Old 01-02-2007, 01:49 PM   #1
Critter
Future TOTM Winner
Critter's Avatar
Rear Springs
Ok, I want to buy some 6” rear springs for my 72 K5 but I am having trouble finding manufacturers that offer them. After calling each of the manufacturers, here is what I have found so far.
ProComp ----not offered
Superlift ----6 inch
Tuff Country ----6 inch
Rough Country ----not offered
Rancho ----not offered
Skyjacker ----5.5 inch plus add-a-leaf (EXPENSIVE!!!)
Fabtech ----not offered
Are there any other manufacturers that make a 6" lift 52” rear spring?
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 01-02-2007, 02:24 PM   #2
desertrat
desertrat's Avatar
Re: Rear Springs
I want to get a set from Deaver Springs, but they dont show a listing for our year blazer but they have a listing for 6" springs for '74 blazer (not sure if it is the same length). I'm sure they could custom make a set if they don't currantly make it.
www.deaverspring.com
desertrat is offline   Reply With Quote
Old 01-02-2007, 02:32 PM   #3
desertrat
desertrat's Avatar
Re: Rear Springs
Also you might want to consider National Spring. They build a custom spring specifically for youre vehicle , but you will probably need to scale youre blazer.
www.nationalspring.com
Old 01-02-2007, 03:37 PM   #4
johnnywagon
Sofa King. We, Todd, Ed.
johnnywagon's Avatar
Re: Rear Springs
Got the 6" Super lifts on mine.
~John
71 Blazer One Ton
65 Chevelle Station Wagon x2
59 Belair 2 Door
71 Chevy Open Road Van RV
www.myspace.com/johnnywagon
johnnywagon is offline   Reply With Quote
Old 01-02-2007, 06:10 PM   #5
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: Rear Springs
Originally Posted by Critter View Post
Rough Country ---- not offered
That is what is on "GQ"
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 01-02-2007, 06:20 PM   #6
Critter
Future TOTM Winner
Critter's Avatar
Re: Rear Springs
That's what I thought you had said, but I called them directly today and they said no. Maybe they quit making them or something. They make a 6" lift for a 56" spring, has GQ been updated somewhere along the way?
Old 01-02-2007, 06:33 PM   #7
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: Rear Springs
Not that I know of
Old 01-02-2007, 10:35 PM   #8
Mike C
Mike C's Avatar
Re: Rear Springs
Rear springs are same for GM 4x4's from at least 71-87. As long as you have the 52" springs. Some 3/4 tons had 56" eye to eye springs. Measure eye to eye and order 73-87 lift springs with 52".
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-03-2007, 01:27 AM   #9
Musclerodz
Re: Rear Springs
Any 52" spring thru 87 should work. Or you could do a shackle flip kit to help retain ride quality.
Mike
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 01-03-2007, 11:55 AM   #10
Critter
Future TOTM Winner
Critter's Avatar
Re: Rear Springs
I’ve heard that before, but I haven’t been able to confirm it. So why do the manufacturers offer a different kit for the 73-87 from the 69-72? Are the front springs different or what? My problem is I have to order all of this so I can’t just walk into a store and look at the parts. Thanks for the help.
Old 01-03-2007, 06:04 PM   #11
Jtrux
I'm a poor spectator
Jtrux's Avatar
Re: Rear Springs
Hell Terry, you should just leave the suspension the way it is and drive it til it breaks...that's what I did and look at me now.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 01-03-2007, 08:16 PM   #12
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Re: Rear Springs
Front springs are different from 73+. Rears are the same.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 01-03-2007, 10:09 PM   #13
Mike C
Mike C's Avatar
Re: Rear Springs
As noted above, fronts are longer on the 73-87. Rears are the same. I have National Spring 4" lift 52" springs on my Jimmy. I bent the axle mounts with 2 1/2" blocks and a 1 1/2" add-a-leaf. Axle wrap was terrible also. My springs have been on my truck since 1991.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 01-04-2007, 12:19 AM   #14
Critter
Future TOTM Winner
Critter's Avatar
Re: Rear Springs
Hell yeah! Problem solved! Thanks guys!!!
