Old 09-26-2006, 10:08 PM   #76
shifty
Questionable
shifty's Avatar
Re: my official 68 shortstep ls1 thread (lots of pics)
I'm using the stock manifolds from the car listed.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 09-26-2006, 10:57 PM   #77
shifty
Questionable
shifty's Avatar
Here's a shortcut way to add a manual temp gauge :
http://ls1tech.com/forums/showpost.p...8&postcount=54
Lots of pictures.
Old 09-26-2006, 11:39 PM   #78
CAL 58 GMC
CAL 58 GMC's Avatar
Nice work so far 68 shortstep! Keep the pictures coming.
CAL 58 GMC is offline   Reply With Quote
Old 11-04-2006, 11:49 PM   #79
68 short step
maken a little progress.... got a electric dual fan im maken mounting brackets for, and modding to fit my rad... also plumbed up the rad to the overflow can.. and plumbing up trans to cooler...
68 short step is offline   Reply With Quote
Old 11-04-2006, 11:51 PM   #80
68 short step
also got my wheels in they are foose nitrous 20s on rear and 18s on front
Old 11-05-2006, 12:02 AM   #81
msgross
msgross's Avatar
wow, I need my sunglasses for those...very nice
msgross is offline   Reply With Quote
Old 11-05-2006, 01:06 AM   #82
shifty
Questionable
shifty's Avatar
Man, those things are huge looking!
Funny you got the fuel lines out. I was sposta work on them today, then a friend called and was stuck in between floors in his house (fell through the cieling while working on the subfloor upstairs). That ate up a lot of the day, then I came home and shot myself in the eye with Brake Cleaner. That put me out of commission for another hour, and by then it was dinnertime
Looks like you got your lines going well. I'd post the PDF of how to make em, but looks like you got the hang of it already
Old 11-05-2006, 10:34 AM   #83
caseychoptop
caseychoptop's Avatar
Originally Posted by 68 short step View Post
maken a little progress.... got a electric dual fan im maken mounting brackets for, and mdding to fit my rad... also plumbed up the rad to the overflow can.. and plumbing up trans to cooler...
just looking at the overflow tank for your rad, i have a 400ci smallblock and the rad just has a overflow pipe draining on to the fllor if it overflows, is that not right then
caseychoptop is offline   Reply With Quote
Old 11-05-2006, 10:38 AM   #84
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
NICE
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 11-05-2006, 12:56 PM   #85
shifty
Questionable
shifty's Avatar
This is the stock setup. Normally, the overflow tube will come out of the radiator, clip onto the side of the battery box and just pour to the floor.
In theory, when your radiator heats up, pressure develops against the spring loaded rubber cork inside the cap, and when it hits a certain PSI (should say on the cap), the rubber cork is pushed up, allowing water to flow into the radiator.
I read recently that the radiator should be able to push/pull water from your resevoir when needed. Still not sure how that works with pulling the water back out of it though.
So, I guess, ultimately the answer is "yes, no overflow tank is normal", but a lot of the guys add them on here.
Old 11-05-2006, 02:02 PM   #86
72CSTC5
72CSTC5's Avatar
It's looking good. Coming around.
72CSTC5 is offline   Reply With Quote
Old 11-05-2006, 03:38 PM   #87
Hart_Rod
Hart_Rod's Avatar
When water heats up it expands, when it cools it contracts. This contraction creates a vacuum on the resevoir and pulls some water back into the radiator. At least that's how I think it supposed to work.
Hart_Rod is offline   Reply With Quote
Old 11-05-2006, 04:06 PM   #88
caseychoptop
where can i get one of those overflow tank/tubes????
Old 11-05-2006, 04:46 PM   #89
shifty
Questionable
shifty's Avatar
I understand how the head + pressure trips the cap/plunger to flow water out of the radiator, I just don't understand how the vacuum after cooling trips the cap/plunger to suck water back in.
