Old 02-16-2016, 10:44 PM   #1
donandal
Plus Five
Well, I am to the point where I can start the build thread for my 53 Chevy pickup.
I'll start with the background info and some goals I have for this project.
I have always liked working with my hands building things, and worked at a tool and die shop
while I worked my way to a flying career. I started a hobby shop back in September of 2001
and have worked on various car and motorcycle projects. My uncles both worked on antique
cars and motorcycles and thought a pickup project would be a good choice.
My uncle found the truck locally, and I bought it and started the tear down in October of 2012.
I had a couple of requirements for the build.
It needs to be reliable, comfortable, and easy to start and drive.
It has to be easy to service with over the counter parts.
It needs to be legal, and as safe as a 60 plus year old truck can be.
It should look nice. It doesn't need to win awards. I am going to
drive it!
Oh, and my wife needs to like it. She will be driving it too!
So here's the thinking;
I was most concerned with the legroom issues in these old trucks. I have
friend who owned a 50 Chevy truck and the steering wheel was in your face
and there was no legroom. The seat back was also too vertical for my taste.
So the cab would need to be lengthened.
The old six banger it had could barely get out of it's own way, and didn't meet
the wife's drivability requirements. An engine swap was in order. New York State
can be pretty picky about inspections ( they recently required an emissions test
for my 2008 build year custom roadster, even though they initially, and for six
years, had issued the inspection as emissions exempt as it was originally
registered. ) so I wanted one with all emissions equipment in case they ever go
that way down the road for this truck. No I don't trust them!
Plus, a computer controlled engine and tranny should be easy to start and drive.
99% of this build up to this point I have done myself. I am not a painter or body
guy. I did paint the chassis and some other parts myself. I asked the painter to
check my work after the major mods were complete. He said the work was fine.
( although he did joke that he could turn my ugly pieces beautiful. ) My brother has
contributed some machining and he has helped with planning and engineering
on some of it...he is a tool and die maker.
The extras here and there I did for fun.
I'll be putting it back together soon and will try to post pictures of the progress
that includes the construction photos as well.
I'll also soon be getting into some areas outside my comfort level, so will be
asking for some help.
Sorry for the long intro, and thanks for reading.
More soon!
53 Chevy Pickup
donandal is offline   Reply With Quote
Old 02-16-2016, 11:37 PM   #2
Big Daddy Bear
Big Daddy Bear's Avatar
Re: Plus Five
Welcome!!
Sounds like an impressive project! Be sure and post lots of pictures, especially of the build process.
No bolt or nut in the world will remain tight if you turn it to liquid!!!
Big Daddy Bear is offline   Reply With Quote
Old 02-17-2016, 12:23 AM   #3
iowaboynca
iowaboynca's Avatar
Re: Plus Five
Good to have goals and think through. Always stick to the scope. I'd recommend start to budget against your goals and if it works stick to it, if not recalibrate then work on it.
Good luck!
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 02-19-2016, 05:23 PM   #4
donandal
Re: Plus Five
this is how it started...
typical rust issues, tore it apart and started planning cab extension
53 Chevy Pickup
Old 02-19-2016, 05:33 PM   #5
donandal
Re: Plus Five
sent the cab out for sand blasting.
had a bunch of bondo, lead, and brazing.
no worries, it will all be fixed
I built a rotisserie for all the work it will need, and to help
with painting the floor later
53 Chevy Pickup
Old 02-19-2016, 05:46 PM   #6
donandal
Re: Plus Five
split the cab into three pieces.
stretched it exactly 5 inches, and widened the rear about 7/8 of an inch.
the cab tapers toward the front, so to keep the extension along the floor
straight, it widened the cab. This actually made extending the rocker panels
and doors pretty straight forward.
