods. Air cleaner originally had an air deflector/baffle/shield which I had to remove when I did the snorkel modification. In doing so I pretty much destroyed it and it needed to be larger anyway.
To make the stand off for the corners I did something I had never tried before. Instead of cutting them into the sheet metal and bending them I cut some 3/8" cold roll rod 3/8" long and spot welded them to the deflector and then to the housing. It worked very well.
12-30-2014, 11:39 PM | #13 |
I couldn't find any 3 1/2" tubing for the outlet locally and I didn't want to buy a 10 foot stick of it anyway. So, I decided to roll my own. I had some 16 gauge hot roll (I would have preferred cold finish) in the pile so that's what I used. I decided a 3" long nipple would work and a little math told me I needed an 11" x 3" piece of material. After cutting and trimming to size I rolled it up with my old Jet slip rolls. Afterwards I welded it about 2/3 of the way on the inside. Past experience told me not to weld where the hose bead is going until last. Then I used my old homemade bead roller to put a bead on it.
12-30-2014, 11:44 PM | #14 |
More pictures.
12-31-2014, 12:00 AM | #15 |
Glad to see you are documenting "Hanks" new heart transplant. I'm off this week so let me know if you need a hand or if you need me to break open a can of Nyalic or Rustoleum.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
12-31-2014, 12:10 AM | #16 |
Will do. With the weather being so crappy and the roads icy for the next few days I might be able to get quite a bit done instead of running around and goofing off.
01-01-2015, 09:29 PM | #17 |
Finished the air cleaner yesterday. Made a flange to mount the snorkel to the firewall. I had to modify my original design because I couldn't mount it as low as I wanted to.
01-01-2015, 09:34 PM | #18 |
Made a clamp to fit around the outlet tube and a firewall brace to attach to it.
01-01-2015, 10:34 PM | #19 |
I received my supercharger rebuild kit from Craig Conley at Paradise Wheels last week and finally got a little time to work on it today. Paradise Wheels purchased the rights to the McCullough and Paxton superchargers from Paxton Automotive and sells complete Paxton units as well as parts. Craig has been very helpful and quick to respond to my questions. The rebuild kit is high quality very complete and even has new springs for the ball drive plate which I didn't expect.
I also purchase a new improved impeller and a SN type pulley at the same time. I started by replacing the drive springs.
01-02-2015, 11:20 PM | #20 |
Nice work Diceman. Like the aircleaner and mounting system. Will the supercharger pull through or blow through the carbuerator?
01-03-2015, 12:23 AM | #21 |
Thanks AD.
It will blow through, but they are not carburetors they are throttle bodies with Bosch style fuel injectors in them.
01-08-2015, 08:21 PM | #22 |
I finished my supercharger conversion and rebuild today. It was pretty straight forward and without any real surprises. Unfortunately I had a camera malfunction so there aren't many pictures of the actual assembly.
01-08-2015, 10:37 PM | #23 |
Looks really good Diceman. Dumb question, is the housing aluminum? Curious and I've never seen one in person.
01-09-2015, 02:10 AM | #24 |
Looking good my friend.
01-09-2015, 10:58 AM | #25 |
Thanks guys. Yes the housing is aluminum. It weighed 26 lbs. in it's original VS configuration and 19 lbs. after the conversion to a SN. I was amazed at the precision of the castings and the machine work on a 60+ year old piece.
