Old 05-14-2012, 11:04 AM   #1
trout
got a burb and need to fix some rust
i got a 88 burb and the bck wheel wells are rusted up preaty good but way fixable i was thinking of using a old bed side for the out side body rust how hard do you think that is to graft it in and im not sure what to do on the in side couse there not mny places like the truck that i can juts unbolt the rust and put in a replacment from the junk yard ideas?
Edited by staff
trout is offline   Reply With Quote
Old 05-14-2012, 06:57 PM   #2
mullit
mullit's Avatar
Re: got a burb and need to fix some rust
there are replacement aftermarket quaters out there you can use
mullit is offline   Reply With Quote
Old 09-24-2012, 12:37 PM   #3
trout
thanks
Edited by staff
Old 09-24-2012, 08:18 PM   #4
79 silverado
With the rust I see there put your head up inside the wheelwells in back over the tires. Unlike a pickup the tub that forms the wheelwells is unfortunately made up 1/2 from a flare extending off the outer quarter panel, 1/2 from the flare on the inner quarter panel. Inside the truck there is then a tub that covers where the two panels meet that looks closer to a piece from inside a truck bed...
What you'll often find is that seam crumbles, starts allowing dirt debris and water to get thrown up by the tires inside the layers of the quarter, then accumulates in the bottoms behind the tire and inbetween the wheelwell and side doors, meanwhile the hole grows wider and wider. Might not be your issue at all, but I had two trucks that did that despite undercoating both at the dealer from GM and another with an add-on at the lot, both spent much time in the garage too...
Check that first before you start working on the rest so your work doesn't get undone if the source is still letting junk in...
79 silverado is offline   Reply With Quote
Old 09-24-2012, 09:56 PM   #5
trout
Yea I have rust there on both side I think I'm going to make patch panel on out side seal up the wheel well with fomyhing so debre font get into truck and finish war I got going on. It then off it goes to maybe done one eles thanks guys for the help
Edited by staff
Thread Tools
Display Modes