Old 11-05-2006, 05:05 PM   #90
Boise69
The Hammer Man
Boise69's Avatar
Quick question... the trailing arms and springs you have in the back.... are they stock? maybe dumb question but i have the same set-up on mine and wasn't sure if they are stock or not. i'm just getting to know my truck after 3 years of driving it.
Boise69. Bought in Boise ID and its a '69
___________________________________________
1969 Chevy C-10 SWB 350/400 - drivable project
www.americanhammer.com
2013 MBZ Sprinter customized
2005 MBZ Sprinter Van
2004 Land Rover Discovery
2001 Yamaha Road Star
1997 MBZ E420
1989 Ferrari Mondial T
Boise69 is offline   Reply With Quote
Old 11-05-2006, 08:08 PM   #91
watahyahknow
watahyahknow's Avatar
it doesnt at least not when the pressurecap is still in place ....... normally the expansiontank is connected into the coolingsystem without any valves or watever in between .
the tank needs to be only halffull the air in the expensiontank gets compressed when the exess water enters it and pushes the water back intoo the system when it cools back down again .
the expensiontank itself has a blowoffvalve in the cap too but that only works in extreme cases to prevent the tank from blowing up
the only reason to put a tank at the exit end of a blowoff cap is to preserve nature by catching the exess fluid instead of dumping it on the road
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 11-05-2006, 08:23 PM   #92
68 short step
summit sells them, manufacturer is billet specialitys
Old 11-05-2006, 08:24 PM   #93
68 short step
yes the trailing arms are stock, springs came in the ECE 6" lowering kit
Old 11-09-2006, 01:12 AM   #94
oscareltemblo
oscareltemblo's Avatar
It's coming along nice good job.
My Official build thread http://67-72chevytrucks.com/vboard/s...d.php?t=196844
oscareltemblo is offline   Reply With Quote
Old 11-09-2006, 02:05 AM   #95
84 400
Sb 400 club
84 400's Avatar
WOW great build up gonna be one killer stepside when done
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 11-09-2006, 01:54 PM   #96
70rs/ss
70rs/ss's Avatar
How are you wiring up the motor, and comp? I have a 6.0 and want it in my 68 short stepper. Love the biuld-up, been watching this and shifty's as well. When you guys finish I should be able to just whip through mine with all of the experience I have gained here!!
70rs/ss is offline   Reply With Quote
Old 11-09-2006, 02:06 PM   #97
shifty
Questionable
shifty's Avatar
Nope, you'll run into your own unique problems. There are a lot of little things that both of us have left out (me, on purpose, or out of laziness) that you'll need to figure out. that's why I pity the person who ever tries to consolidate this info and sell it on eBay as a swap howto (hello, negative feedback! )
What do you mean by "how are you wiring up motor and comp"?? That can be taken many ways - you mean, how are the wires ran, where are you mounting the comp, where did you get the harness, ????
Old 11-09-2006, 08:30 PM   #98
68 short step
the wiring is a harness im doing myself, and the computer will be mounted under the dash (if thats what you're asking)...... you'll have your share of obstacles too.... the easiest part of the swap is the actual mounting the engine trans in the truck.... here is a goood tool to aid in all questions to come www.ls1tech.com the conversion and hybred section....
BTW i met boyd in rockwall TX at a car auction i was attending, i thought he was a jerk, but i can say i met him...
Old 11-09-2006, 09:01 PM   #99
watahyahknow
from wat i see in the american hot rod series i can only agree with you , there is a chance that he's different in real life but i have my doubts .
i wouldn't like to work in his shop no matter what they would pay me
Old 11-09-2006, 10:46 PM   #100
Greubin
Greubin's Avatar
Great build so far!! I noticed the A&P manual, are you working general or commercial av? I was an AP in my former life, prior to 9/11.
Keep up the gr8 work
___________
Greubin
'71 C20 custom - GM Crate 350CI/290HP, BTO 700R4 level II, Qjet, and HEI
Greubin is offline   Reply With Quote
