![]() ![]() Join Date: Sep 2008
Arkansas K10
No special reason for the title , but we have to have one.
I picked this K10 up in California a while back. It's an original Cheyenne with deluxe paint, but somebody had pulled all the trim and painted it all one color. It is as rust free a truck as I have seen in a long time. It still has the original rockers in place. When I bought it I planned to replace the carpet, seat, headliner and exterior moldings and drive it. I started painting the white and touching up the Ochre and realized the color on the truck was not ochre. The trim was already off the truck, so I might as well paint it. The original paint on the truck was very thin, or non existent. All the black painted parts under the hood and frame had surface rust. So here we go with a frame off. I built a fixture for A body Chevelles years ago, and I adapted it to support the bed while I work on it. Once I get the gas filler holes filled, I will stand the bed up and blast it inside and on the bottom. When I get the bed worked, and in epoxy, I will pull the cab and put it on a rotisserie and strip and paint it.
Re: Arkansas K10
I has begun.
Re: Arkansas K10
Notice there is almost no paint on the front of the bed.
![]() Join Date: Jul 2009
Re: Arkansas K10
I missed seeing this build hit the forum, but I'll be watching. What a solid foundation to start with!
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ![]() 2001 GMC Sierra K2500 |
![]() Join Date: Apr 2008
Re: Arkansas K10
Will be very nice when you’re done- good start!
![]() Join Date: Dec 2013
Re: Arkansas K10
Awesome truck
I aint nobody DORK 1972 Cheyenne super k10 swb 350 4speed posi hooks 1934 ford 3 window blown 355 1969 Camaro hugger orange hounds tooth |
Re: Arkansas K10
Im in.
Re: Arkansas K10
I finally got around to painting the bottom of the bed floor today. I had planned to sand blast it but all I had to do was power wash it and scuff it with a pad.
Re: Arkansas K10
I just noticed where your located. I came through there last year. If I had noticed this sooner I would have given you a holler.
![]() ![]() Join Date: May 2015
Re: Arkansas K10
wow...that under bed shot looks like brand new metal....thisll be a nice build
Re: Arkansas K10
I'm struggling with what to do inside the bed. It had a bed liner in it, hence the nice bed, but I hate bed liners. Stuff slides around in them like it was on ice.
I thought about a color matched spray in bed liner, but they always make me think somebody is trying to cover something up.
Re: Arkansas K10
im going to use color match linex on my IH build for that very reason...to cover stuff up...my bed floor was well used and I straightened what I could and i also shortened the bed.....my thinking was the linex would help hide some of it
Re: Arkansas K10
Rubber bed mats are what I use. Plastic bedliners usually grind the pait off the floor--gack.
Re: Arkansas K10
The floor is real nice because of the bed liner, but the bed liner did take the paint off in places. I may do a mat. The truck will see the easiest times of it's life as long as I have it. Read, till I'm gone.
I have a rough late model for working.
#15 |
Re: Arkansas K10
I got the inside of the bed blasted today. Of course I waited until we had 95% humidity to tackle this. I wore a hoody, gloves and face mask. It was hot in there.
#16 |
Re: Arkansas K10
I finally got epoxy primer on the bed today. It only took three months.
#17 |
Re: Arkansas K10
I got some other projects finished up and got back on the K10 this week. We set the cab off today and I degreased the frame and chassis.
The only assembly mark I found so far is a mark on the rear differential cover.
#18 |
Re: Arkansas K10
Glad you’re back on it. Didn’t have the vin on the firewall?
#19 |
Re: Arkansas K10
Only the two marks at the far outside of the cowl that look like a ribbon.
#20 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: Arkansas K10
I'm on board!
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#21 |
Re: Arkansas K10
I got the power washer out this afternoon. It's tempting to get more aggressive in the cleanup, but since this is a restoration, I'm trying to document all the factory markings and colors I can.
The front springs were gray. The transmission has "H4" stenciled on the side. The bell housing has a "P" or "B" in crayon. The passenger side axle tube has blue paint inspection marks by the shock mount. The transfer case has the data tag on it.
#22 |
Re: Arkansas K10
The yoke behind the transfer case is red like the transfer. The bolts appear to have been in the transfer case when it was painted, because they are red also.
The calipers have inspection marks on them in crayon.
#23 |
Re: Arkansas K10
This truck is going to be on the same level as IronCanine’s projects
71 C10 72 K20 72 K10 Super Kirk |
#24 |
Re: Arkansas K10
Don't put that kind of pressure on me. I am already looking for places to cheat. Pictures do wonders for us cheaters.
#25 |
Re: Arkansas K10
I found some more assembly plant inspection marks today.
Blue paint mark on top of axle tube by rear shock mount. Blue paint mark on top of transfer case at the rear output shaft. Part number stencil on drive shaft. "Chassis and Body Parts Catalogue" effective May, 1979 says the part number is 3995752
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. Last edited by davischevy; 09-30-2019 at 06:49 PM. |