53 Chevy Pickup
Old 02-19-2016, 05:55 PM   #7
donandal
Re: Plus Five
made some ribs to hold the curve of the cab roof, and started making the
cab roof pieces
53 Chevy Pickup
Old 02-19-2016, 06:03 PM   #8
donandal
Re: Plus Five
more cab work
53 Chevy Pickup
Old 02-19-2016, 06:11 PM   #9
donandal
Re: Plus Five
reworked the cab corners and firewall
53 Chevy Pickup
Old 02-19-2016, 06:17 PM   #10
donandal
Re: Plus Five
the replacement pieces for this area fit poorly, so I made my own
that will be removable to allow running wiring and A/C drain hose
53 Chevy Pickup
Old 02-19-2016, 06:24 PM   #11
donandal
Re: Plus Five
braced the cab floor to support seats and seat belts
added bracing to the rocker panels and tied in cab mounts
53 Chevy Pickup
Old 02-19-2016, 06:37 PM   #12
pugs
pugs's Avatar
Re: Plus Five
nice work on the cab
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done...
pugs is offline   Reply With Quote
Old 02-19-2016, 06:48 PM   #13
donandal
Re: Plus Five
cab is pretty much done here...
doors will be fit to door openings.
53 Chevy Pickup
Old 02-19-2016, 07:13 PM   #14
donandal
Re: Plus Five
I made cross sections of the various door shapes and extended the
inside five inches also.
I also made an exterior door skin brace for each door.
It anchors the bottom of the door window track also.
The door skin will be separated from the brace with sound deadener
like Dynomat or Fatmat.
The perimeter frame around both removable panels is a boxed
beam structure to better brace the door and the hinge attach areas.
They are removable to allow installing the window and mechanism.
53 Chevy Pickup
Old 02-19-2016, 07:24 PM   #15
donandal
Re: Plus Five
that pretty much covers the cab stretch.
this is whats next for the fenders.....
the stripe is going to be the cut line for a front end
tilt
53 Chevy Pickup
Old 02-19-2016, 08:16 PM   #16
Advanced Design
Advanced Design's Avatar
Re: Plus Five
Impressive metal work donandal! Tagging along for the rest.
Advanced Design is offline   Reply With Quote
Old 02-19-2016, 11:28 PM   #17
youngrodder
youngrodder's Avatar
Re: Plus Five
Great work. Its builds like this that remind me of how awesomely talented a lot of you guys are on this site. Fantastic job so far.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 02-20-2016, 02:52 AM   #18
Chance48
Re: Plus Five
Very nice work! What kind of bead roller do you have? I need a good one.
SHAKE N BAKE BABY, SHAKE N BAKE....
http://67-72chevytrucks.com/vboard/s...d.php?t=686729
Chance48 is offline   Reply With Quote
Old 02-20-2016, 10:25 AM   #19
MIKESAD50
Re: Plus Five
WOW! very nice work. wish I had a small amount of your Fab talent.
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 02-20-2016, 11:04 AM   #20
RockinKees
RockinKees's Avatar
Re: Plus Five
This is some impressive metal work!
Makes me happy, just to look at it!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 02-20-2016, 03:27 PM   #21
Flysocal
Re: Plus Five
Impressed with your metal work. Also like your rotisserie
Flysocal is offline   Reply With Quote
Old 02-20-2016, 03:33 PM   #22
donandal
Re: Plus Five
Thanks everyone,
I stopped by the paint shop today.
The cab is blocked and ready for color. Interior is already
painted the light champagne color I chose.
He sure does make my metal work look nice!
53 Chevy Pickup
Old 02-20-2016, 04:07 PM   #23
donandal
Re: Plus Five
these two indentations were made for the firewall for extra
clearance around the heads.
53 Chevy Pickup
Old 02-20-2016, 06:35 PM   #24
47 Fasttoys
47 Fasttoys's Avatar
Re: Plus Five
Great work on the cab stretch +5, that a lot of work and craftsmanship to say the least. Now for my 2 cent son the tilt front end. I've done 2 of these and don't think I'll do another. My frame was boxed to the transmission cross member with IFS, I still had issues with frame flex which causes issues with clip alignment. One more note, you may want to review the cut pattern you have marked out, it looks like you would have limited access to the rear of the engine do to the point hanging out. Keep us posted truck looks like it will be a quality build.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 02-20-2016, 06:35 PM   #25
donandal
Re: Plus Five
usual cab rust areas were fixed.
I also rebuilt the hinge pockets...the back
bracket is stainless steel sand blasted for paint
should never rust out
53 Chevy Pickup
