Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 06-10-2007, 01:56 PM   #201
Frizzle Fry
Frizzle Fry's Avatar
Re: Joined the Short Wheelbase Club *69 Tahoe Project*
It'll be either white/blue like the first rendering in this thread, or replace the blue with dark green and the white with silver.
Update on the hidden hinges: It's not as simple as I thought... I've determined that in order to use a single point (conventional) hinge I'll have to shave the rear drip rail. You just can't put the fulcrum high and aft enough to clear it. It doesn't matter what the rest of the hinge looks like, if it's a single point hinge the arch is fixed around the fulcrum, and this determines the hatch motion.
The other option is to use a compound hinge like Sachse Rod Shop makes. This would move the virtual fulcrum to the outside of the panels providing the correct arch for the hatch motion.
I made up some simple drawings to help illustrate this. The compound hinge diagram is exaggerated, but shows basically what a virtual fulcrum looks like:
Frizzle Fry is offline   Reply With Quote
Old 06-11-2007, 12:47 AM   #202
CG
BlahBlahBlah
I like the stock style hinges. Keeps it looking more like a 69 Tahoe. Helps make it more of a guessing game...Is this truck stock? Once you start smoothing and modernizing the exterior you lose a little of that.
Of course Id still love to have it either way
Old 06-11-2007, 01:47 AM   #203
Frizzle Fry
Ya, that's why I don't want to shave the drip-rail, just hide the hinges. Most people won't notice... even 67-72 truck owners. How often do people study the back of a 67-72 Burb (besides a few of us here)?
Old 06-12-2007, 06:57 PM   #204
Frizzle Fry
Looks like the hinges might have to go on the back burner for now. It may be more time/money than it's worth. We'll see...
I have a bunch of goodies coming in the Big Brown Truck over the next couple of weeks
Old 06-12-2007, 07:49 PM   #205
62 short step
62 short step's Avatar
Awesome, awesome, awesome!!! And I was worried about cutting on mine!!!
62 short step is offline   Reply With Quote
Old 06-12-2007, 07:54 PM   #206
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Tease
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 06-13-2007, 12:00 AM   #207
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
nice
LOW DOUGH is offline   Reply With Quote
Old 06-13-2007, 06:50 PM   #208
Frizzle Fry
Brown Truck delivery numero uno:
Old 06-13-2007, 06:54 PM   #209
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Sweeeeeeeeeeeeeet. I have the same one, uninstalled, was it easy to do?
Old 06-13-2007, 07:25 PM   #210
Hart_Rod
Hart_Rod's Avatar
What drop did you go with? Quit holding out, .
Hart_Rod is offline   Reply With Quote
Old 06-13-2007, 10:18 PM   #211
Frizzle Fry
Well, I couldn't get the OG stud out of the rear end. Must need a press or something and I'm not taking the whole thing out at this point. So I ended up hacking it off...
The other thing I found is that you need to put the bar in place at both ends BEFORE you tighten up the passenger side U-Bolt. This is because there is some play in the bracket's U-Bolt holes. So if you install the bar you can clock the bracket correctly, then tighten the U-Bolt.
Also, I already have lowering blocks and longer U-Bolts so the nice new one's that come with the kit are useless to me. You may be able to ask for longer ones if you already have blocks.
Alright, alright Bags (SS RE7's) for all four corners, the top digital air management package from SD, KP step notch, and some of their weld-on shock brackets. I'm going to put the rear bags in the stock location for now and see how I like it. The 2.5" lowering blocks plus bags should get me pretty low
I also have my quarter glass and all the rear seals on the way
Old 06-13-2007, 10:47 PM   #212
Frizzle Fry
Barn Door Lovers avert your eyes...
This one will never again have the option to be a barn door truck (well, anything is possible...):
These holes had to go... (don't mind the little scene stealer):
Old 06-13-2007, 11:07 PM   #213
Hart_Rod
Hart_Rod's Avatar
You get more use out of fender washers than anyone I know! I did it the hard way, I cut them all out, . Are you filling the hole on the bottom?
Old 06-14-2007, 01:16 AM   #214
Frizzle Fry
Yep, I used 1" OD 3/16" ID "fender washers." They fit perfectly and the 3/16" hole is easy to weld up. The BD hinge slots and the "trough" (as I call it) are next.
Old 06-14-2007, 01:38 AM   #215
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
this is the setup i just completed on the rear of my truck and the bottom of my license plate sits 4.5" off the ground. that's with RE7's, 2.5" blocks, and a bolt in notch. If i had a bigger notch, i could easily get another 2" so really, the blocks are pointless with a bolt in notch. details are in my build thread in my sig.
sounds like you're going with a step notch. that should get really low with bags and blocks.
IvelDesigns is offline   Reply With Quote
Old 06-14-2007, 07:39 AM   #216
Hart_Rod
Hart_Rod's Avatar
The blocks don't allow you to go lower aired out, but they do allow you to "ride" lower at a higher air pressure (if needed).
Old 06-14-2007, 10:34 AM   #217
Frizzle Fry
The blocks don't allow you to go lower aired out...).
They do when you have a step notch.
Old 06-14-2007, 12:27 PM   #218
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
very nice
Old 06-14-2007, 03:17 PM   #219
Frizzle Fry
I'm basing that on this:
This is the notch I'm going with. This truck has relocated bags and no blocks. You can see how close the trailing arms are to the frame. Mine will have bags in the stock location so the arms will be spaced off the frame by the hight of a collapsed bag when aired out. I'll make up for that with the blocks.
You can also see why I went with the ECE super track bar over stock:
Old 06-14-2007, 04:54 PM   #220
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
This Is An Awsome Build! Great Work!
Old 06-14-2007, 04:57 PM   #221
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Oh, are you going to do the tail lights like Hart_Rod. I think the truck lights look great on the Burb... I mean Tahoe!
Old 06-14-2007, 07:49 PM   #222
Frizzle Fry
Thanks, I'm thinkin about it They won't be exactly like his though. His are definitely an inspiration though
Old 06-14-2007, 10:31 PM   #223
h8menow
can't wait to see it bagged, i'm planning on using he6's in front and he8's in the rear. i have the air ride ride pro e on my infiniti and i love it.
h8menow is offline   Reply With Quote
Old 06-15-2007, 11:42 AM   #224
Frizzle Fry
Me too It sits way too high in the back right now. You have a Burb?
Old 06-15-2007, 11:44 AM   #225
Frizzle Fry
Speaking of notches... :P
I can't put it in until the rest of the stuff gets here because of the upper shock mount/crossmember.
