Old 09-25-2002, 01:40 PM   #1
71MoneyPit
MPG...hmm..more like GPM
71MoneyPit's Avatar
What is this?
Hey everybody, i was wondering if any of the fellow Caddy swap members or a person that knows a bit about Caddilac engines can tell me what the heck this thing is or does. it hooks directly into each head. I don't have a clue as to what it is.
thanks in advance
(Looking for 67-72 shortwide or shortstep bed)
71 C-10, 500ci of tire shredding Caddy torque, th400, 12 bolt w/Powertrax Lock-Right. Bald Rear Tires
85 Toyota 4x4- 22r 4-banger, 5 speed, I can actually AFFORD to drive this one.
71MoneyPit is offline   Reply With Quote
Old 09-25-2002, 02:00 PM   #2
BUXMAN66
go bucks!
looks to me like a valve cover/head pressure regulator. evens out the pressure between both heads.i'm sure there is a tech. term for it......you get my drift!
'68 swb 1/2t 350/350th
'86 lngbd 3/4 TON parts getter
'49 gmc 1/2 t 5 window 350/350th
'96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know?
BUXMAN66 is offline   Reply With Quote
Old 09-25-2002, 03:49 PM   #3
brennecke
brennecke's Avatar
AIR pump tube.
Its part of the emmisions system.
Never tire of doing what is right II Thess. 3:13
Northeast Missouri
71 LWB original 350 3/speed
Soon to be 500
brennecke is offline   Reply With Quote
Old 09-25-2002, 06:45 PM   #4
THOR 50
Over worked under paid
THOR 50's Avatar
Thumbs up hard to tell
Looks like emissions to me! but hard to tell from pic.
I'd agree w/brennecke, air pump tube
Roger
'69 C-10 with GMC front clip billet grill, 283CI, 400TH and 12bolt posiw/3.73 gears
THOR 50 is offline   Reply With Quote
Old 09-25-2002, 08:14 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Interesting...never seen it before.
Old 09-25-2002, 08:14 PM   #6
lux hauler
Psycho-billy Member
lux hauler's Avatar
i think that's what it is. my eldo has it. that tube can be removed and the holes in the head plugged, right? What should they be plugged with?
'72 C-10
350 w/Lunati Voodoo cam (207*/213*, .437/.454), Performer intake, 625 Road Demon Jr. and Hooker headers.
Support your community, support yourself. Buy local, buy American (or Canadian).
lux hauler is offline   Reply With Quote
Old 09-26-2002, 09:57 AM   #7
brennecke
brennecke's Avatar
I don't think just plugging it is enough. Inside the head in the exhaust port is a little hole where that tube blows air intho the exhaust to help with reburn. Those have to be plugged too.
As for the outside, I heard that a dime is about the right size and welds in nicely.
Everyone interested in cad engines should relly get ahold of the BIG INCH CAD BOOK
It has all the info you need to do most anything to the cad, and all the info to give to your machinist when the time comes.
Northeast Missouri
Soon to be 500
Old 09-26-2002, 11:03 PM   #8
Longhorn Man
Hmmm, your link there took me to the site.
Old 09-27-2002, 12:54 AM   #9
GrungyCoin
Is that really a pink engine, please let it be my monitor:p
GrungyCoin is offline   Reply With Quote
Old 09-27-2002, 07:53 AM   #10
Drecarious
Engine looks to be Chevy Orange on my monitor
'67 LWB Fleetside
w/ 283 & powerglide
Edelbrock intake and 1406 carb
K&N filter, Flowmater 40's
Drecarious is offline   Reply With Quote
Old 09-27-2002, 08:44 AM   #11
brennecke
brennecke's Avatar
Andy
Look down the side for books. There's only one.
It's really for the big cad though, I don't know how much it would help with a 425. It's mostly about how to make the stroker and get the most bang for your buck out of the big cad.
Northeast Missouri
Soon to be 500
Old 09-27-2002, 10:56 AM   #12
Longhorn Man
Ahhh, OK. There goes that short attention span kicking in again.
Old 09-27-2002, 01:35 PM   #13
71MoneyPit
71MoneyPit's Avatar
Thumbs up
Thanks for all the help guys,
brennecke- do you think that rubber plug i have on there now would be sufficient? i tried taking the plugs out but they seem to be rusted on or something
Drecarious and GrungyCoin-for some reason it looks pink on my monitor too? but it's really Fire Engine Red
Yesterday was a good day, i finally got to fire the Money Pit up,she hit on the second revolution and fired right up.runs like a champ (neighbors probably weren't too thrilled with the open exhaust) you can definately tell that there is something lurking under the hood that isn't a SBC or BBC
anyway heres a pic of the front of the motor with the belts and fan put on
Old 09-27-2002, 01:39 PM   #14
71MoneyPit
71MoneyPit's Avatar
heres a closeup of the fan and belts, do you guys think ill need a fan shroud I'm not sure if there is room.
Old 09-27-2002, 01:41 PM   #15
71MoneyPit
71MoneyPit's Avatar
heres another (what is this? ) pic. It's on the passenger side back of the motor. The heater hose hooks to it? I wonder if i need it
Old 09-27-2002, 03:26 PM   #16
71GMC_3/4T
Weapons Of Construction
71GMC_3/4T's Avatar
That last pic is the vacuum controlled heater flow doo-dad.
When there is vacuum applied, it will allow the water to flow through the heater core.
I'd take it off and plug it. If you want to use it for heater hose, get a heater hose fitting and remove the vacuum thingy. Hopefully it isn't rusted in there for life.
1971 GMC 2500, 402/TH400 4.10 Daily Driver
Lafayette, CO
71GMC_3/4T is offline   Reply With Quote
Old 09-28-2002, 12:34 AM   #17
THOR 50
THOR 50's Avatar
exactly
part of the cadilac climate control if you're not using the cadillac system you don't need it.
Roger
Old 09-28-2002, 04:01 PM   #18
brennecke
brennecke's Avatar
Gotta say I don't know about rubber plugs. If they're already in there, then maybe. Isn't there a pump that connects to the heads somewhere? I'll have to look at my Eldo and see. I don't have that on my 425, and that's what I'm tearing down now.
Northeast Missouri
Soon to be 500
Old 09-29-2002, 10:48 AM   #19
71MoneyPit
71MoneyPit's Avatar
Thumbs up
thanks for all the help,
so that is a vacuum controlled heater flow thing? Couldn't i just remove it then and run that hose straight to my heater core Is that thing threaded into the block?
brennecke- sorry if i confused you with my reply. i meant there is a rubber plug where the AIR pump hooked to. (you can see it in the first pic, It's the thing thats circled.) I've tried to remove the pipe where it connects to the heads but it won't budge
Old 09-29-2002, 04:09 PM   #20
THOR 50
THOR 50's Avatar
Thumbs up straight to the core
You can run straight to the heater core.
I haven't removed mine but it looks like it's threaded into the block.
Roger
