04-06-2020, 01:14 PM | #1 |
Don't blame the messenger
Another Fuel Tank Retrofit Thread....
I have seen posts of various sorts of the different kinds of fuel tanks guys have used when retrofitting to a rear mounted tank. Yes, there are a lot of custom built tanks to choose from, I am not interested in those.
What I want to do is know more about the retrofit tanks from other vehicles to use on a 67-72 build. From searching the forum, I have found these options: 1. Blazer tank 2. 69 Camaro tank 3. 49-52 Chevy Passenger car tank Anyone have experience with other tank swaps?
On the Level Just a guy with a hammer and a grinder. OH!, and an HOA- enough said...: http://67-72chevytrucks.com/vboard/s...d.php?t=372525 "Some drink from the fountain of knowledge while others just gargle." |
04-06-2020, 01:41 PM | #2 |
Re: Another Fuel Tank Retrofit Thread....
I used a 32 gallon Blazer tank. Don't remember the year. Then changed the filler neck to center so I can use either side at the gas pump. My truck is a 69/70 C-30
04-06-2020, 05:08 PM | #3 |
Man, that is a huge tank! I like your fill mount, looks good.
04-06-2020, 06:31 PM | #4 |
Thanks. Yes that was a bit of a squeeze to fit in a swb. This veiw give you a better look at how it went in. Close to the differential but it clears
03-28-2021, 08:57 PM | #5 |
Junior Member
Do you have a photo of the rear with the bed on? I love the idea of a large tank but that seems like it might hang down pretty low.
03-29-2021, 08:26 PM | #6 |
Yes. I built my bed but I don't know if this pic helps. I have others. The tank sits up a tad bit higher than the plane of my frame.
03-29-2021, 08:52 PM | #7 |
The rear section of that bed is removable (between the wheel wells) so the fuel tank is accessible.
Thread Tools | |
Display Modes | |
