Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > Engine and Drivetrain
Old 01-18-2005, 11:02 PM   #1
bagged91
Out draggin'
bagged91's Avatar
Unhappy Factory Cruise Control
Putting out feelers for a factory Cruise Control servo that attaches to the fenderwell along with the cable.
Thanks....
Joe
91 GMC Xcab LB-Bags/bd/caddy clip SOLD
72 C10 Cheyenne Super LWB SOLD
92 GMC K1500 Burb
72 C10 Burb (ex. Cheesewagon)SOLD
72 C20 Burb parts truck
71 C10 Burb "project"
bagged91 is offline
Old 01-18-2005, 11:36 PM   #2
Rod
You at one time asked what a newer cruise would look like...this is from a 1975 set.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline
Old 01-18-2005, 11:51 PM   #3
Bob Moore
Cruise
Not to hijack this but how different it the 75 unit from a 71/72?
The fender bracket might be different(different curve of inner fender) and the short speedo cable would have a slip on end rather than a screw on end - but wouldn't the rest of the unit work just fine on a 71/72? Just asking??
Thanks - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline
Old 01-19-2005, 01:14 PM   #4
Rod
I was pointing out difference in the vacuum servo for bagged91.
You could make the 75 system work, or probably any other year around that era.
But if you want correct servo and such...look at spending more money.
Just letting him and everyone else the know the difference.
Otherwise its like the 72 BB motor mount I watch sell on ebay last night for about 10 times what there worth..cause they were 73 up mounts. All that by a former board member currently banned. You think he would know the difference ..it's his business to know...I say he knew, and thats
I have a few piece of a cruise system and could use more to complete it... but let bagged91 have his shot first.
Rod is offline
Old 01-19-2005, 01:59 PM   #5
'70_402
'70_402's Avatar
ok then i need some help.....i need to know if what i have is factory and just mounted in the wrong place?
here are some pics and some parts that i "think" go with the unit....
thanks for yall's help.
'70_402 is offline
Old 01-19-2005, 02:01 PM   #6
'70_402
'70_402's Avatar
here are some more pics
'70_402 is offline
Old 01-19-2005, 03:06 PM   #7
HuggerCST
HuggerCST's Avatar
70 402- Here are some pics of a '68-'70 setup. Not saying that yours isn't factory, but I've never seen one like it.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline
Old 01-19-2005, 03:12 PM   #8
'70_402
'70_402's Avatar
is there any way to identify what i have? i don't know much about the cruise control scene...... mine has never been hooked up so i don't know if it even works.
'70_402 is offline
Old 01-19-2005, 03:15 PM   #9
HuggerCST
HuggerCST's Avatar
bagged- Here are some pics of the '71-'72 stuff that I have. Pic #5 is a carb bracket from a '77, but would probably work with the '71 cable. The vacuum switch bracket appears to be fabricated.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 01-19-2005, 03:27 PM   #10
Bob Moore
Rod - I was not suggesting they were identical but that they were compatible for use if one was not doing a "restoration".
70 - That is a different set-up than the ones I have found for my 67,s. I have a firewall mounted bracket with a plastic wheel to guide a chain attached to the throttle arm. I removed mine from a GMC at the local junk yard complete with wire harness, brake switch, additional tab for brake pedal(as shown in the factory assembly manual). The wiring harness included wires for an additional switch on the clutch pedal but this truck was an automatic. Sadly I did not know how rare the cruise/turn lever was and did not get it or it was MIA.
A friend had a 71/72 Burb with factory cruise with the servo mounted down on the inner fender below the horn.
vac, 454, T400
more to follow
Old 01-19-2005, 03:30 PM   #11
HuggerCST
HuggerCST's Avatar
From what I can tell, here is what is missing, with the exception of the vacuum switch.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 01-19-2005, 05:41 PM   #12
Bob Moore
Cruise???
70 - 402 I'm not sure but the red paint on the brackets makes me think Buick. I think they used red on their motors back in the late 60's - this is just a guess.
vac, 454, T400
more to follow
Old 01-19-2005, 08:35 PM   #13
chipflyer
chipflyer's Avatar
This is what was used on 71 light trucks according to my installation directions. It was probably the same on 70-72, not sure though.
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline
Old 01-19-2005, 11:23 PM   #14
bagged91
Out draggin'
bagged91's Avatar
Ok, I know what pic 1, 2 & 4 are but what is the item in pic # 3? Does that bolt onto the carb's throttle lever?
