04-22-2005, 02:01 PM | #76 |
For you that have put the blazer tanks in do you put the lines back in that go to the canister in the engine compartment ?
72 chevy super cheyenne 70 4x4 project blazer/F.S 66 chevelle 56 chevy sedan delivery 57 pontiac safari wagon |
04-23-2005, 05:53 AM | #77 |
if you decide togo with the stock blazer tank for our trucks be warned you are going to have too notch a cross member on the bottom of the bed if you have a steel bed which can be pretty hard if you dont plan removing the bed if you have a wood floor in your bed you can just remove the cross member i wish sombody would have warned me about this
08-15-2005, 07:18 PM | #78 |
I moved mine 'cause I got tired of the smell of gas inside my cab and spilling down the side of the cab after a left turn following a fillup. I guess I'm just getting old and prissy.
1969 1/2 ton CST the never-ending project!! 350 muncie m21 4 spd 3.73 posi and a box of extra bolts |
08-15-2005, 09:47 PM | #79 |
So, we need to be afraid of drunk people in the road instead of the fuel tank in the back. The trucks with the fuel tank in the chassis in this type of collision have more probabilty to find a spark than the ones inside of the truck.
08-15-2005, 10:16 PM | #80 |
Its a Truck Thing......
Well I dont plan on driving mine much, so I put the tank in the back, I ran the cannister with all new lines, the crossmember will be cut, but i hate to the spilling of fuel after filling it up and turning even replacing the gas cap twice a year. piss poor tank design. oh well......
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
08-16-2005, 08:46 PM | #81 |
i bought the tank from GMC paul, got the straps made and sending unit from a salvage yard....Tank holds over 20 gallons..22 i thhink..i also have a smaller 12 gallon tank that is the depth of the frame rails if someone wants it,would be good for a lowered truck that doesnt get driven a whole lot...or if you dont mind fillin it all the time...
1968 SWB Stepside, 250,pwr disc brake and tilt pwr steering, 5 spd tranny, HEI,Accel coil,K&N filter,Seat from a later truck with built in seatbelts, front and rear sway bars, moved gas tank to under the bed, headman hedders, new chrome bumpers,one wire alternator,Weber k550cub carburator...WORK IN PROGRESS, Freeland MI , Just bought a 72 Jimmy!!!!!!!!!!! |
08-18-2005, 03:16 PM | #82 |
I plan to put the tank in the bed on the daily driver I am building. I will put my spare under the bed. I have not contacted this vendor yet, so I only know what thier site states. http://www.auxtank.com/auxtank/home.asp
08-18-2005, 03:43 PM | #83 | |
67 is sold
08-22-2005, 09:14 PM | #84 |
None that I know of. They are faily common for fuel transfer tanks.
10-06-2005, 01:41 AM | #85 |
How tough is it to build a fuel cell. I dont really know what kind of technical stuff is in the cell but 400 dollars seems like a lot of money for a tank.
10-06-2005, 12:56 PM | #86 |
I looked at building my own, but after materials, time, and peace of mind it was an easy choice to get a Fuel Cell Guy tank. It mounted easily, and was literally plug and play.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
10-07-2005, 12:54 AM | #87 |
LMC's rear gas tank sucks, don't get it. it hangs way to low and looks like crap.
1972 Chevy Short Box Ls1 swap 1977 chevy Chevette |
10-19-2005, 10:09 PM | #88 |
Re: Rear Fuel Tank swap
Let me add my opinion....since it IS worth so much. :-)
First off, the blazer replacement will force you much work....the 1-3/8" filler and the fact that if its intended for a fleetside bed, major modification of the underbed support rail. The ECE version may seem pricey in the beginning, but...in the end you will be happy with it. 2" filler tube (at least for a side fill set up) Bolt right in using the stock holes (if a short bed will require removal of the original frame cross member, and the include a nicely made replacement) You can also specify carb or fuel injection (my recommendation, get the fuel injection version....it can be used with a carb and gives you the option of upgrading later) Comes with a 0-90ohm fuel level sending unit made by VDO. Holds 22~23 gallons. Made out of stainless, so it wont rust. Here are a couple of pics I have of my install. Only thing I requested on the tank is a 1/2" NPT bung installed apprx 2" in front of the side fill port, for the vent during refueling to prevent backfill issues. (this is non-standard to the ECE, special request) The filler door is from an S-10, not sure of the year. here are a coulpe of links (since I cant figure out how to add pics anymore) http://www.prismnet.com/~grzanich/ECE_FuelTank.JPG http://www.prismnet.com/~grzanich/71...iller_door.jpg Will be glad to answer any questions in regards to this.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
10-19-2005, 10:20 PM | #89 | |
Keepin an eye out
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
10-21-2005, 11:37 AM | #90 |
i got my relocation kit from gmcpauls. it's the poly version and so far i love it.
10-21-2005, 01:57 PM | #91 | |
Mike |
10-21-2005, 04:02 PM | #92 | |
As if this weren't reason enough, smelling fuel is not good for you either! I am going to do the swap for the above reason and that I once had a 67 (years ago) and it leaked fumes into the truck regularly and I need all the brain cells that survived college so Blazer tank here I come. I may even fab one up myself. I have access to a TIG welder and I can buy the SS, I plan to run an LT1 and need the intank pump. mike |
10-21-2005, 06:36 PM | #93 | |
http://67-72chevytrucks.com/vboard/s...699#post599699 stepsides will be this easy. fleetsides are trickier go here for the fleetside install http://www.classicheartbeat.com/mark...t_gas_door.htm |
10-21-2005, 07:29 PM | #94 |
Car O'Holic
Didnt someone on here put the filler neck though the rear post hole on the back of his truck?
Also I was wondering would it be possible to have 2 reasonably sized tanks in our trucks? One behind the wheels and one infront? I was wanting to do this (454 gets like 9mpg want to be able to go somewhat far without refilling) but having the filler necks in the driver side corners on the front and back. Do you get what im saying? |
10-21-2005, 11:49 PM | #95 | |
Mike P.S. Thanks for the links...I had found the stepside version but not the fleetside. Last edited by BigMike; 10-21-2005 at 11:54 PM. |
10-22-2005, 12:04 AM | #96 |
Who is fcg? Do they have a web site?
Thanks, Steve |
10-22-2005, 08:47 PM | #97 |
too bad there's a driveshaft in front of the axle. they make saddle tanks to go on the sides. don't ask me where they're sold, because all the one's i've seen are originals.
@big mike http://www.classicheartbeat.com/mark...t_gas_door.htm again here's a fleetside installation of the sidemarker filler. |
10-23-2005, 03:58 PM | #98 | |
Got Light Emitting Diode?
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
10-24-2005, 02:13 PM | #99 |
Vortec in the works
Here's a link to his website
http://www.aluminumfuelcell.com/index.html
68? It's all figured out untill you get it apart. Is it Sunday yet??? 68 Project 68 SWB frame off/98 Vortec with stock FI/power everything. 95 ECLB 2500 with 346,000 on the clock(the original HD) 99 Lesabre-wifes ride 08 Crew Cab LTZ-All Mine 89 SWB 5/7 drop-Son's first ride. |
11-05-2005, 01:57 PM | #100 | |
70+ ( Old Skool Club )
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
