Old 04-15-2007, 08:14 AM   #101
meathead95
computer illiterate
meathead95's Avatar
Re: I lifted the hood on the Blazer . . .
congrats yukon!
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 04-15-2007, 09:50 AM   #102
jaros44sr
jaros44sr's Avatar
YJ, I'm sorta confused with all fuel tank problems. Are ou saying you don't have to fool with the replacement tank neck, all you have to do is cut a section out of the old filler neck and use it like a splice to get the correct angle to fit??
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 04-15-2007, 10:29 AM   #103
RustyParts
RustyParts's Avatar
Originally Posted by vtblazer View Post
Who's close enough to you to 'run' over and pick up parts for our truck?
Man...I'm so jealous.
If I don't have it in my own stock out in the back 40, I have to order it online.
I hear ya' brother.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires
The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers!
RustyParts is offline   Reply With Quote
Old 04-15-2007, 11:02 AM   #104
Yukon Jack
Yukon Jack's Avatar
On this tank, yep, that ended up being the very simple fix. Lucky the guy who swapped the neck only cost me $20 so wasn't too big of a loss. Course it could be the company that made this tank has placed the filler in the more correct position and angle - I don't know about that. I have the box the tank came in still so I will get all of the info and post it.
One of our boardmembers commented that that looked like all it needed when he saw pics of my tank and I remember in Herb101's tank thread someone mentioning that that was a potential way to solve the problem.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-15-2007, 11:16 AM   #105
jaros44sr
jaros44sr's Avatar
Thanks YJ, will wait for further info. Tank project comin' up in the not to distant future, altho it doesn't leak yet!
Congrats. on getting the truck on the road, looks great...
SAFETY FIRST
AS usual, off topic
Jim
Old 04-16-2007, 03:47 PM   #106
Yukon Jack
Yukon Jack's Avatar
Drove my two girls to school this morning and then headed over to get my antique tag registered - yep - I'm not legally driving the streets!
Ain't that 14 bolt sexy
Had to snap some shots of the K5 outside since most of my shots have been from inside the shop.
The seat covers are off a vehicle that my dad has - he hated them and was going to get rid of the. I noticed the shape was pretty close and tried them out and they work pretty good. Not necessarily what I would have chosen, but sure beats sitting on ripped up seats!
Got into the secondaries yesterday and a couple times today - really bogs down and sputters so something needs to be adjusted. Sure drives and runs well when the secondaries are shut.
Old 04-20-2007, 12:31 PM   #107
Yukon Jack
Yukon Jack's Avatar
jaros44 - the box from my tank says Fuel Tank Kit and gives the following number: 69-9310-BKIT. The manufacture info was torn off of the box.
I got it from www.bowtiebits.com for $250 and it comes with the tank, the straps, a sending unit, new sending unit seal and lock ring. It did not include the rubbber strips that go between the tank and the straps.
Old 04-20-2007, 04:55 PM   #108
jaros44sr
jaros44sr's Avatar
Thanks YJ for the info, how did the straps work out, did they fit rite??? Thanks for getting back to me!!! J.
SAFETY FIRST
AS usual, off topic
Jim
Old 04-20-2007, 05:58 PM   #109
Yukon Jack
Yukon Jack's Avatar
I used my existing strap, the ones in the package were more generic.
Old 04-20-2007, 06:01 PM   #110
jaros44sr
jaros44sr's Avatar
Thought so, I bought new ones, and didn't like them. I thought I would just spot weld some stainless steel onto my old ends. J.
SAFETY FIRST
AS usual, off topic
Jim
Old 04-23-2007, 10:03 AM   #111
Yukon Jack
Yukon Jack's Avatar
After doing lawn work Sunday I took a few minutes and worked on the Blazer doors. They were opening extremely hard so I put a couple shims at the mount directly behind the front seats and a shim at the mount behind that mount. Definitely a big improvement but the passenger door is still a little tight. If I remove one of the contact plates (not sure of their actual name) on the door, the passenger door opens effortlessly but I'm sure those plates are needed so won't leave them off.
After getting the doors to open better I installed the rear shocks - imagine that, alot less bouncy now!
