04-15-2005, 06:11 PM | #1 |
Active Member
1986 305 timing tab
My '86 305's timing tab is pretty dirty and all I can see are the "teeth"; the numbers are covered. I think I know what the teeth indicate but want to be sure so I know I'm setting the timing I think I'm setting.
Think of each tooth point as a high spot and the halfway point between 2 teeth as a low spot. There's one low spot that's wider and deeper than the others; I believe this is TDC. The first tooth counterclockwise from TDC is 2 BTDC, the next one is 6 BTDC, and so on. The low spots represent 4 BTDC, 8 BTDC, etc. Currently at idle the mark corresponds with the 2nd low spot, meaning the engine's initial timing is 8 BTDC. Does this sound right? Thanks! Brad |
04-15-2005, 07:19 PM | #2 |
Insert Witty Text Here
I don't know how much this helps, but I believe the white mark was pointing at TDC when I took this pic.
http://www.slonaker.net/images/truck/TDC.jpg I will be working on the truck tomorrow, and might be able to answer your question better then. BTW, mine is an '86 with a 305 also. Slonaker |
04-15-2005, 08:53 PM | #3 |
Active Member
Thanks! According to the photo I'm correct about the location of TDC on the tab, so now all that remains is to verify that it's 4 degrees from tooth to tooth. If you could please check that tomorrow (as long as it's not an inconvenience) I'd really appreciate it.
Brad |
04-15-2005, 08:56 PM | #4 |
i wish i had a timing tab.....
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
04-15-2005, 09:01 PM | #5 | |
1979 chevy c10 short bed step side BBC in the works |
04-16-2005, 01:22 AM | #6 |
Until Seventy Times Seven
Brad -
Here's what I got for a timing tab for a 305. Maybe Slonaker will be able to confirm this. Hope this helps.
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... Last edited by boxrodz; 04-16-2005 at 01:23 AM. |
04-16-2005, 03:50 PM | #7 |
What I drive
is that 12 at the end?
1986 Chevy Crew Cab Dually(Choo-Choo Conversion) 2006 Chevy Equinox |
04-16-2005, 08:42 PM | #8 | |
Active Member
Brad |
04-16-2005, 08:58 PM | #9 |
What I drive
That is why I asked if that was 12, I to thought that was 10 and it is past that. So my is probably around 14-15 initial!
04-17-2005, 01:54 AM | #10 |
You're welcome, Brad. (Sure is it tight where the tab is located.)
1986Silverado - Yes, the last timing mark is a 12 (ie. 12 - 8 - 4 - 0 - 4).
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
