04-30-2013, 08:49 AM | #1 |
Spare Tire Mount - In Bed
If you were mounting a spare tire in the bed of the truck, which back corner would you mount it in? Driver or Passenger side? I have already picked up a mount from LMC, just have to decide where to put it. I have a bed box, so I would like to avoid the front corners. I did a mock-up mount last night with it on the drivers side, pics below. By the way, the mount from LMC looks to be of good quality.
04-30-2013, 09:04 AM | #2 |
Re: Spare Tire Mount - In Bed
Drivers side like you have it mocked..with the exception of the three holes you can leave bolts in you can move it later.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
04-30-2013, 09:13 AM | #3 |
Great mock up 68_Step - I have recently received a mount from LMC and was wondering where it would look the best - it looks like the truck was design with that spot in mind - the the tire and wheel seem to fit perfectly behind the wheel well.
Btw, does the family love themselves some Kikoman Soy Sauce or what? JK Please post some pictures once you have it installed. Thanks
Texas - Don't Let The Size Scare You! |
04-30-2013, 10:26 AM | #4 | ||
04-30-2013, 01:20 PM | #5 |
MY 72 C10 had an aftermarket in that location and it worked out well. The stock location on both the short and long beds was just forward of the left wheelhouse.
But having it in the left rear also proved very useful and a convenient place to stash stuff behind like gloves, tire chains and tie-downs out of your normal sight line.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
04-30-2013, 03:34 PM | #6 |
I had one in the front driver's side before. Sorta liked it didn't block my view there. Rear corner I think is fine.
04-30-2013, 03:38 PM | #7 |
That does look good, and a lot easier than under the bed too
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
04-30-2013, 03:44 PM | #8 |
id do drivers just because when you look over your right shoulder it wont be in your view or hiding that car you are about to run into.
05-09-2013, 08:39 AM | #9 |
Mounting was a breeze. 3 carriage bolts - but I must admit I was a bit surprised at the 10mm bolts for a 67 Chevy mount!
05-09-2013, 09:23 AM | #10 |
Looks great - I see you have a lock on it - what are you locking to?
Great job, KellerMac
05-09-2013, 01:21 PM | #11 |
One could use one of these to scure the wheel. |
05-09-2013, 01:54 PM | #12 | |
What am I locking it to? Not much The LMC kit came with a steel loop that fits over the lug nut - it has a hole in it that lines up with a hole in the black bar that holds the tire in place, lock goes thru both holes. If they are more than a little determined the tire is gone, but last night the lock was handy. |
12-03-2013, 11:21 PM | #13 |
Thinking of getting one of these from LMC for my rig too. 73' Short bed K10
12-04-2013, 12:10 AM | #14 |
The Older Generation
You could always do this... LockDoc
12-04-2013, 09:07 AM | #15 |
12-04-2013, 02:18 PM | #16 | |
LockDoc - great idea. The only draw back I can see is does that hinder you from hauling 4x8 sheets of plywood or similar? I still need to use my truck as a truck.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
12-04-2013, 03:14 PM | #17 | |
Not my trucks but it shouldn't stick out any farther than the wheel tub... LockDoc
Thread Tools | |
Display Modes | |
