01-10-2010, 01:57 AM | #276 |
VA72C10
Re: Project NOT4SLE
Nice work....looking forward to the pictures. Your planning has paid off. Even with a few setbacks your downtime is minimal...
Looking for a 67-72 swb or blazer project in or around VA. |
01-10-2010, 09:27 AM | #277 |
Re: Project NOT4SLE
yesterday ended up being a long day, going on a couple hours of sleep and at work again. once off work going to go and finish the truck.
01-10-2010, 05:25 PM | #278 |
big guy
Re: Project NOT4SLE
It's looking great! i am in the same boat but because of work i have no time to play plus it was only 22 here yesterday for the high!!!! Really hard to do any painting or anything in this weather. lol I can't wait to see yours done.
Thanks for sharing with us Ray |
01-10-2010, 08:15 PM | #279 |
Re: Project NOT4SLE
Well I got the truck finished in the rear, it is Porterbuilts 2" lowering trailing arms, and 5" ECE lowering springs. The shocks which many rave about the KYB seem to not be good at all. i did buy them used and was told less then 400 miles on them but they just do not seem very firm and the truck has some bounce to it.
I did have HUGE problems getting my driveshaft to mount up in the Porterbuilt crossmember. The factory driveshaft had no possible way mount to the crossmember without a custom 1" spacer. You can see by the pics. It is a little odd looking right now until the front gets done but she sits on 235/75/15 tires right now and she seems to be very low. Way lower then comparable trucks with a 6" lowered rear. heres some pics finishing up heres pics of the spacer I HAD to make. Maybe Im missing something but no other way to get a driveshaft to work. You see the front bar that the driveshaft has to clear. Last edited by vegaschevy; 01-10-2010 at 08:16 PM. |
01-10-2010, 08:17 PM | #280 |
Re: Project NOT4SLE
01-10-2010, 08:42 PM | #281 |
Re: Project NOT4SLE
looking really good, but I know that when you lower the front the back will come up some..
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
01-10-2010, 08:43 PM | #282 |
Re: Project NOT4SLE
01-10-2010, 11:52 PM | #283 |
Re: Project NOT4SLE
Cool, lots of work there. How long till you drop the front?
01-11-2010, 12:35 AM | #284 |
Re: Project NOT4SLE
Love your progress - thanks for the updates!
72 Cheyenne shorty "CheyLow" 72 3/4 long 4X4 69 SWB "Prospector" 68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled" Have you heard about C10 Talk? C10 Talk is a podcast all about C10 Trucks, the builders, the vendors, and most importantly the C10 Community. Check us out online at www.c10talk.com |
01-11-2010, 12:41 AM | #285 |
Re: Project NOT4SLE
i would contact porterbuilt on that man. seems fishy. looks good
01-11-2010, 01:28 AM | #286 |
Re: Project NOT4SLE
Sent ya a PM Deven. The crossmember isn't designed to be used with the carrier bearing you have installed. A shim or spacer like you have made is necessary for clearance at the shaft. It will work as you have it. I will give you a call tomorrow to further discuss.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
01-11-2010, 02:57 AM | #287 | ||
Re: Project NOT4SLE
SHould be doing it next wednesday. I have another day off and going to start on it. should take a day or two to get it all done. I would be set if I could find someone that has a set of 71-72 A arms that I could get shipped to me and then I could ship mine back to them. I want to powdercoat my arms and that would save me a day of disassembly.
cool, Thats what I figured, Just ran around till I found a spacer and went that route. I looked at every carrier bearing I could find and they all had the same dimensions height wise. |
01-11-2010, 03:15 AM | #288 |
Re: Project NOT4SLE
Nice progress ! She looks great lowered
72 C20 Longbed 05 1500 Z71 |
01-12-2010, 09:23 AM | #289 |
Re: Project NOT4SLE
Had a starting issue with the truck this morning. or this last evening.
i cut my exhaust right in front of the muffler to get my rear suspension on. Well she no longer starts very easy like she used to. i dont get it. i would not think loosing back pressure would make it hard to start but maybe. Last night she started idled for a few seconds then died. would not restart. It has fuel and floats are full. Any ideas? I was thinking a muffler that was flow through but those dont restrict much if that is my problem |
01-12-2010, 10:00 AM | #290 |
Re: Project NOT4SLE
Just a thought check the grounds
Looks good
Rolled the dice and lost!! Check Out my 71 build http://67-72chevytrucks.com/vboard/s...d.php?t=375158 |
01-12-2010, 12:35 PM | #291 |
Re: Project NOT4SLE
Lack of back pressure won't cause either situation. If I'm understanding you correctly, it won't start and it hasn't started since it died right? Check your ignition module inside the dizzy or at least check a wire for spark.
01-12-2010, 01:12 PM | #292 | |
Re: Project NOT4SLE
i think the lack of back pressure is making it run and start hard. It without a doubt has made the gas mileage drop |
01-12-2010, 04:26 PM | #293 |
Never Ending Projects
Re: Project NOT4SLE
Three things you must have for an engine to run, fuel, air, spark. Make sure you are actually getting all three before going futher.
Exhaust back pressure can change the tune needed but will not typically cause an engine not to run. I have run open headers without issues. Check all the basics first. Good luck.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
01-12-2010, 04:47 PM | #294 | |
Re: Project NOT4SLE
Went out to trouble shoot and the 12 volt wire came off the Dizzy. she fired right up after that. Still runs crappy though |
01-12-2010, 05:37 PM | #295 |
Re: Project NOT4SLE
Truck is looking good. Keep up the nice work.
01-12-2010, 06:01 PM | #296 |
VA72C10
Re: Project NOT4SLE
glad you got it running. I'd adjust the idle screws unless you will be doing the exhaust soon. THe freer flowing exhaust will affect the tuning of course. I ran more timing and less fuel if i remember (might be wrong-it's been 12 yrs) on my 80Z28 whenever I opened up the exhaust cutouts. Let the exhaust dump right after the headers....It ran really good like that once I learned to tune it. I ran it at the strip and I picked up 2 tenths with the exhaust open vs through the exhaust (had high flow cats and dynomax turbo mufflers)
01-13-2010, 12:02 AM | #297 |
Re: Project NOT4SLE
01-13-2010, 04:27 AM | #298 |
Re: Project NOT4SLE
I have so many ideas, thoughts and plans it is not even funny. i have kicked around the big block idea, LS or 6.0 motor, 383 stroker motor, all kinds of everything.
I know that it is a matter of time with the current motor as it is probably 180k on it and 40 yrs old. Not to mention the tranny lol Well I need to start on the motor route soon. Ill probably patch up the exhaust a bit and then wont get to a motor for awhile. i want to do the front suspension, wheels tires, front sheetmetal and 67 front end, then a few other odds and ends and then the motor. So it is a few months away at a minimum. but it will be a great motor when i head that way. I want to do another truck as well so i was thinking I could build a nice 383 and then keep it for another project if I decide to do a FI motor later for this truck. |
01-13-2010, 07:04 PM | #299 |
Re: Project NOT4SLE
LOL, got the spark working. Knew it would be one of the three.
01-13-2010, 10:44 PM | #300 |
Re: Project NOT4SLE
Well I'm a big fan of the 383's
Alot of guys are doing to the LSx motors with fuel injection and overdrives but I love the old school stuff. I'll leave the 402 in mine but I'm gonna toss some mods in it soon. |
Thread Tools | |
Display Modes | |
