#51 | |||
Union Electrician
Re: My build up thread 67 small window short/fleet
Got a little further this weekend
![]() front panel brought up to the shop for some trial fitting and to work out the feul filler details. I went to the local hardware store and picked up a bunch of 3/8" and 5/16" carriage bolts, nuts, and washers to use for trial fitting, I will be using polished stainless button heads bolts for the final product. THe pieces went together fairly well, but I do have work still to do as I could get 3 or 4 of the bolts in. The PS bedside is absolutely perfect dead on, but the DS is the one that needs the tweeking, but over all the Goodmark parts are a nice fit. I haven't squared the bed or anything yet just go as many bolts as I could in it, and it measures off about a 1/2" cross corners, but from side to side it is really close a little tweaking and it will fit really nicely. I will be useing the stake pocket fill like John Frabris's FAQ and have got the filler cap ordered and will try to get it worked out this week sometime.I gave it a glance today and it looks like it may be a little easier for me because of where my filler inlet in the tank is. It is alot closer to the rear of the truck than the blazer tank and should have almost no bend in it from the stake pocket to the tank inlet. In the last pic I put a small red circle around what is not really visible but it is the center seat from a set of buddy buckets ![]() ![]() ![]() I want to again thank all the board members involved in getting my seat to me safe and sound, Huck, Teeitup, and Gmcjon, oh I almost forgot Teeitups brother for meeting up with Huck and teeitup's boy was sick.This type of help and comraddery(sp) is what this board is all about,and can't thank you guys enough ![]() ![]() ![]()
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
#52 | |||
Union Electrician
Last pic
#53 |
Sb 400 club
once again nice work byrd
![]() ![]() 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed ![]() 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
#54 |
Randy, trucks lookin' good. I guess by the progress on Frank, you haven't tried the patch piece I dropped off to ya? Thanx for the parts. Will be able to finish radio install now. Great meeting you. Wish we woulda had more time to BS? Maybe sometime you can come this way with Huck? Still got a couple of schools to attend down your way. Will catch up to ya then?
Later, Dan ![]() ![]() ![]()
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() |
#55 |
Designated A-hole!
It's looking better by the day.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
#56 | |||
Union Electrician
Dan,
No that is for my driver and it is in the perpetiual awaiting restoration ![]() ![]() I believe the patch panel will work just fine, just needs a little sectioning to line up right. Thank you again for bringing it down with you. Please do holler at me when you come back down for school!! ![]()
#57 |
![]() ![]() Join Date: Jul 2002
That is coming together real nice. I need to get back on mine (stupid work).
#58 |
![]() Join Date: Feb 2000
Cool to see the parts get to you through the hands of numerous boardmembers. I've met gmcjon and teeitup and they are great people. Keep at the project!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
#59 | |||
Union Electrician
Got a little more done yesterday and today. I got all new brake parts, calipers, ceramic pads , turned the rotors, new bearings races, grease seal, and new cotter pins. For the the rear I got new wheel cylinders, new shoes and spring kits, turned the drums. I also got the new stainless e-brake cables installed while I was at it. I pulled the hoghead to replace both axel seals and drained the fluid and also check the ratio. I found the truck has 3.07 gears in it. I blasted the brum backing plates, drums, and the front dust shields, and painted them flat black high temp and they turned out nice.I will have the rear done tomorrow, I had to wait on an ebrake spring, the PO had the wrong spring on it.
I got the stainless pop up style filler neck today and I knocked out the little piece of metal down in the DS stake pocket. Smashed my thumb while knocking that piece of metal out ![]() ![]() I went by the machine shop building the motor and was informed the heads were shot of the motor and I needed to replace them ![]() A few pics....
