10-22-2012, 08:32 PM | #176 |
Re: The Good, The Bad and Ugly from Harbor Freight
I've got a few HF tools, some good, some not.
Wrenches and sockets have held up well. Ratchets, hit or miss. What I won't recommend to anyone is the 3/8" drive impact. Read the reviews at HF and believe them. I actually used mine for about a month. When it spit the socket twice in 20 minutes (last time socket flew about 35 feet) I was mad enough that I financed a gun off of the tool truck. (truck was sitting there when all this went down).
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ) I'm kinda like duct tape- no real purpose, but handy to have around. |
10-22-2012, 09:23 PM | #177 |
I bought a set of socket drive adapters from Harbor Freight and they've all twisted off the very first time I've used them. I also bought a cut-off wheel and it's great though.
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061 |
10-22-2012, 10:22 PM | #178 |
I tried my SAE ratcheting wrenches ($26.99) today, they worked great. Definitely handy for tight areas. I put strain on them and none of them broke.
71 K20 64 GMC mud truck |
02-08-2013, 06:14 PM | #179 |
I bought their CO2/Argon Regulator Gauge on sale + 20% coupon = $25. It works great on my 25/75 co2/ar bottle.
http://www.harborfreight.com/regulator-gauge-94841.html
My build thread: '66 Chevy |
02-10-2013, 03:56 AM | #180 |
My GF got me a 20 gallon compressor 3 years ago and it has worked great. No problems at all. In 1996 I picked up a pretty big tool set from Fingerhut of all places. I have yet to break a ratchet, socket or wrench. They are mastercraft brand made in China. I guess China used better steel back then.
66 shorty |
02-14-2013, 11:25 AM | #181 |
I'll jump in.
Good: 20 ton press Transmission Jack Soldering gun Ratchet extensions Heat shrink tube Bearing separator plate Bug zapper Bungee cords Useable, but not great: Sand blaster (I think it's a 50 lb) Die grinder (uses a lot of air and doesn't grind much. Maybe it's not so useable after all.) Bad: Pitman arm separator (cracked on first use) Exhaust tubing spreader (stripped threads on first use) 4" grinder (first one lasted 2 hours; replacement lasted 10 minutes) Impact wrenches (what good is an impact if you have to use a breaker bar first?) Band clamps (worm drive type) That's all I can think of right now. |
02-14-2013, 11:48 AM | #182 |
I've had good and bad with them.
Good: I actually have a 4" angle grinder I've beat the crap out of for over 10 years that still works great. Earthquake impact gun has worked well for many years Offset box end wrenches----don't use them a lot, but have been handy and no issues Heat gun---got it on sale for like $9 and it works great Heat shrink tubing---cheap and works great meh Manual tire changer----had to re-weld it in a bunch of places, works good now. Mostly use for motorcycle tires Hardware----some of the sheetmetal screws and stuff are ok, some are not Pipe threader---just barely ok Sockets---just ok Electric cut off tool---works ok but trips out easy. Have to keep resetting it. Bad Screwdrivers Flashlights Haven't tried much else.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
02-17-2013, 10:13 PM | #183 | |
I had it about 7 yrs it ran great but the spool was a piece of ####.Anyway one day in a hurry and very hot outside it tried to use it, of course spool messed up. The guy next door was laughing so hard my wife was in tears. I smashed the s*** out of it right in the front yard. oh we still laugh to this day about it. The guy next door said he would never ever get me mad after watching that episode, of course he steers clear from the barn out back at times also. |
12-04-2013, 11:34 AM | #184 |
I've found that the quick setting epoxy seems to hold better than JB weld...
12-05-2013, 01:13 AM | #185 |
a few weeks back I bought the $40.00 HVLP paint gun... it works great.
12-05-2013, 01:52 PM | #186 |
Happy (so far) with this.... http://www.harborfreight.com/18-gaug...ear-92148.html
Cuts pretty clean, fairly easy cuts.
"I feel the need for speed!"... as soon as I am done with my nap. |
12-08-2013, 02:44 AM | #187 | |
Beer Drink'n Knuckle Dragger
GOD BLESS MY BROTHERS & SISTERS THAT SERVE WITH US - 67 GMC Long-Wide 350/SM420 My BACON Wrapped Meatloaf Recipe |
12-08-2013, 03:31 PM | #188 |
their ratcheting crimpers Central-Forge - item#97420 also work well once you get the tension adjusted right. just make sure you put the terminal in the correct direction, the wire needs to feed in from the side of the crimper with the three colored dots. accel spark plug crimping heads also fit.
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies 2004 2500HD utility bed aka Brutus |
01-18-2014, 02:52 PM | #189 |
i had a prybar from there and as soon as i put some ass to it it broke!! the onlly time i have even seen a prybar break!!
"DON'T TOUCH THE TRIM!!"-Early Kyler |
01-20-2014, 03:25 PM | #190 | |
01-20-2014, 03:46 PM | #191 |
65 C20 292 4spd 4:56 Eaton HO52 |
02-18-2014, 08:28 PM | #192 |
some items are hit an miss
i bought both sets(standard&metric) of 1/2" dr impact sockets a few years ago they are awesome for the price. then i got both sets of 3/4" dr sockets and broke one the first time useing it. I try too stay away from the power tools there. but i got two items i have my eye on and i'm looking for some feedback on them. the retractable air/water hose reel with 50' hose. lot #93897/69265 i can imagine the hose is crap but i'm curious about the spring in the retractor does it last? and there 5lb.vibrator/tumbler lot#67617 of course i'm lookin at this too clean nuts&bolts blastin them is a pain oh an i've gotten there industreal air compessor filter/regulator and the reg blows the diaphram in a few weeks(i've had two) the filter...its better than nothing. just curious if anybody has these two items?
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
02-18-2014, 11:36 PM | #193 |
I've had the retractable air hose for years.
Can't complain one bit about it. Kim |
02-19-2014, 06:19 AM | #194 | |
great thanks kim57
02-19-2014, 06:34 AM | #195 |
As you mentioned in your initial post, the hose in mine started cracking/drying/leaking out after about 2 years (I think may have been closer to 3). I replaced it with another hose and it is good to go again. I can't complain though, and the reel works great.
02-19-2014, 09:02 PM | #196 | |
i had gotten a manual hose reel from there years ago its been holding up just fine after rewelding the handle back on. i use that one too reach outside. picking up an coiling air hose just becomes a pita all the time.
Thread Tools | |
Display Modes | |
