07-21-2016, 12:00 AM | #51 |
Re: Anyone have this original in-bed spare tire carrier mounted?
I don't have a good picture of mine, but it looks just like the rest of these so it must be original. I wouldn't mind a 2nd one, a 2nd spare. They are a great place to store your tire chains, plus often it's easier to change tires than install chains.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
07-21-2016, 10:08 AM | #52 | |
Ya'll gotta remember that back then,these trucks used relatively small tires compared to today. I have P235-70-15 on it now,which are a little too wide for the stock rims width. When I was a young red-neck type deer hunter,I drove a 63,C-10.I always had 2 re-capped mudgrip tires in the bed to use in deer season and street tires for the rest of the year.It was a common thing down here. On the spid-What does the SM mean? Mike. |
07-21-2016, 10:40 AM | #53 |
07-23-2016, 08:42 PM | #54 |
I took a couple pictures of my set-up today:
I just have a piece of all-thread for a bolt The tire is held on with these spacers and wing-nut: Like this: It works for me!
07-24-2016, 12:51 AM | #55 |
That's bolt set-up is nice Pritch.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
08-03-2016, 12:48 AM | #56 |
It does appear the screws for the top are the same as that for the spring for the jack handle behind the door (5/16" x 3/4"). Might be shorter however. Just received a carrier and the top holes are 3/8". So unless I'm mistaken that calls for a 5/16" thread.
That's my report.
03-16-2018, 06:03 PM | #57 |
Earlier in this thread, I believe, 71CHEVYSHORTBED402 said that the bolt I have pictured above is not the correct bolt for a 1970 C/10 fleetside with the in-bed mounted spare. Am I reading the parts manual wrong or is it just because my bolt is threaded farther up the shaft of the bolt? I was pretty sure this one was correct. If not, what is the part number for the correct bolt?
03-16-2018, 06:08 PM | #58 |
Looks right to me...
Stan 67 swb BLU MULE posted via flip-fone |
03-16-2018, 10:46 PM | #59 | |
04-19-2018, 10:53 AM | #60 |
Sorry to bring back an old thread. Just wanted to say how happy I am I found this post. My newly acquired truck had been converted to propane at one time then converted back to gas. It had big steel hoops mounted in the bed. Just last night I got the hoops out (with some choice words in the process). I saw the strange mount on the inside of the bed near where the hoops were. I assumed it was some bracket having to do with the propane stuff. I had planned to remove it (probably cutting some bolts) but I got tired last night and decided to save the removal for another day. Today I found this thread and realized what the mount is. It is staying and will be put to use once I get a carriage bolt etc.
04-19-2018, 10:55 AM | #61 |
Haha, just realized after looking at my own pics, the carriage bolt is in the first pic. That means I have the carriage bolt sitting in a box.
04-19-2018, 11:17 AM | #62 |
So quick questions regarding this spare tire carrier option:
Were the upper holes needed to mount it, pre-drilled into the upper flange?...or were they added/drilled and then 'touched up' on the assembly line? What was the distance(s) from the front bed panel to the wheel centerline? Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
04-19-2018, 12:28 PM | #63 |
Its great to see old threads do some current good.
If the carrier is factory stock it will be listed as P13 S/M WHEEL CARRIER on the SPID. However many were sold as GM accessories and many aftermarket versions exist. It was located, by the factory, on the left bedside forward of the wheelhouse. The mounting specifics are in the assembly manual. Off the top of my head there is a smaller than standard floor bolt hole that locates the carrier it and two other holes are drilled to fit upon bed assembly. If I get a chance I will confirm/expand later. It has two or three different distances SWB, LWB and I believe Longhorn specifc. Really need to dig through my assembly manual. But basically the tire tucks to the wheelhouse.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 04-22-2018 at 12:27 PM. |
04-19-2018, 12:39 PM | #64 | |
Posted via Mobile Device |
04-19-2018, 02:47 PM | #65 |
Interesting.....makes me wonder when the holes were added on the assembly line.
you would think before paint?.....or did they include it in all the truck beds from the get go? Coley
04-19-2018, 04:07 PM | #66 |
I think they mostly just drilled out the rail for the top two mounts at the dealer and then reused the lower bed bolt. My bracket had the matching original paint but was mounted at the rear (which doesn't sound standard). The top holes were not tapped, just drilled. It had very little surface corrosion in the hole, maybe because it was high up and didn't get too wet over the years.
