01-03-2015, 02:34 AM | #1 |
My 86 build
I bought this truck in 2014. The exterior had already been done by the previous owner. The inside was clean, but I can't handle that Burgandy color in a red truck, so I've been working on some projects over the last year. So here's the dash project.
01-03-2015, 02:39 AM | #2 |
Re: 86 Dash Project
After dismanteling the dash, I repainted the lower portion. The red on the ashtray & glovebox didn't match with the rest of the dash.
01-03-2015, 02:43 AM | #3 |
Re: 86 Dash Project
Painted the dash pad Charcoal after removing the burgundy paint. Cleaned all the old dye off with lacquer thinner. I made a little makeshift paint tent in the garage.
01-03-2015, 02:53 AM | #4 |
Re: 86 Dash Project
Installed a new radio & speakers, temp control and a clock. My truck didn't have one. So since I had an empty spot on the meter face, I added an original working clock i found on eBay. I also added led lights in the meter and more courtesy lights along with the BowTie door sills
01-03-2015, 02:58 AM | #5 |
Re: 86 Dash Project
And the finished project. New Billet dash molding & emblem. New dash Bezel, I have the Billet overlay for the dash bezel, but I can't bring myself to cover the new bezel just yet.
01-03-2015, 04:44 AM | #6 |
Diggin The SquareLife
Re: 86 Dash Project
looks real good, are those the door sills from lmc?
01-03-2015, 12:11 PM | #7 |
Re: 86 Dash Project
Yes the door sills are from LMC.
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=73 |
01-03-2015, 11:17 PM | #8 |
Re: 86 Dash Project
Looks great. What other plans do you have for it?
01-03-2015, 11:36 PM | #9 |
Re: 86 Dash Project
I've already painted the doors panels and all the interior trim parts.
01-03-2015, 11:39 PM | #10 |
Re: 86 Dash Project
Recovered the headliner & installed new carpet
01-03-2015, 11:40 PM | #11 |
Re: 86 Dash Project
Here's the headliner pic
01-03-2015, 11:44 PM | #12 |
Re: 86 Dash Project
To complete the interior, recover the bench seat & install the new seatbelts. When the finances are there, I would like to get a new steering column, steering wheel and replace all the column levers.
01-05-2015, 03:36 PM | #13 |
Re: 86 Dash Project
Looking good. I like the color combo you have.
My Chevy habit is paid for by Ford diesels... Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355 Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748 Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974 IG mattcrp1 |
01-06-2015, 04:36 PM | #14 |
Re: 86 Dash Project
You did an awesome job! What did you use for the lower dash?
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
01-06-2015, 04:42 PM | #15 |
Re: 86 Dash Project
Why do you want a new column? Yours appears to be in decent shape, and is tilt.
1973 C20, 350/350 |
01-06-2015, 04:47 PM | #16 | |
Re: 86 Dash Project
That's exactly the same thing the women at my house said. Looked fine to me... Anyway, in deference to their opinion(s) I changed over to a black interior when I went back together. You can see the results in my build/intro thread below if you are interested. Having given it further thought - it's even funnier since the red/burgandy '87 was a direct result of their complaints about my red/tan '86 Suburban. They called it the "Rotten Tomato". I can't win... K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
03-20-2016, 01:39 AM | #17 | |
Re: 86 Dash Project
I opted out of the new steering column, but did install a new steering wheel & turn signal/wiper w/ cruise control stalk. Last edited by TKCR; 03-20-2016 at 02:07 AM. |
03-20-2016, 01:48 AM | #18 |
Re: 86 Dash & Interior Project
Other interior changes:
New seatbelts because of the color change. Ran into a bit of a snag there. The PO had broke the weld nut off one of the belts and cut a hole in the floor to be able to put a nut on the bolt. I wondered why I was having such a hard time getting that bolt out, which I ended up breaking. So I had to do the same, I used the hole to install a nut the bolt for the new bolt. Patched up the hole. Last edited by TKCR; 02-17-2018 at 10:17 AM. |
03-20-2016, 02:01 AM | #19 |
The seat went through a few stages. The truck came with a 90's seat. I had it re-upholstered, but the guy didn't do it right. He did the whole seat with the one material, so I wasn't happy with that. I then searched for a period correct seat, which I found at a local yard for $50 and had someone else re-upholster the seat like the original seats were for the time. This time I got all the material myself and had a pic in hand, so there would be no question on how it was to look.
I had some left over vinyl from the seat and sent it to CruisinCupholders, they made my console with my material. Perfect color match!! |
03-20-2016, 02:15 AM | #20 |
This one is a bit out of order. I did this back when I changed the carpet. I put FatMat down on the floor and re-used the tar mat that was installed at the factory. I followed that up new jute material before installing the new carpet.
03-20-2016, 02:30 AM | #21 |
Then behind the seat, I got a new storage tray like the original trucks had.
http://www.usa1industries.com/1973-8...tool-tray.html I put speaker carpet on it. Since then, I have carpeted the metal speaker brackets and painted the grille covers. I'll have to get photos and post later. |
03-20-2016, 10:07 AM | #22 |
Re: 86 Dash Project
Nice work!
Do you mind sharing your radio and speaker set up? |
03-20-2016, 11:26 AM | #23 |
Re: 86 Dash Project
My stereo is a Custom Autosound, got it from LMC. The only thing I didn't like about the stereo, was the cheap black plastic knobs. The original knobs on the old factory stereo would not fit on the shaft. so I found some later model chrome knobs that did fit. I like those a lot better. They are nice and heavy, and not the plastic.
I also did the A-pillar tweeters. The pillar garnishes come in black, so I dyed/painted to match my interior. http://www.lmctruck.com/icatalog/cc/full.aspx?Page=85 The dash speakers are Kenwood, got them from Brother's. http://www.brotherstrucks.com/85-87-...tinfo/UDDSA87/ The 6x9's in the rear cab were already there from the PO. They work & sound good, so I didn't replace them. |
05-12-2016, 02:48 PM | #24 |
Re: 86 Dash Project
Here is some exterior updates:
Had my vent windows restored by Precision. |
05-12-2016, 02:57 PM | #25 |
Re: 86 Dash Project
All my exterior trim was in great shape, but it needed a good cleaning. Used Brasso Polish, and it came out great.
The paint was peeling and faded on the corner trim, so I cleaned all the paint off and repainted the Bowties black. I was able to find a NOS Chevrolet emblem for the tailgate trim. And to add a bit of a cool note ( at least to me ), my dad worked at GM for over 30 yrs. One of his jobs was stamping the tailgate trim. So I like to think that I actually have one on my truck that my dad made. |
