08-10-2016, 03:50 PM | #1 |
do they make air bags for the rear
I want something for when I load my truck.Just a basic kit that I could fill with an air pump.71 c10 8 foot fleetside,3/4 drop?Thanks
08-10-2016, 05:51 PM | #2 |
///Relaxed Atmosphere
Re: do they make air bags for the rear
www.airliftcompany.com try giving them a call I remember seeing someone on here has them on there 71 or 72. I have them on my daily driver cause I lowered the rear 2 inches and can tell you they work like they should when you when you tow, great product for the price and easy to install.
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R) 87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R) hector _________________________________ 1971 Chevrolet Cheyenne Super 1987 Chevrolet Silverado 2006 Ford Mustang GT 2012 Toyota 4-Runner 2014 Dodge Ram 1500 Sport Crew Cab |
08-11-2016, 06:25 AM | #3 |
Great. Thanks
08-11-2016, 04:42 PM | #4 |
Six in a row makes it go...
I've had airlift bags in two cars and on my 2006 C1500. They work well.
Read the instructions and don't run them with too little air in them...
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
08-11-2016, 06:14 PM | #5 |
I checked that site (www.airliftcompany dot com) and they have a series of vehicle selection dropboxes on their page -
For my 1970 C10 they do not have a product or even that vehicle listed. Seems odd - they do have them for the Vans G20 G30 etc of that year and many other vehicles but not specifically the C10 (or GMC half-ton) with coil springs or otherwise. I tried calling them but couldn't get through so maybe it is a custom order for my particular year and col spring set up. I did notice that Autozone is their retailer - probably special order but likely pretty quick lead time. Actually I wouldn't mind the bags on the front springs as well and initially without the on-board compressor because I could add that later and in the meantime just use an external compressor to set the spring rate. |
08-12-2016, 11:43 AM | #6 |
2WD Jimmy
This:.....Rear Air Ride Suspension Kits
http://www.earlyclassic.com/catalog....gory=Drop+Kits Would you like to lower your Classic and still be able to haul heavy loads or pull a large trailer? We’ve designed our Rear Air Ride Suspension Kit to allow the best of both worlds: Heavy hauling and a low rear stance without compromise. This kit is a direct replacement of your rear coil springs and can be inflated manually or with the optional on-board compressor system. Included in the system are the required Super Track Bar Kit, Shock Mount Relocator Kit and Two KYB nitrogen gas shocks. Rear Air Ride Kits (#902-6572AIR Kit includes Super Track Bar Kit, Shock Mount Relocator Kit and 2 Rear KYB Shocks. Does not include #902-5095AIR Rear Compressor Kit). (#902-5095AIR Rear Air Suspension Compressor Kit includes Tank, Gauge and Switch.) Options: |
08-12-2016, 12:42 PM | #7 |
My recently acquired k10 has brand new airbags in the rear from the PO.
I can send a pic if needed but not till I get home on Sunday...
1962 C10 Longbox LS 5.3 4L60E----Sold$$ 2014 Ram 4x4 3500 Laramie Diesel..Momma's truck 2015 Ram 4x4 1500 1997 Boxster. 1972 K10 Custom Deluxe LS 6.0 1950 GMC 3100 S10 & LS swapped |
08-12-2016, 12:44 PM | #8 |
I would love to see them. Pm me when you can
08-12-2016, 12:51 PM | #9 |
In the olden days GM could sell you an under-hood compressor along with air shocks (and heck, add an air horn while you're at it). Here's some of the factory pieces, for the curious.
I'm still searching for "the" reservoir tank or something similar enough. I'll plumb it in all at the same time, I think.
08-12-2016, 01:12 PM | #10 |
That's great!
Thread Tools | |
Display Modes | |
