216- 235 Valve Cover ?
Will a 216 valve cover fit on an early 235 ?
and a few others
Re: 216- 235 Valve Cover ?
Not sure.
Can anyone help us out here?
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
Hollister Road Co.
I think so. I'll check tomorrow. I have a 235 head and 216 cover and studs.
Come on guy's I need some help here ?
1. My valve cover is a 235, 4 bolt (two per side on the bottom flange) and has some surface rust on the inside, will probably blast off.
2. I searched online and over at Stovebolt and it APPEARS like the early 235 and 216 valve covers interchange, 235 is taller, there is mention of needing longer bolts in one thread. There is also statements about early aluminum aftermarket valve covers fitting 216/235. I could not find a specific statement that they are the same. You might do a search over at the HAMB board. FWIW I still have the 58 235 long block, anyone need parts?
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
Probably get a good answer on inliners.org (http://inliners.org/ubbthreads/ubbthreads.php) where they definitely know their sixes. (btw not sure if they still manually approve all requests to register in which case it may take a day or so).
Hollister Road Co.
It will fit. You need the 2 long rocker studs that act as the hold downs and the cover.
Thread Tools | |
Display Modes | |
