Holley Carb Identification Help..
I have a Holley carb that a buddy gave me...sais its a 780 cfm, need to know if it is a double pumper, what CFM it is exactly and probably the part number or where it is located on the carborator. I know it is a dual feed square bore...but that's it. Any help would be appreciated, Thanks guys!!
Fabricate till you "puke"
Look on the front of the air horn(dr side) for the #. A dp will have an acc pump on the rearpass side. the vac secondaries wont have this. post the # , & somebody can help.........Crazy Al
The Mighty Blue Bottle
go to the holley web site and it will give you all of the info you need with the right list number
1967 Chevy C 10 Custom 350 780 cfm 467 lift 278 dur ported&pollished 2400 stall 350TH B&M shifter 175 shot of nitrious |
ok.
List-3310-1 is what is on there.
then below that it sais 0884. Tried to look at the numbers on the Holly site and it was down or something thanks. |
3310-1 is a 780 cfm. I may not be correct, but I believe the 0884 indicated that it was built in August of 1984. The Holley site is back up now.
Your 3310-1 is a 4150(has a rear metering block). as posted, it is a 780 cfm,& has vacumn secondairies. 72 primary jets, & 76 secondairy jets(factory). Renew kit # from my Holley book is 37-332......the trick kit is #37-915. It should be a good all around carb to run on 350- 455 ci engines,with a little tuning for the application. good luck.......crazy Al
