Old 07-07-2002, 08:23 AM   #1
RodC
RodC's Avatar
Unhappy Drum Brake Locking up, very grabby..
On my 71 (disc front, drum rears) the passenger side rear brake seems very grabby and locks up eaisy. BTW I have power brakes.
I have not had it appart yet, what should I look for? Is there a spring that could break that would cause this?
Rod Childers
'71 C10 Stepside
RodC is offline   Reply With Quote
Old 07-07-2002, 08:41 AM   #2
Brad
Out of the carpool lane.
Brad's Avatar
Check to see if the passenger side e brake cable is frozen, also maybe the star adjuster isn't doing it's job?
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 07-07-2002, 09:46 AM   #3
da-burb
"Ochre Ogre"
da-burb's Avatar
When this has happened to me it was a leaky axle seal. The oil saturated brake shoes would lock up the moment the brake was applied. Nobody tailgated me that day!
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 07-07-2002, 11:38 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
What ever it is, you'll probably notice it as soon as you remove the drum.
Old 07-07-2002, 11:41 AM   #5
68 with 350 TPI
68 with 350 TPI's Avatar
Well since everyone said everything else....... I would have to say the wheel cyl
Life is good with a 6-71 supercharged 355 in a 72 camaro
68 with 350 TPI is offline   Reply With Quote
Old 07-07-2002, 02:55 PM   #6
racedvl
racedvl's Avatar
It could be the drum brake gremlin!! That little bastard is reaking havioc in my rear brakes!!! LOL!!!!
racedvl is offline   Reply With Quote
Old 07-07-2002, 04:36 PM   #7
jhwkns
Registered Cruiser
jhwkns's Avatar
I'm with Brad on this one. Try lubricating your parking brake cables before you do anything else. That's a pretty common problem on these old trucks.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 07-07-2002, 05:54 PM   #8
CoryM
Make sure your wheel cylinders are not rusted solid. Time to pull the drum off and have a look. Da-burb, I had the rear brakes on a truck lock up solid on me from gear oil on the shoes. Be fine except I was on ice and rolling at about 20mph . HAd to leave the beater on an road that turned from snow to solid ice.
Needless to say it got creamed. Wrote off a new taurus though .
Good Luck
CoryM
1970 heavy duty C-10 fleetside sport truck. Vancouver B.C. Canada
http://www.geocities.com/chevroletc1070
"Take up our quarrel with the foe:
To you from failing hands we throw
The torch; be yours to hold it high."
Lieutenant Colonel John McCrae, Canadian Army
CoryM is offline   Reply With Quote
Old 07-07-2002, 07:12 PM   #9
RodC
RodC's Avatar
Thanks guys, I'll be takin it off tomorrow to check it out. I have had every other wheel off recently and all looked OK. I don't see any kind of fluid, but may have a small leak. Now that you mention it I have seen fluid on tractor breaks and clutches that made them act the same way.
Rod Childers
'71 C10 Stepside
