Old 04-26-2007, 03:40 PM   #1
wedgemon
wedgemon's Avatar
Cool K5 Lifted to K10 stock suspension swap.
I’ve been consider returning my 73 K5 Blazer to stock height. It’s currently got a 4 inch lift. My question for you guys is – can I swap the K5 lifted suspension to my 80 K10 Long bed and the K10 standard suspension to the K5. Or will there be spring length issues?
I’m obviously trying to cheap out and save a trip and money at the junkyard.
Also, is there a link or site that notes standard spring lengths?
Thanks!
- Dave
2003 Silverado K1500 Z71 - Arrival Blue
1973 K5 Cheyenne Blazer 350/TH350/NP203
Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift.
RETIRED: 1980 Scottsdale 4x4
Founding Member:
"TILT WHEEL BELLY." Club
wedgemon is offline   Reply With Quote
Old 04-26-2007, 04:33 PM   #2
Jonboy
Slots go on anything!
Re: K5 Lifted to K10 stock suspension swap.
If there are blocks in the rear, the parts should swap right out.
Old 04-26-2007, 05:03 PM   #3
wedgemon
wedgemon's Avatar
The K5 does have blocks in the rear. I more concerned with the spring length.
Thanks!
- Dave
Founding Member:
Old 04-26-2007, 05:14 PM   #4
Jonboy
the front springs are the same length. At least they should be. The difference is in the rears. Since you have blocks, it shouldn't affect anything, as you will keep the rear spring with it's respective vehicle. I did just the opposite once upon a time; used the lift out of a 79 K10 in an 81 Blazer. Everything is the same.
Thread Tools
Display Modes
