Old 02-23-2007, 09:17 AM   #51
ChevyDude
Re: lets see your trick mods and custom touches!!
Paint Frame and well everything and install Fuel Cell Guys tank, sway bar...that's just the rear end mod...Eaton posi disc brakes to be added this summer!
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 02-23-2007, 10:47 PM   #52
corn
Not a lot from me but here goes...
Ash tray converted to cup holder in console, trans mounted floor shifter & engine turned gage cluster...
corn is offline   Reply With Quote
Old 02-23-2007, 10:50 PM   #53
corn
Heres the shifter...
Old 02-23-2007, 11:49 PM   #54
cped
Originally Posted by HuggerCST View Post
Here's mine. It's about the only thing on my truck that is custom.
Doing a search for gas filler options and came across this thread. I'd love to see more info/tech how to on this specific one. This is clean and exactly what I'd like to do with mine. Any help would be greatly appreciated.
Thanks,
chad
Chad
Thursday Night Garage Association
cped is offline   Reply With Quote
Old 02-23-2007, 11:53 PM   #55
pritch
pritch's Avatar
This is pretty much all I've added so far. Map light out of a '88 F-150.
I didn't have any kind of dome light, and with the Panel I needed to put it above the windshield.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 02-24-2007, 12:03 AM   #56
dan42
dan42's Avatar
dude, that is nice - it's different but still very original -
dan42 is offline   Reply With Quote
Old 02-24-2007, 12:06 AM   #57
dan42
dan42's Avatar
Originally Posted by cstm68 View Post
im doing the same thing but as a full length console. how did you make the cup holders ???
dude, I like the white gauges - are they still original?
Old 02-24-2007, 12:25 AM   #58
chevymike71
fully custom truck
chevymike71 is offline   Reply With Quote
Old 02-24-2007, 12:32 AM   #59
Frizzle Fry
Frizzle Fry's Avatar
Another member now owns this truck, but I rounded the bed corners (proof of concept run for my 61), made the door panels from deluxe/standard panels combined (I thought they looked pretty cool), and put F150 side mirrors on it:
Frizzle Fry is offline   Reply With Quote
Old 02-24-2007, 12:49 AM   #60
Frizzle Fry
Then on the Suburban... Is a 476 a custom touch? Door panels (still not fully complete), new inserts in the seats (as seen via camera phone pic), Keeping the dealer installed roof rack (it's sorta custom, right?), and I just finished making these covered fiberglass kick panels. I'll post the installed pics later.
Old 02-24-2007, 12:52 AM   #61
Frizzle Fry
Kick panels before covering, and the rack...
Old 02-24-2007, 10:02 AM   #62
c10crazy
Like a Rock!
c10crazy's Avatar
Frizzle Fry- how will you mount the door panel inserts?. Are you going to install the pull knobs for the air vents so they are still functional?. Cool Burb!
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
Old 02-24-2007, 10:27 AM   #63
meaniam
good looking deal. i asked you some ? on your other thread
meaniam is offline   Reply With Quote
Old 02-24-2007, 10:31 AM   #64
meaniam
Originally Posted by johnnywagon View Post
Kinda low-tech and easy. I mounted 2 pairs of Pilot brand fog & driving lights (one pair clear, one amber) in my bumper marker light holes. Yes, its on a 4x4 but I think it would look good a lowered rig too.
now that there is a get her done pic. looks bad ass
Old 02-24-2007, 01:08 PM   #65
Blue85
Oilfield Trash
Blue85's Avatar
01 chevy seats, 95 booster and master, and a custom gas fill in the box
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 02-24-2007, 01:14 PM   #66
Frizzle Fry
I've epoxied hardwood blocks to the back of the inserts. I'll just use wood screws through the panels and maybe some glue. I have the rear deluxe panels for making the rear inserts too.
Yes, drilling holes for the vent pull bracket is the next step on the kick panels.
Old 02-24-2007, 01:21 PM   #67
Frizzle Fry
The gas filler is clean. Well done! Is the MC/Booster a simple install?
Old 02-24-2007, 03:51 PM   #68
dave3156
One of my mods is a wood bed I made myself. The wood is poplar. I cut the boards to size (specs from GMC Pauls website), ran them thru a planer, cut the grooves for the strips with a table saw, put three coats of spar polyurethane on both sides, bought the unfinished strips form Mar K and painted them with 2 coats of Blue and one coat clear. I attached them over a one piece welded in steel bed. I first coated the bed with POR15 and then mounted the boards over closed cell pipe insulation (boards are on top of foam insulation so they have air under them). I drilled holes through the steel bed and used stainless steel bolts and self tighening nuts to secure it to the steel plate. It was alot of work but I'm happy with the results.
dave3156 is offline   Reply With Quote
Old 02-24-2007, 04:23 PM   #69
RetroSBK
Made an acrylic hood emblem insert out of florescent blue acrylic. Thinking about adding a LED to side light it when the head lights are on...
Some mildly custom door panels.
Also fitted 14in electric fans, One puller on the radiator, one puser on the condensor. Did quite get the AC cold enuf so now sitting on the shelf, waiting for me to put them on are a 508 compressor and Be-Cool condensor. Made a smoked Acrylic shroud to force all the air to flow through the condensor as well.
The front fan eliminated the room I had for my old hood pop, so I made up a new lever drilled a hole, and looked some cable through it. Ran this around one bar of the grill... It is all but invisible, and works great!
Also fitted late model C1500 seats..
Right now we are calling this truck FHFU... Fix his F*** ups (the previous owner was a hack) notice the cut doors and dash, the fact the when you turn on the fan, the compressor kicks on, etc etc.. LOTS of work to do... or re-do..
1970 C10, shortened long bed, Alum Headed full roller 383 (with Victor, 750DP, stainless rockers, behive springs, CNC ported heads) TCI SSF 700R4, 4.10 Posi, Bagged on C-Notch and 2.5 spindles. Air Cond, black out tint, satin black paint, custom interior, rolling low and not so slow...
RetroSBK is offline   Reply With Quote
Old 02-24-2007, 04:42 PM   #70
Kurt L
Kurt L's Avatar
that would be cool idea there Retro on liteing up the hood emblem.post pics after your done.
Kurt L is offline   Reply With Quote
Old 02-24-2007, 04:58 PM   #71
Blue85
Oilfield Trash
Blue85's Avatar
frizzle fry, just had to drill new mounting holes for the booster, and lengthen the pushrod
87 Chev 3+3 4x4
Old 04-15-2008, 05:30 AM   #72
chevychase
chevychase's Avatar
TTT
I was checking out this cool thread, it's over a year old. I'm trying to revive it, so post your mods up!
chevychase is offline   Reply With Quote
Old 04-15-2008, 02:10 PM   #73
tommypic
tommypic's Avatar
Did the Booster bolt right up ? what brackets did you use . I am putting disk on 4 corners on a 67 C 10
tommypic is offline   Reply With Quote
Old 04-16-2008, 03:07 AM   #74
fastom
That's right, it's Copper!!
fastom's Avatar
Here's my dash, kick panel speakers, shaved firewall, etc.
The truck is nearing completion!!
fastom is offline   Reply With Quote
Old 04-16-2008, 03:17 AM   #75
gregfull
gregfull's Avatar
Lets see some more of that truck. I'm partial to that color.
My Suburban Project
72 Suburban
68 SWB
57 Belair
55 Cameo
06 Chevy 1/2 ton crew
09 Suburban
gregfull is offline   Reply With Quote
Thread Tools
Display Modes
