Old 12-26-2010, 08:35 PM   #451
85burb
85burb's Avatar
Re: 85 burb meets 6.0 lq4
Just seen the pic.....sorry i guess i was running buy when i took it. Was VERY excited. Will do beter next time.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 12-27-2010, 02:46 PM   #452
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
prestone
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 12-27-2010, 05:05 PM   #453
68 TT
Still plays with trucks
68 TT's Avatar
Originally Posted by 85burb View Post
My truck only puts out 12 something at ldle then if you tap the gas at all it goes up to 14 or so. So it is getting constant batt voltage. The wire i am using is not 10 but it is prety thick. maybe 12-16 or so. I have seen the relay kits the sell but not sure if the wires will go to the back where my pump is located. Maybe i will save up for that kit. Thanks.
Where is the fuel pump relay getting its power from?
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 12-27-2010, 08:41 PM   #454
85burb
85burb's Avatar
Originally Posted by 68GMCCustom View Post
prestone
The regular green or the extended life?
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 12-27-2010, 11:02 PM   #455
68GMCCustom
ah heck....I don't remember...but I poured a litte in my daughters Jeep and it was green!
Kurt -
Old 12-28-2010, 12:09 AM   #456
85burb
85burb's Avatar
Oh i see. It may be the mixable kind or regular.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 12-28-2010, 12:15 AM   #457
85burb
85burb's Avatar
Does not have a relay. Could not find a relay wire kit at auto stores. It is comming from my fuse box under dash in an ignition power spot. Then goes to a fuse then switch then to pump. It only requires a 7.5 amp fuse. I am going to get it a relay some time. Not sure if it will do any thing for my problem or not. I looked at my psi gauge and at high idle it was 6 and after i got home from work with light and heat on and volt gauge reading under 13 it was still a 6psi. Guess it does not matter if the pump is going fast or slow the reg will still only put out 6 right now. Will set float level and idle mix again this week end if i have a chance due to having diff fuel psi then when carb was first installed. Sadly still has hesitation...Did not think pump would fix it tho.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 12-28-2010, 01:09 PM   #458
68 TT
68 TT's Avatar
That is a whole bunch of the voltage fluctuation problem. The fuel pump needs as much voltage as you can give it and coming out of the fuse box it doesn't get much and the amps are low too.
Find a front wheel drive donor rig that has one of the oval shaped weather-pak style 30-amp electric fan relays with a long 10-gauge power wire. Early 90's or so. Take all the wire you can get out of the donor rig along with the relay so you don't have to splice the main power supply wire.
Run the power supply wire for it through a 30-amp breaker and connect that directly to the battery. The breaker will trip if grounded out but reset when the problem is corrected so you won't get stranded by a blown fuse.
Mount it as close to your fuel pump as you can get it so the smaller gauge feed wire from the relay to the fuel pump is as short as possible.
Old 12-28-2010, 08:47 PM   #459
85burb
85burb's Avatar
Thanks for the info i will save for the painless fuel pump kit. The pump says to use a 7.5 amp fuse. Does it matter on the amp rating or should i just get a 7.5 amp breaker?
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 12-29-2010, 12:08 AM   #460
68GMCCustom
since you're not running efi your fuel pump isn't as big of an issue. I plan on running mine wired direct to an ign lead on my Painless Circuit Boss....which is fused, breakered, and relayed.
Kurt -
Old 12-29-2010, 12:56 AM   #461
85burb
85burb's Avatar
That is one fancy circuit boss. My only has ign port with no fuse or relay. I do have it fuesed and switched so it can be shut off if i need to sit with the key on engine off for some reason. I would still like to put a relay so i can get power direct from the batt connection and have it come one with key. I am not that worried about it any more due to fuel psi staying the same all the time.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 12-31-2010, 06:23 PM   #462
85burb
85burb's Avatar
Got to install my sensor adapters today. Forgot my dang oil psi sensor at the house tho...dang it. Moved plug from passenger side head to driver side head then installed coolant sensor in the pass head. Looks cleaner i think. Also checked plugs in old motor and reset idle mix and float levels.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 01-04-2011, 12:22 AM   #463
85burb
85burb's Avatar
Well after readjusting my idle mix and float level i drove it to work today and seems to me the problem with the hesitation is compleatly gone... Kind of funny. Not sure why or how it is compleatly gone. But it is. Still does not have any more power on the hiway after like 65 if you put some throttle in to it. Maybe my secondarys are not opening due to the heavy spring i put in it. Oh well. If it stays how it is i will be happy. At least tell i put motor in.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 01-10-2011, 05:15 PM   #464
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Got my msd wires in mail today. They came with fancy wire lables and cool too to install the labels. Also got alt pig tail and oil psi sensor.
Looking great so far!! Do you have a part number on the MSD plug wires??
Thanks!!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 01-10-2011, 10:21 PM   #465
85burb
85burb's Avatar
Thanks!!
Thanks. 32829 is the part number.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 01-16-2011, 10:55 PM   #466
85burb
85burb's Avatar
Well folks....Have good news.. i have a tenitive install date set. The last week end of this month. If weather is nice and bro can get time off work it should be in. That is all thank you....
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 01-16-2011, 11:20 PM   #467
68GMCCustom
I'll bet you're anxious!
Kurt -
Old 01-16-2011, 11:28 PM   #468
85burb
85burb's Avatar
.............................Maybe a little.......................
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 01-17-2011, 09:22 PM   #469
y5mgisi
Second Chance Program
y5mgisi's Avatar
Man! Cant wait to hear how it runs!
y5mgisi is offline   Reply With Quote
Old 01-18-2011, 12:16 AM   #470
85burb
85burb's Avatar
Me too!!!!!!!!!!!!!!!!!!!!
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 01-23-2011, 09:32 PM   #471
85burb
85burb's Avatar
Well i got oil and filter today. Got 6 qts of valvolines finest and one ac delco filter. Talked to my bro and we are all set for this friday. If the boss will give me the time off that is. Ran all over town to try to find a 3inch to 2.5 inch reducer and could not come up with any thing. So i will be going to my exhaust shop to see what he can do for me. Want to get the flandges welded on with short reduceres so i can get rest of exhaust welded on.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 01-23-2011, 09:46 PM   #472
68GMCCustom
Order it from Summit Monday and you'll have it by Friday.
Kurt -
Old 01-23-2011, 10:06 PM   #473
85burb
85burb's Avatar
I need some that do not have a 3 bolt flandge on it. The ones summit sells are 26 bucks. I can go to autozone and get some with slip on flanges for 20 if my exhaust shop can not work something out for me. Dang pepboys had one 3 to 2.5 reducer and that is it. A 2.75 inch pipe goes in side my v band clamp like a glove. Maybe they can take a 2.5 pipe and expand it to that size.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 01-26-2011, 12:11 AM   #474
85burb
85burb's Avatar
Install day moved.....UP TO FRIDAY!!!!!!!!!!!!!!
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 01-26-2011, 02:05 AM   #475
y5mgisi
y5mgisi's Avatar
Thats in like 3 days!!! Planning on having it running by sunday afternoon?
Thread Tools
Display Modes
