04-11-2007, 10:49 AM | #51 |
Seņor Member
Re: West Coast 67
C'mon out... I can put a cot in the basement for you Do you take S&H Green Stamps?
04-11-2007, 04:23 PM | #52 |
Digital Dude
Re: West Coast 67
I like the two tone as well. This one was cool one to do, I really liked the ideas that went into it. Now on to the next one.... (sound of whip cracking)... back to work to work render boy!
Carter |
04-11-2007, 10:38 PM | #53 |
Re: West Coast 67
Ok, I have a really stupid question. I'm sorry but please just humor me. When the wheels are so big and so tucked, is there a problem with the turning radius? It just doesn't look like it the wheels would turn very far. Is something done to fix this or is it just not as tight as it looks?
'70 GMC SWB step-side- 454, 4 speed, air bags (in progress) '09 CTS-V M6 '03 Sierra SWB Z71 '82 Yamaha Seca XJ650R Turbo! '04 Yamaha FZ6 |
04-11-2007, 11:26 PM | #54 | |
Re: West Coast 67
I think the front wheels are little too big... I think a 20" wheel with a 27" diameter tire looks best in the front of these trucks.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
04-11-2007, 11:29 PM | #55 | |
Seņor Member
Re: West Coast 67
Oh, and I've got that cot set up and ready to go
04-11-2007, 11:33 PM | #56 |
Re: West Coast 67
What is a S&H Green stamp? Oh XXL... how about a sleep number bed in the master bedroom?
04-11-2007, 11:50 PM | #57 |
Re: West Coast 67
This shows the age of both of you
04-12-2007, 08:11 AM | #58 |
Re: West Coast 67
Looks great as always! I like XXL's idea of a hood cowl merger. I have been thinking about this and then sink the windshield frame down about 1.5" (1.5" chop) and hide the wipers down their as well so you would increase the cowl to glass gap, smooth everything out on top and still have wippers. This was done in Tex Smith's book on chop Tops and thought it was cool
Kevin LFD Inc. |
04-12-2007, 08:36 PM | #59 |
Re: West Coast 67
Some more pics of the fender/hood welded up.
04-12-2007, 08:37 PM | #60 |
Re: West Coast 67
Few more...
04-13-2007, 07:15 AM | #62 |
Re: West Coast 67
Love the plexy fire wall
Kevin LFD Inc. |
04-13-2007, 07:34 AM | #63 |
Weekend Warrior
Re: West Coast 67
Awesome Work!! - can't say that I dig the hood treatment, but you gotta do what you gotta do.
Do you have any pictures of the welded sheetmetal seams before ginding them? - I see some Cleco's and looks like a backer piece of metal in some of the pictures - did this backer get welded in with the overlap like that?
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered |
04-13-2007, 09:38 AM | #64 |
Seņor Member
Re: West Coast 67
04-13-2007, 10:14 AM | #65 | |
Re: West Coast 67
That backer piece is just for fitting... I butt-weld all my sheetmetal joints. I just used it to get the front piece fit up.
04-14-2007, 08:09 PM | #66 |
Re: West Coast 67
All i can say is WOW
04-14-2007, 08:43 PM | #67 |
Re: West Coast 67
Interesting on the grinding, I have never heard of anyone doing that before.
04-14-2007, 08:49 PM | #68 | |
Re: West Coast 67
Kevin LFD Inc. |
04-14-2007, 08:58 PM | #69 | |
Weekend Warrior
Re: West Coast 67
You're obviously TIG welding everything as you would never be able to get a MIG weld to metal finish like that. - How did you close those gaps where the backers were used for fitment? - I though you couldn't fill a gap that big in sheet metal with a TIG? Looks like you had to split the front of the hood section to get the body lines to work (which left you with those gaps) I guess my question is were you able to close them or did you add a "filler strip"???
04-15-2007, 12:19 AM | #70 | |
Re: West Coast 67
When TIG welding a panel I try and get the edges to butt up perfectly (no gap). The way I achieve this is by lining it up best I can, tack it in a few spots, then take my trusty cut-off wheel (1/32") and run it along the entire seam making the gap perfectly even (I don't cut the spot welds yet). Now I have a perfect gap that is even and true. I then cut the tacks and butt the panel up tight. Out comes the welder and away I go. After each tack or small stitch I will grind, hammer, and dolly the area making sure the entire panel maintains alignment. It may seem like it would take more time to use this method, but time spent now almost always means time saved later! If I am using the MIG process I follow the same steps, only I don't butt the edges up completely... I have found it best to leave a small gap to aid in penetration.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! Last edited by PBFAB.COM; 04-15-2007 at 12:20 AM. |
04-16-2007, 08:05 AM | #71 |
Happy to be here
Re: West Coast 67
Subscribing...
04-16-2007, 09:17 AM | #72 |
Re: West Coast 67
I grind as well with a 3M weld grinding wheel, 3" same but I have never ground down each individual spot weld as I go along. I will have to try that method and see how it comes out. Wish I had a tig welder though. May need to buy one this year some time as money permits.
04-16-2007, 10:50 AM | #73 |
Re: West Coast 67
Looking forward to watching this one come to completion.
2004 Kawasaki KLR Always looking for a cheap driver |
04-16-2007, 07:50 PM | #74 | |
Re: West Coast 67
04-16-2007, 07:52 PM | #75 |
Re: West Coast 67
Starting to look like a truck again! At least for a little while...