Will the CC switch that's on the turn signal work with the OEM 71/2 setup?(the kind that LMC has in their catalog)
Thanks guys for the pics & info. Now I'm a little less confused about it!
HuggerCST, I'm sending you a PM on the stuff...
The things I get myself into.... No wonder she thinks I'm nuts....
92 GMC K1500 Burb
bagged91 is offline
Old 01-19-2005, 11:33 PM   #15
Rod
I have gotten into the posts about cruise controls before...basically search my name and the word cruise in an advanced search and you'll get all kinds of posts with pics.
Bob I was implying the same thing regarding that 1975 vacuum pod, it would work.
ChipFlyer..yours looks correct for 71-72 era except for the lever of signal. 71-72 Trucks never used that type....they were under dash type...and there
are 2 kinds of those... one is the one in the pic of my hand above. The other Ill try to post also.
Hugger the cruise chromed lever is not era correct...correct has no word of cruise on it. Your vacuum pod firewall bracket I havent held that kind in hand. Is it bent so it will go on the firewall like in a pic I'll post here. I have seen the other bracket at the rear of the pod like in a pic below also. I wonder what style the pic of the pod on the firewall has..its a members here..maybe he will post.
70-402 your lever is correct...the servo is correct.. the vacuum pod is 68 type but the bracket that holds the pod I believe is wrong for truck I think, probably a different application in 68. That 4 prong switch is for the tranny kick down on a turbo 400 I believe.
I'll try to throw some pics up.
1 showing the vacuum pod off firewall of a 1970 truck.
2 showing a 68 truck cruise..except the lever is 67 car. It's fluted handle.
3 is a cruise brake vaccum disconnect the cruise switch off the pedal.
4 a 1972 NOS cruise
5 a 69-70 cruise..note just one vaccum line off the pod.. thats what I figure the difference is between 69 and the 70..assuming 70 has just one line. Wrong lever in that pic also.
I've been on this board near 8 years now and it's taken a long time to gather up info on what I figure is correct.. but I'm open to opinions. Those newer cruise levers will work and you'll have the cruise activated on the signal arm. wiring is the same and same plug.
the difference in the servo's is that it appears 68 used a sysytem where the speedo cable were posiiton one on front one on side. 69-70 up had speedo cable one above the other.
I do belive that GM dealers just grabbed what they could to make a cruise system work in this era. Mix and match happened I figure.
Rod is offline
Old 01-20-2005, 12:18 AM   #16
HuggerCST
HuggerCST's Avatar
Thanks for the info, Rod. I don't have the vacuum pod bracket in front of me, but I think it is curved, the picture just doesn't show it. I didn't realize I had the wrong lever though. Can we knickname you "Cruisemaster Rod"? Oh yea, thanks for the pics too.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 01-20-2005, 01:12 AM   #17
chipflyer
chipflyer's Avatar
Rod I know you always have good info about the cruise posts but I am curious about the 71's. Could some have had the turn signal lever switch or is that not possible? The only reason I ask is because I have an original 71 owners manual and it doesn't show the under dash switch at all, in fact it shows how to use the turn signal lever type. Also my old 71 repair manual also shows the turn signal lever and doesn't mention the underdash switch. I'm not disagreeing with you about the 72's I have just never been completly sure about the 71's.
Jeff
Old 01-20-2005, 09:41 AM   #18
Rod
From what I have gathered in looking these things up..cruise became a dealer installed item in late 1970... to many problems with warranty being charged back to factory from what I interpret.
The parts books show this cruise button pictured here as 1970 after jobs and 71+ 72 cruise button. Part number 6465701 group 3.880
The chrome one is part number 6465627 same group 67-69 and 70 first jobs. Although I haven't seen a 67 truck with cruise on the glove box sheet even.
Closest I have seen is 68 on the board who by the way sent me this pic of his 68 vacuum pod...
so another version it seems.
Da-burb sent me this pic of engine bay from a 71 suburban he had that had cruise also. I think it was listed on the glove box also. I can't remember what he wrote back many years ago.
This took me over 8 years to gather up this kinda info..where else you gonna get it , but here.
The black lever with cruise written on it will work but is from newer than our vintage trucks.
Rod is offline
Old 01-20-2005, 10:01 AM   #19
Rod
It's kinda amazing every time I post good stuff...info for all...it all of a sudden comes up on ebay. And the bidding wars go higher and higher. Look at 8 tracks and such now.
here is a refurbished cruise on ebay... I believe its 1970 version, with wrong lever. Buy it now is $375
http://cgi.ebay.com/ebaymotors/ws/eB...category=34206
Rod is offline
