Old 04-16-2007, 11:08 AM   #1
crm318
Alright Alright Alright
crm318's Avatar
play in the rear axles
i was putting on a set of new tires on yesterday and noticed when i got one of my wheels off, the axles had just a little bit of back and forth play (pushing it in and out, not side to side. is this normal? it is on an 8.5 10 bolt with a 3.73 posi.
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 04-16-2007, 12:34 PM   #2
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
Re: play in the rear axles
Going by what I have experienced there is a little in and out movement. From how the C-Clip installs on the inside of the axle.
IIRC it should only be very minor (MEMORY) No more than a 1/16th to 1/8th of and inch or so, Not much more. Someone else might have a more exact measurement for ya.
Side to side which you stated you do not have would be a bigger problem leaning toward axle bearing faliure.
I would say your fine as long as there no major movement.
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