#60 |
good reason to try to get some vortec heads now (you need another manifold for it though )
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts Last edited by watahyahknow; 10-19-2006 at 06:06 AM. |
#61 | |||
Union Electrician
Got a little more done over the past week or so. Got the rear shock relocator brackets installed, still need to put rear shocks on, also go the front shocks on I used doetch tech(sp) drop shocks for better ride and handling. Got the DS rear stake pocket enlarged a little and cut down the filler I bought and got them close for now, still need to finish it up. I went and picked up the motor last Thursday, installed the intake after picking it up form the sand blaster, got the motor taped up, prepped and painted with Plastic coat high temp paint.NO dice on the bc/cc as he was afaid it would peel from DD. Peeled the tape off and put in the oil pump,pump rod(bought a all metal rod to replace the stock plastic one
![]() ![]() ![]() I drove my 69 in my avatar to pick up the tranny from Bowtie overdrives yesterday at a local trucking terminal. Fresh 200r4 with a 1800 stall and complete install and TV made easy kit, and torque converter lock up kit. A guy at the trucking terminal asked me if that was my 69 in the parking lot, and when I said yes, he then wanted to know what I wanted for my truck, and was shocked when I, without hesitation said," it's not for sale". I guessed he wasn't used to hearing that ![]() I did find out that the headers I have will not work with the heads. The headers have round holes and the heads are squared. ![]() Here are a few pics
#62 |
she's coming along very nicly, great job
common sense isn't so common anymore |
#63 |
good stuff! Way to go.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
#64 |
The Hammer Man
![]() Join Date: Oct 2006
You are motivating me for sure!
I'm just a bit nervous to tear into her. Can one but the cab cart or just have it made. I'm not a good welder but i do have someone in my shop that can. |
#65 | |||
Union Electrician
More progress!! I finished up the serpentine belt set up and had to add a bolt hole in the pass side head for the bracket. Got all the water, and PS pump and pulleys on as well as the A/C compressor, new belt and new idler and tensioner pulleys. I have ordered the alt and it will be here Tuesday and that will complete that part. I will have to rework the fule line some, maybe with some braided flex because the serp bracket is in the way of the fuel lines normal path.
Got the motor and tranny bolted together with a new high torque mini starter and tried to use the headers seen in the pics but the driver side is not going to work ![]() I tried to finish up the E-brake cables but ran out of time and will work on it some more this weekend. With the weight of the motor and tranny in, I'm really digdin' the stance ![]() Her are a few pics of the progress..
#66 |
Everythings really looking good! I can tell you have done a lot of work since the start.
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 Last edited by CAL 58 GMC; 11-11-2006 at 02:37 AM. |
#67 |
MY EX DRIVES A BROOM
lookin good, keep it up
They say nobody's perfect. I'm a nobody, so I must be perfect. Building Nemo -1968 C10 Long Bed FRED -1947 KB-2 International |
#68 |
The cabless truck. I had one of those too.
It looks good. Progressing along very nicely.
#69 | |||
Union Electrician
Thanks guys for the words of encouragment!! It means a lot!!
Looking for a set of 3/4 length ceramic coated headers that will fit, any help is appreciated
#70 | |||
Union Electrician
I picked up a cab(almost totally rust free, literally) from Montana that Huck a fellow board member turned me on to. Bill another member here in Ky brought this cab back and had it for sale. Huck contacted me and I got in touch with Bill and the deal was made. This should make the restoration a lot easier as the cab I had before was pretty rough(see pics in earlier post)I brought the cab home yesterday and got it into the shop for a photo op.Huck was also very helpfull in giving me a 1 1/2" yoke that I needed for my 200r4 to get the driveshaft work done and complete the driveline.Hopefully in the next two weeks I will be able to get the bodyguy started on the cab and keep the restoration moving along. The cab will only need maybe a rocker and a little on the kicks panels, but other than that is is rust free, all cab supports, cab corners, winshield area, visor area, and floor pans are rust free and in great shape.
Thanks again Huck for the help and the heads up!!! Here are a few pics of the cab..
#71 | |||
Union Electrician
few more pics, there is a little damage to the PS drip rail ,somebody before Bill and I must have tried to pick the cab up with a strap and pulled it loose, shouldn't be hard to fix.
#72 |
Sb 400 club
looking great and that is gonna be one killer rolling tribute when done. great work!!!
#73 | ||||
Union Electrician
#74 |
those rims are from a late 70's early 80's corvette just so you know. here is a picture of what they look like polished and with the red stripe on them. BTW cool build and i am hopping to have a 67-72 SWB really soon sense i might have someone that wants to trade for my corvette (not the one in the picture)
![]() Last edited by liquiddragon; 11-19-2006 at 12:58 PM. |
#75 | |
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