Old 01-06-2007, 09:00 AM   #15
vtblazer
vtblazer's Avatar
Re: Rear Springs
Alcan is another one you could check into.
They make theirs using 6/7 thin springs per pack instead of only 4 thicker ones.
Ride quality and flex are excellent.
My blazer rides better than my moms lumina with the sport package.
vtblazer is offline   Reply With Quote
Old 01-07-2007, 12:44 AM   #16
1969k10stepside
Re: Rear Springs
I ordered a 4 " lift from rough country and was sent a 6" lift for my 71 4x4.So I know that they have a 6" lift that will work for a 69-72
1969k10stepside is offline   Reply With Quote
Old 01-07-2007, 03:05 PM   #17
badchev69
Active Member
badchev69's Avatar
Re: Rear Springs
I had the tuff country 6's then switched to the skyjaker 8's...... huge difference in ride quaility. I was very surprised. I guess thats why skyjacker is so darn expensive!
1969 C10 SWB /350 vortech/th400
1968 SWB build (in progress)
1969 SWB build (my son's future project)
1968 camaro yellow/white stripes (wife's car)
2011 GMC reg cab short bed 2wd daily driver 5/7 drop on 22's
1972 K5 Blazer 13"/11"lift,38"M/T MTZ's, 3" cust exst.
350/350 (sold it )
badchev69 is offline   Reply With Quote
Old 01-08-2007, 11:35 AM   #18
Critter
Future TOTM Winner
Critter's Avatar
Re: Rear Springs
I must have talked to the intern-in-training or something when I called RoughCountry. All of the info that this guy gave me is different from what y’all are saying. I asked if they had 52” rear 6” springs for a 72 and he said no. I think he just looked through the application manual, didn’t see it right off, and gave up. 1969k10stepside, did they send you a 6” kit with rear springs or blocks? Maybe I need to call them again and see if I can talk to someone else. I’m not losing my mind. I even took notes over what the guy was telling me, didn’t get his name though, dang!
Old 01-08-2007, 02:19 PM   #19
Angelse68cal
Cochino_Racing_909
Angelse68cal's Avatar
Re: Rear Springs
Ok The truth is you should really concider doing the Shackle Flip from ORD.
It Has a 4 inch drop so then you will only have to get a 2 inch spring.
The Shackle flip is so much better ride and also helps axel Wrap.
Angelse68cal is offline   Reply With Quote
Old 01-08-2007, 02:46 PM   #20
71jimmy
71jimmy's Avatar
Re: Rear Springs
BADCHEV69, sent ya a PM!
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 01-08-2007, 03:45 PM   #21
Critter
Future TOTM Winner
Critter's Avatar
Re: Rear Springs
I agree about the shackle flip having a better ride. I don’t like how it positions the axel farther forward and I don’t really feel like moving the shackle mounts around for longer springs to correct that. Maybe I will do it some day down the road.
Old 01-08-2007, 04:44 PM   #22
Angelse68cal
Cochino_Racing_909
Re: Rear Springs
Its not all that Bad I have it on my 72 Jimmy and I have a 8 in super lift. Its nice!
Old 01-08-2007, 05:42 PM   #23
1969k10stepside
Re: Rear Springs
I got the rear springs for it.I will post some pics later tonight of them.They are actually closer to 8" lift
Old 01-08-2007, 11:36 PM   #24
1969k10stepside
Re: Rear Springs
Here are a few pics of the springs/truck.4" lift on front,about 8" on the back .I have got ahold of the company I bought the lift from and they are going to get this figured out and get me the 4" lift I ordered....
Name:  truck frame.jpg
Old 01-09-2007, 10:30 AM   #25
Critter
Future TOTM Winner
Critter's Avatar
Re: Rear Springs
Are you saying that they are 8 inches like they are right now on the bare frame? I'm sure that they will compress alot when the body is on. I believe that is how the manufacturers measure them.
