#51 |
Re: 1975 Chevy K10 Scottsdale Rebuild.
Looks awesome and the caps are a nice touch!
#52 |
Man those look great. Go sling some mud.
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
#53 |
Second Chance Program
Thanks fellas!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
#54 |
Nice! The new tires and wheels look great.
#55 |
Finally got the k10 into the garage for the auto to manual transmission swap! Today I got the column out and the old pedal assembly out. Tomorrow morning I'll drill the hole for the linkage and get the new pedal assembly in and the column back in.
#56 |
How are you setting up the clutch / linkage?
#57 |
#58 | |
The truck looks great with the new wheels and tires! |
#59 |
Lol all good my friend! And thank you! I'm ridiculously excited about how it looks now!
#60 |
#62 |
Thanks! I thought it was clever.
#63 |
Camaro Club
its going to be a blast to drive with the 4 speed. And I dont know about you but I love the mechanical clutch's. My 88 Suburban has everything from a late 70's truck so its mechanical and it has a much nicer pedal feel than my boss's 85 k30 dumptruck or his stepdads 85 k20, both with Hydrolic clutch's.
#64 |
Best part about my 4 speed '77 was my wife never wanted to borrow it! Just kidding. Should be a blast to cruise. Something is just right about an old truck with a stick.
#65 |
I can't wait! Hopefully get it wrapped up here in the next couple weeks!
#66 |
Always a pain not having help in the garage but it does make you feel like mcguyver when you get clever out there
![]() Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289 - Dylan (209)-985-7721 |
#67 |
Had to get creative a good number of times over the years! I did get the flywheel and clutch bolted on.
#68 |
I decided now would be a good time to replace the clutch fork and pivot ball...
![]() ![]() ![]() ![]() And made myself up a neato little clutch linkage bracket. ![]()
#69 |
#70 |
And my solution to the problematic heat riser exhaust valve. I knocked out the shaft and drilled and tapped the hole for a bolt.
#71 |
I know the pieces fit
Looks good! The bracket you made, is that hard to find? Just curious, I have most all the parts to do the same swap but have never swapped an auto for a manual trans.
#72 |
I was having a little bit of a tough time finding one. I'm sure I could have but in the end I just decided that it would be easier to make one out of some angle iron I had.
#73 |
Nice work on the fab. You should be grinding 1-2 shifts faster than you can say go!
#74 |
Lol!
#75 |
Thread Tools | |
Display Modes | |
