08-13-2006, 02:22 PM | #26 | |
70+ ( Old Skool Club )
Re: Looking for PICS! Dropped
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
08-13-2006, 06:39 PM | #27 |
WTB this ad
I had a driveshaft built because the extreme drop crossmember requires the use of a one piece driveshaft. ECE recomends the use of a one piece shaft and extreme drop crossmember with anything 5" or more. In my past experiences when they recomend a part you usually end up needing it. Once again lots of guys on here are running 6" of drop in the back or more and claim no problems without the shaft conversion or the crossmember. My upper control arm bushings were replaced due to wear. I really don't know how we didn't see it when we were replacing the springs and spindles. I like my drop and how the truck drives but if I had it to do over I might do it different. A 5" drop out back combined with a 2.5" drop spindle and a stock height front spring would get things about right. I'm only saying this because I didn't want to notch the truck and in all honesty it could use it.
08-13-2006, 10:34 PM | #28 |
I have 2" drop spindles and air bags on the front and bags on the rear. Here are 2 pics one with air in the bags (a little dark, sorry) and one with the air let out.
08-13-2006, 11:07 PM | #29 | |
'Bags' aren't all bad, but like they say with everything else: You get what you paid for.
08-14-2006, 07:56 AM | #30 |
67-72 Addict!
Wow, you guys have some really cool looking stances!. see ten- I love your trucks stance!. I just bought a disc conversion kit with 2½" drop spindles but not sure if I want stock springs up front or not. Right now I have almost 3" front and 4" rear and this gives me a ¾" rake. I might add a block in the rear and cut another pair of springs to bring it down a little more in the front. It's hard to tell until the disc kit is installed.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
09-23-2006, 06:25 PM | #31 |
heres mine, 3" drop spindles, stock front springs, 4" drop rear coils with 2" blocks. the 454 takes about another inch off the front.....so 4/6. rolling on 20s........rat
09-23-2006, 06:34 PM | #32 |
heres another one
09-23-2006, 10:47 PM | #33 |
heres my 69. i did a 5.5/6 drop with springs. it also has 16"x8.5" wheels with 225/55/r16 tires, so whatever drop that added. the only problem i have is when i gotta put a floorjack underneath the crossmember. i have to drive it up on 2x4s. i havent had any safety issues with it yet. later...
09-23-2006, 11:07 PM | #34 |
Heres mine as it sits now.
4.5/5 drop 2.5" spindles and 2" coils 3" springs and 2" blocks in back
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s 64 Cadillac Sedan DeVille |
09-23-2006, 11:18 PM | #35 |
XIV. As of October 15th 2005 subscribing members will be the only ones permitted to post for sale and want to buy ads on any classified section of this site. All other rules of buying and selling still apply. 67-72chevytrucks.com, its administrators or staff are not responsible for any transactions on or off the forums. We will work hard to ensure you a smooth transaction, and help in the event you may need it, but all for sale and trade areas are buyer beware. Any persons who have misrepresented an item, lie about an item, fail to deliver, or are in violation of any of the rules will forfeit there subscription fees and be banned from 67-72chevytrucks.com
09-24-2006, 08:33 AM | #36 |
Like a Rock!
Who sells the 2" rear blocks?
69 LWB Runs great - work in progress Mess with me and you mess with the whole trailer park! |
09-24-2006, 10:14 AM | #37 |
i made mine but you can buy them at www.classicperform.com
