Old 11-27-2006, 11:56 PM   #1
mothertrucker424
mothertrucker424's Avatar
what is breaking point??
what kind of off road abuse or playing can a stock '72 handle?? what are the weak points and positive points of this year??
this is my daily driver and my weekend light duty mud truck
i dont wanna push it to breaking and wanna bring it back to a nice looking truck
not really show but something to be proud of . i will be lifting it soon 4-6" with 33"s i have gathered many of good info so far but i figured i'd get an answer on the breaking point??
thanks
mothertrucker424 is offline   Reply With Quote
Old 11-28-2006, 09:47 AM   #2
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Re: what is breaking point??
Frame cracking under stress at the steering box.
Battered fenders from not having enough lift.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 11-28-2006, 03:09 PM   #3
johnnywagon
Sofa King. We, Todd, Ed.
johnnywagon's Avatar
Wow, where to begin? I've had multiple problems with all things related to the driver side leaf spring and steering. If you're twisting a full size Chevy with a 6" lift you can expect steering problems and potential leaf spring issues. I have broken leaf center pins, bent the shackle and damaged the front spring mounting bucket.
~John
71 Blazer One Ton
65 Chevelle Station Wagon x2
59 Belair 2 Door
71 Chevy Open Road Van RV
www.myspace.com/johnnywagon
johnnywagon is offline   Reply With Quote
Old 11-28-2006, 05:06 PM   #4
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
1st. thing that came to my mind (Frame cracking under stress at the steering box.) Depends alot on how hard you wheel it. Ball joints will go alot faster. Tie rods too.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 11-28-2006, 11:31 PM   #5
mothertrucker424
ok so is 4" lift gonna have less problems or is 6" and 4" gonna have same problems??
is there anyway to beef frame and steering box??
Old 11-29-2006, 12:24 AM   #6
1969k10stepside
You can box the frame for extra strength.
1969k10stepside is offline   Reply With Quote
Old 11-29-2006, 12:37 PM   #7
johnnywagon
I had no probs with my 4" lift. Different story when I went 6 inch. I built a brace behind my steering box. I used a piece of 1/4" thick angle iron behind the front two bolt holes that I also bolted to the stock cross member. The diagonal brace goes to my hitch mount but the angle iron alone might help if you dont have a place to put the diagonal brace.
~John
71 Blazer One Ton
59 Belair 2 Door