I investigated all that so I could prep it when I moved it forward and to the other side. Hope that helps. Posted via Mobile Device |
04-19-2018, 05:39 PM | #67 | |
The RPO P13 carrier replaced the standard P10 uderbed carrier. On Fleetsides it was located by a production reference hole in the left bedside floor flange. The locating hole was opened for a production through bolt and an existing fastener (@ station 72.49 or 84.49) hole used for the other lower corner. The bottom is secured in two locations with an existing production bed floor bolt hardware stack and an added bolt of the same type. We know the carrier top was match drilled and through bolted with phillips screws, nuts and washers. Of interest, spacers (crush sleeves?) were also used on RPO E81 wood floor Fleetsides and two different carriage bolts were used, 10 series and 20-30 series.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
04-19-2018, 07:53 PM | #68 |
I would not pretend to know factory restoration facts. Mine clearly was not factory. I just found it unusual that it had the original paint on the bracket if it was not factory. I guess it could have been painted to match and then mounted by the dealer or the owner.
1971 GMC C15 Sierra Grande SWB 1972 Chevy C10 Custom Deluxe LWB 2018 GMC Yukon Denali |
04-21-2018, 11:37 PM | #69 |
The Older Generation
As long as this was bumped to the top I will add pictures of the original NOS hardware I have. The first picture is the individual pieces and the second picture shows all of the pieces assembled. I think the picture above from the assembly manual (post #21) shows the two different nuts depending on whether the spare tire hardware uses the lock or not. The part number for the special nut is 3682846. The box is for the lock. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 04-21-2018 at 11:45 PM. |
04-22-2018, 01:07 AM | #70 |
How did I get this OLD!
Thanks for posting that Leon. That's the set-up I am going with on my 67 with P13 SM SPARE WHEEL EQ. as well as A97 SM SPARE WHEEL LOCK EQ. All the research I can find for the spare wheel lock in 67 is a chain with a plastic sleeve and a padlock. I don't know if your set-up was stock in 67 but that's what I'm going with.
http://67-72chevytrucks.com/vboard/a...1&d=1524373369
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt. |
04-22-2018, 02:26 AM | #71 | |
Did some digging and confirmed bolt 3991023 is for 1/2 ton applications being a round head square neck bolt 7/16"-20 x 4". Callout [4] in the drawing The/a 3/4-1 ton bolt 3898396 is the same but 1/2"-20 x 8 1/8". Callout [6] in the drawing So it would go that Callout [5] is a plain 7/16" lug nut and Callout [7] is a plain 1/2-20" lug nut as notated on the assembly drawing. Really wish the truck assembly manual had part numbers (any part numbers even long superceded) like my Camaro and Vette manuals do! Nut 3682846 (yours) is the 1/2 ton specific application for the keyed lock.
04-22-2018, 11:36 AM | #72 |
For some reason I can't find my 70 brochure. There is a very small image (LWB C10) of the P13 carrier. If someone has a copy and wants to check for visable details on the face side of the wheel....
04-22-2018, 11:57 AM | #73 | ||
I had a few of the 3682846 nuts that were about 1/2" shorter than the one pictured. Unfortunately I didn't take a picture of one before I sold them all. The groove in those was in the center of the nut. EDIT: it would be like the one on the bolt that Canuckvetter posted..... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 04-22-2018 at 12:04 PM. |
04-24-2018, 11:17 AM | #74 |
Good info here. Thanks
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
04-24-2018, 08:05 PM | #75 |
Here's a pic of mine
Thread Tools | |
Display Modes | |
