Old 10-02-2002, 04:14 PM   #1
ira ashley
AC Question
What size and length are the AC & HEATER duct hoses for the inside; also how many?
ira ashley is offline   Reply With Quote
Old 10-02-2002, 04:31 PM   #2
1971Stepside
Almost Satisfied
1971Stepside's Avatar
I believe there are three hoses. If you go to your local parts store you can buy the hose and cut it to fit your application. It is pretty easy to do especially if you have the trucks wiring out of the way. If not, pull the glove box out for the right side and you will need to get access to the center vent this way as well.
I hope this helps some. I don't know the exact length of each hose, but my guess would be 10' would do all vents easily.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
