Old 04-14-2002, 02:36 PM   #1
Benrs86
Benrs86's Avatar
Post exhaust+wood floor
can i have my exhaust cut off as it ends going down after the axle? will the fumes go into my wood and hurt it? its bruce horkey wood, i dont want to hurt it. lol. thanks, Ben
Brandon, SD
69 GMC 1/2 ton 2wd
wide long bed with wood
3 on the tree
350 engine 4 bolt main
rv cam
AIM = Alphray04
Benrs86 is offline   Reply With Quote
Old 04-14-2002, 03:41 PM   #2
Southpa
Southpa's Avatar
Post
You should try to route them to the outside.
Southpa
1970 GMC 1500 Custom
Victoria, BC, Canada
communities.msn.com/Alsplac/shoebox.msnw
Original 350/TH350
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 04-14-2002, 08:22 PM   #3
Benrs86
Benrs86's Avatar
Post
it would be bad to not go out? nobodys done this? thanks
Brandon, SD
69 GMC 1/2 ton 2wd
3 on the tree
rv cam
AIM = Alphray04
Old 04-14-2002, 08:26 PM   #4
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Post
my exhaust ends right before the rear axle.. but i have a metal floor, if you are worried just get some turndowns
My Truck pictures
www.xframeimpala.com
68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET"
56 big window short stepside 235 dual 1 brls
64ImpalaSS 327
70 C10 LWB fleetside custom/10 350/TH350
IM me on aol SN= SHAGROLET
68SWB4x4 is offline   Reply With Quote
Old 04-14-2002, 08:36 PM   #5
Mudder
Mudder's Avatar
Post
I have dumped mine about 18 inches from the rear of the cab for about 16 years. Really the onlu thing bad is the moisture affecting the frame and some carbon on the axle and shocks. Theres nothing on the bottom side of my wood floor. Just ad turn downs like pala said.
67 stepside 4x4 Owensville MO mudder67@hotmail.com
Mudder is offline   Reply With Quote
Old 04-14-2002, 09:33 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
I had wood and cherry bombs exiting about 2 feet infront of the rear end...no turn downs or anything. Never had a problem.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 04-14-2002, 09:48 PM   #7
Benrs86
Benrs86's Avatar
Post
sweet thanks for the replies. i think im just gonna cut them off and turn them down, im puttin on a trialer hitch, there in the way. thanks, Ben
Brandon, SD
69 GMC 1/2 ton 2wd
3 on the tree
rv cam
AIM = Alphray04
