09-12-2011, 07:12 AM | #1 | |
1 thing at a time is progress.
Re: Project Vitamin C-10
Has any body looked at my wiring question 2 post above?
Alan
Philippians 2:14-16 |
09-12-2011, 10:29 AM | #2 |
Daring to be Different
I would mount the fan relay close to the fan. Not in the cab. Run a temp switch to turn on the fan, or a switch where ever you want.
Dennis Check out my 65/73 Cheap Build Thread. http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] I AM WE TODD IT, I AM SOFA KING WE TODD IT |
09-12-2011, 08:41 PM | #3 | |
There's my $.02
09-12-2011, 08:47 PM | #4 |
Thanks guys, I'm going to repost my question for clarity.
I'm studing the schematics and planning. Questions: Is there any reason why I can't keep the relay inside the cab? I know the reason for a relay is the reduce the bigger wires from being in the cab. So that means I need to keep it close to the battery. I just don't want a lot of wires in the engine bay. Info: I am running a single fan with two terminals. My plan Fuse panel Spot #1 to one side of the temp sensor included in the relay package. Then the other wire from the sensor to the yellow wire of the relay. Spot #2 unsure what to connect there if anything. The only thing I can think of is the ground wire from the fan or the ground from the relay. Relay Red wire- to the battery. Black wire-to chassis ground close to the battery Green wire- to the AC controller, which will be discussed in a later post Orange wire- power to the fan with the fan grounded to the chassis. Let me know if I'm getting close to having it right. I don't want to wire up something I'm not sure of and have to redo it.
Alan
09-12-2011, 10:02 PM | #5 |
HOW long until spring??
Alan , Just got home, This working for a living screws up my free time
1) the relay is usually located close to the power source and the load as Dennis mentioned. The relay could be hidden be behind the grille off to a side out of view if you wanted. Keeping the relay close to the load keeps the voltage drop to a minimum with the heavier wires doing the work and then the smaller gauge coil wires running back to the cab to turn things on and off. 2) I think you have the right idea with the plan , I am not sure what you mean by spot 1 and spot 2, Would that be the terminal location from the terminal block(panel connection block)?? I cannot quite make out the terminal numbers on page 1 But with a single fan you would only need the one output from the N.O. relay contacts to the fan motor. 3) use a good grounding method, I like to extend all the ground wires to a common area and ground them together and then to the frame or back to the battery or block. I have found on old cars and especially trailer lights, most electrical problems are really grounding problems, Now, looking into the future,, Are you planning to run the high and low beam relays for your headlights??? maybe they all can be hid in a shiny junction box or concealed in the same location behind the grille or headlight bucket area???,
69 chevelle convertible 71-C-10 short-wide and low 64 C-10 custom shortbox "Bubba"s Recycling project" |
09-12-2011, 10:42 PM | #6 |
Not to confuse the situation, but I use relays to ground also. I did that with air bag compressors, and worked great. No come backs or melted wires.
09-12-2011, 10:45 PM | #7 |
Alan
09-12-2011, 10:46 PM | #8 |
Sorry for that.
09-12-2011, 10:48 PM | #9 |
Instead of powering the compressor, I use the relay to switch on the ground. Make sense?
09-12-2011, 10:44 PM | #10 | |
So do I need to connect anything to the terminal #2 on the fuse block? It's showing a switch or sending unit to ground. I don't think I need to connect anything there.
Alan
09-13-2011, 09:38 AM | #11 | |
PITbut
fixit-p Awesome guy.
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
09-15-2011, 12:12 AM | #12 |
Just a quick note, I'm not getting all the notifications either from any threads. I think I got two notifications all day from other threads. It's really sporadic.
Alan
09-15-2011, 12:19 AM | #13 |
I get all the notices. No problem here.
Maybe it your Smart Phone settings?
09-15-2011, 12:41 AM | #14 |
VA72C10
who's your email carrier? I'm looking into it...
Looking for a 67-72 swb or blazer project in or around VA. |
09-15-2011, 01:19 PM | #15 |
I use yahoo. I check my build at least once a day and here lately I hardly get any notifications of new post. There are a couple post I get notifications daily and haven't checked that particular thread for some time. Thanks for looking into it.
Alan
09-15-2011, 01:31 PM | #16 |
VA72C10
No prob...I'll let you know when I find out something...one way or another
09-15-2011, 12:49 AM | #17 | |
I think it's one of the most annoying things ever so I just set up cron jobs to visit the forums every few minutes to keep me updated |
09-15-2011, 01:57 AM | #18 | |
VA72C10
I already get well over a hundred emails a day from this site...it'd be more like 5-600 if i got one for every single post
09-15-2011, 01:34 PM | #19 |
VA72C10
Whenever you log onto the forum you'll (or at least should) get new notifications for ALL threads you've subscribed to...not just the ones that you've actually visited.
Can you check and make sure a notification email didn't get into a spam folder possibly? That is a problem that's been mentioned...
09-15-2011, 02:04 PM | #20 | |
I did get one notification just now for you recent reply. I didnt get one for your last message. I check spam about every other day and haven't seen anything there. Posted via Mobile Device
Alan
09-15-2011, 03:16 PM | #21 | ||
VA72C10
09-15-2011, 03:23 PM | #22 |
Yep. Yahoo (& ATT) were blocking/auto-spamming my responses also. I use another account for my board(s) e-mail.
09-15-2011, 06:32 PM | #23 |
since my last visit i have not gotten any notification from your thread
I am aware that you have to visit to keep getting updates and I also get mail from this site on one thread that I rarely visit and then I got the updates today on 198Plus build which i posed a comment last night I am using Yahoo and it has not been an issue in the past until the last few months I suppose I will follow Liz's advice and see if it changes anything Thanks |
09-15-2011, 07:31 PM | #24 |
Alan I don't get notifications from your thread either.........I think your thread has screwed the Internet up with your view count and post
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=346597 https://www.facebook.com/pages/198-C...1434001?ref=hl |
09-15-2011, 08:24 PM | #25 | ||||||
I'm still running wires inside the cab. Nothing really to post about as far as progress.
Alan
Tags |
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange |
