#201 |
Life, Be In It.....
![]() Join Date: Oct 2003
Wooh Hooo, my first block party. It should be fun learning something new, I just hope I don't screw it up. I have my filtered mask ready to go. The pics look great, I will add them to the DVD slide show I'm making.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
#202 |
Active Member
Re: Project Lemon Drop: anything but stock!
Kevin,
Thanks for the recharge to get going on my project. I bought a set of your flip dolly plans last year and I am finally going to get it done. I just purchased a Lincoln 140c mig welder. My big question is what bodyworking tools do you recommend I get? I can't wait to get started. Sonny |
#203 | |
Note on your tip and flip, if think down the road you may want to get the "One man cab & bed lift" than use 6" casters not the 4" I call for in the prints. It is not a must but it make your life alot easier trust me. I still have 4" on mine and it is a pain only when using the cab lift. Kevin LFD Inc. |
#204 |
Well I only had one person show up for the block party so I put him to work on the drivers door and burgers were served for lunch! We got one door finished inside and out, jambs, window rail and all. We also finished the hood and one fender. Next week end will finish up the front sheet metal. After each part was finished we sprayed them down with prep-all for a nice wet film that will show any flaw before paint and they look great! Here are a few shots of the one guest working. I think he thought I was joking when I handed hit a 1" stir stick and told him to have fun!
Kevin LFD Inc. Last edited by Rokcrln; 02-11-2007 at 10:55 PM. |
#205 |
Chevy Forever
You are having him do what my friend the body man is having me do. All the Grunt work ;o)
I also thought about putting 6 inch wheels on the dollie I really wish I had now but other then that I love the thing I modded it to fit my long bed and it still works great. All I do to get the cab and bed lift to work I jack the dollie up and put the legs on it and when I am done I just reverse the process. It would be a lot quicker with shorter legs ;o)
My first love 1971 C20 Hugger orange Getting face lift and heart transplant .30 402 BB /TH400 and GV Wifes car 1969 Chevelle SS 396 325hp/TH400 Factroy A/C Automatic w/ Floor shift console. restored. |
#206 |
Hey I was right along side him doing the hood and fender
![]() Kevin LFD inc. |
#207 |
Life, Be In It.....
It is very nice of Kevin to say that "We did it", but actually it took me 5 or 6 hours to do that door. (My first time block sanding a car) Kevin completed the hood and one fender.
Boy let me tell you, I have a new respect for those die hard body guys. My fingers, upper arms, lower back and neck hurt from all that sanding. But it paid off, because the parts look great. Thanks for the schooling, Kevin. I am looking forward to giving a hand with other customer's projects in the future. Now if you excuse me I think my pain medication is kicking in.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 Last edited by jugernot; 02-15-2007 at 06:42 AM. |
#208 | |
By the way you are a freakin genius when it comes to building trucks. |
#209 |
#210 |
We got some more done on the truck today. Fenders, hood, cowl and one door are done. The grill is ready for it's 320 grit sanding and I had to touch up a spot on the door where the old mirrors were filled in. I then pulled the cab and modified the fire wall for the 8" booster. I had to raise the hole about 1" and fill in the bottom portion, make a new push rod shaft and do some body work due to the new hole and the A/C mount I welded to the inside of the fire wall for the Vintage Air mount. We hope to have the bed pulled and modifications done (fuel filler door, bed rear mount, roll pan, cap off the end's of the rails) by monday so I can send the frame back home and get ready for paint real soon. Here are a few pic's
Kevin LFD Inc. |
#211 |
And the rest of my messy shop.
Kevin LFD Inc. |
#212 |
That booster looks great. Progress is good, even when it's only a little.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
#213 |
Yes blocking for perfection is never fast. But it shows in the end.
Kevin LFD Inc. |
#214 |
kevin-
A while back you mentioned a product, "Prep-all." Could you give some more details on that. I am familiar with using a black primer as a guide-coat to reveal high and low spots, but I'd never heard of a product like you described.
Have mercy, I'm recovering from my 4x4 addiction. ![]() |
#215 |
Life, Be In It.....
Well it’s my turn to post an update. Kevin made a lot of progress today with some modification to the step bed. While I spent my third day block sanding the doors.
Kevin cut a square hole on the left side bed side, to make room for the gas door. He also added a vent tube for the tank which exits to the upper right of the gas cap. Then He cut out part of the rear cross sill, so the rear roll pan could be mounted. The license plate cut out originally hit the rear cross sill. He also welded up all the bed panel seems, removed the bolts holding the bed together on welded up the bolt holes. The top ends at the front and rear of the bed were caped off with a patch and welded. All of this to give the bed a clean smooth looks. Subtle modifications, but noticeable if you know what you are looking at. Did I mention that Kevin did all that while I sanded one door and the grill. The final thing we did was load up the frame onto Kevin's trailer. The drove it back to my house about 45 miles away. About 10 miles from my house the trailer had a blow out. Just I was pulling into my driveway, Kevin calls me and asks if I can bring a floor jack. The unfortunate thing is that Kevin did not have a spare tire for the trailer, but the wheel from my frame just fit. So the frame is safe back in my garage. Anyway enough with the BLAH BLAH BLAH, there are some pictures. Sorry about the quality, I think it was operator error.
#216 |
Life, Be In It.....
Here are some more pictures.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 Last edited by jugernot; 02-20-2007 at 01:01 AM. |
#217 | |
A guy with a truck
- Chris
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#218 | |
Oh and don't forget you got part of my shop all vacumed up while I was grinding! ![]() Kevin LFD Inc. |
#219 |
Tailgate time!
I installed the gate keeper kit this morning. It went well but their are a few things left out in the directions I had to work around. I started by using their templet for the upper bolt stops. Then you have to cut away a notch on both sides od the gate for the stop arms to set in side of. After that bolt on the upper bolt stop and put on one of the bracket arms. This is were the directions fall short. They give a dimention from the bottom pivot bolt for the gate up to were you drill two 1/4" holes for the bracket to bolt to the gate. The dimention given is 27/32" and as you can see this does not work. What I did and would recomend even with a corect dimention is use a C-clamp and a square and adjust the gate so it is 90* to the rear of the bed. Once this is done take a transfer punch and mark your holes to drill. Once this is done bolt the bracket on and you will see that the bolts stick out too far and need to be cut off (also not mentioned in the directions). Once both sides were done I went to close the gate only to find out it would not close and I had to grind out a bit of the slotted hole at the bed end of the arms. This let it tuck up and allows the gate to close all the way with out binding. All in all it went good and works very well. I would recomend this kit for others that want the chain free look. The kit is from Mar-K and if anyone has a contact with them please send them this link so they can update their directions. Kevin LFD Inc. Last edited by Rokcrln; 02-24-2007 at 02:23 PM. |
#220 |
The rest of the pic's
#221 |
The LuvShack Garage
Sweet, wish I lived closer, I'd luv to be watching and learning in person
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
#222 | |
Looking good BTW ![]()
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill Last edited by brak; 02-24-2007 at 02:35 PM. |
#223 |
Bed body work is done
![]() ![]() Next is a small amount of work on the inside of the cab and we should be all ready for paint! Kevin LFD Inc. Last edited by Rokcrln; 02-24-2007 at 08:07 PM. |
#224 |
![]() ![]() Join Date: Jul 2002
Very Nice Kevin. Love watching your posts. Can't wait till I get back on mine again!
#225 |
Kevin - I got a little lost on the tailgate at first. I gather, after looking at the pictures, this is a lot like the fleetside tailgate hardware? As usual you have done an outstanding job on this installation.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
