01-17-2021, 10:56 AM | #1 |
57 Fleetside C4 build
Hi All, I figured I should start a build thread since been a member for a while. I picked up a 57 big back window custom cab with 58/59 fleetside bed that has been converted to C4 suspension front and rear. This was a started project by the previous owner. I have done a half dozen body off restos on 67-73 olds 442's and this will be my first truck. I know the truck looks pretty good in the pictures but the front floors, cab mounts and cab step areas needed work. I have been working on it the last 5 months and will get the thread up to date. Thanks Steve
01-17-2021, 11:06 AM | #2 |
Re: 57 Fleetside C4 build
This was the teardown just after getting it. I came with a lot of parts including a LT1/4l60E that I am not using. There is at least 5 different trucks that parts were collected from. Steve
01-17-2021, 11:20 AM | #3 |
After looking everything over and coming up with a plan I got started on the cab first. Someone had install step plates over the original, mudded over holes in the hinge and lock pillars and installed some pretty ugly floor patches. I will be installing, front floor patch panels, front cab mounts, cab steps, lower "A" pillars, Lower "B" pillars, right lower plenum and inner and outer cab corners. Plus made some patches for pieces not reproduced. Steve
01-17-2021, 11:29 AM | #4 |
Starting to patch up the cab in the left plenum, A and B pillar and step area. My welding is not the greatest but will not fall apart. Steve
01-17-2021, 11:44 AM | #5 |
While I was patching the cab up I was thinking about what powertrain I was going to use. I settled on a 6.0 LS with a 4L80E trans from Just Chevy Trucks in Maine. This is one of there Hypermax builds in which they install rebuilt 5.3 heads on a 6.0 for more compression, new roller cam, lifters, cam bearings, oil pump and timing chains. They dyno the engine, tune a pcm to your specs with a stand alone wire harness. My engine made 472 h.p. at the crank which should move this truck good. They also supplied the 4L80E completely rebuilt. They did the engine, trans, harness and all associated parts like pcm, fuel pedal (mine will be DBW)and gaskets all for $4500 delivered to my door which I think is a good deal. Steve
01-17-2021, 02:46 PM | #6 |
After getting the engine and trans settled went back on the cab. First was finalizing the B pillar and inner cab corner I test fit the step which did not go well. The step rocker was at least a 1/2" below the cab corner. Should have known when the inner cab corner was to high and cut it down. someone had done cab corners and put them in to high on the body. After replace the out cab corners was able to get it aligned much better. The first test fit of the right door went well an gaps not too bad. Steve
01-17-2021, 03:44 PM | #7 |
Some more pics. This of the left side same area plus the fuel filler hole. Steve
01-17-2021, 04:01 PM | #8 |
After the cab work needed to test fit the LS engine and trans just to Make sure it fits. It was tight but fits great. I used the Dirty Dingo slider mounts which raises the engine 1/4" over other mounts and I needed it to clear the rack. these mounts allow the engine to be slid where you need it. Steve
01-19-2021, 05:43 PM | #9 |
Looks like a great start to a project. Killer deal on the engine/trans setup. 472hp ought to move her along pretty mightily!
“Perseverance is the hard work you do after you get tired of doing the hard work you already did.” ― Newt Gingrich 1975 Toyota FJ40 1952 GMC 5 window 1963 Falcon Convertible |
01-20-2021, 11:53 AM | #10 |
This is going to be a fun truck, good job. Have you set your radiator and electric fan in place? I had to alter my firewall a little and move the engine back about 2" so I have lots of fan and shroud room. Some radiators are thicker than others and some fans - shrouds are thicker/thinner too.
01-20-2021, 07:35 PM | #11 |
Thank You. I did not think I could go wrong for the price. A good friend used the same company for his 49 pickup only he used a 5.3/4L60E combo and runs great. Steve
01-20-2021, 07:39 PM | #12 | |
01-21-2021, 11:27 AM | #13 |
looking good. we are running fairly similar setups. Im hoping to tack in my motor mounts and test fit the radiator this week. Do you plan on running either front or rear sway bars?
1955 chevy longbed shortened, C4 vette suspension front and rear with flatout kit. Gen V LT1/8L90 http://67-72chevytrucks.com/vboard/s...d.php?t=746958 |
01-21-2021, 12:03 PM | #14 |
I wasn't planning on running sway bars. The guy I bought this from does a lot of these and he wasn't running sway bars on his builds. I don't know if you could get the stock corvette bars in there. Steve
01-21-2021, 04:05 PM | #15 |
nice work!
01-21-2021, 04:44 PM | #16 |
01-21-2021, 04:54 PM | #17 |
Test fit a second set of headers. I tried the shorty set from speed engineering and the #5 tube was too far in the way of the steering shaft. I bought a set of long tube headers from speed engineering and they fit perfect other than having to trim the right ear on the 4L80E trans and flexplate cover.
Another problem I am trying to figure out is the aftermarket front fender alignment at where the fender meet the cowl near the windshield. It fits good at the back but is high at the front. Any help would be appreciated. Thanks Steve |
01-21-2021, 05:01 PM | #18 |
I had the very same issue with the aftermarket fenders. It took some time to cut and weld to fix it to get it right... after all that work I still ended up going with originals just because the originals were a thicker gauge metal. but you can fix it... just time and patience
01-22-2021, 12:17 PM | #19 |
While it seems there's some definite fitment issues with the reproduction schtuff, I recently came across a good video showing how to align TF's panels. Maybe this will help some.
https://youtu.be/RgUwd9PdWiA |
01-22-2021, 01:33 PM | #20 |
imo you got a smoking deal on your motor/trans setup, the more people getting into that type of tuning/conversion the better the pricing gets. i spent that much just on my ramjet 350
nice headers, i wish i had gone thru the trouble to find nice long tubes vs my block huggers have you figured out your shift linkage yet? the left lever gives you more room but your going the wrong way. i can tell you what i did
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
01-22-2021, 01:39 PM | #21 | |
01-22-2021, 04:37 PM | #22 | |
01-22-2021, 07:24 PM | #23 |
heres a video from Jodaddy that really helps with the fenders
https://www.youtube.com/watch?v=6vwg_loea5w |
01-22-2021, 10:24 PM | #24 |
Navy Radioman Veteran
VERY nice build! Great work.
1987 Chevrolet R10 Silverado BBC Build thread - SOLD 1986 GMC Sierra Classic - SOLD 1957 Chevy Step Side - At the Body Shop Daily Driver; 2005 Chevrolet Silverado 4x4 Z71 Stepside |
01-23-2021, 05:53 PM | #25 | |
